Willawake and Bushytails, this one is yours to mod. I'll gather up all the Q & A's I can find throughout the forum and begin this. You both have mod rights over this forum, so have fun and be creative. Being the admin, I can do the same as well. Tonight or tomorrow I'll start building a mass FAQ thread and see what other ideas pop into my head.
FAQ Section in the works!
<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsTags: None
by sam_sam_samSo I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line... -
by piernovActivity on this forum has been increasing steadily and the workload for the moderation team as well in order to keep the place clean, so please make an effort to keep it organized.
I've been deleting more and more posts that make a mess, so take a minute before posting to make sure you make a proper request/offer.
Reminder about the rules and the organization of the "Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals" section.
This section and its subsections are about the following classes of devices:- Desktop computers
- All-in-one
03-31-2023, 06:17 AM -
by CapLeakerGot a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing.
O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
by rouninHi everyone,
I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
🛠 Original Issue
The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
Diagnosis showed PP1V5_UPC0_LDO_CORE shorted to ground.
I replaced U3100 (UF400) using a donor board (A2179), and the machine powers on fine now.
⚠️ New Problem: One USB-C Port Only Works in One Orientation... -
by MichelinManHey guys,
Just purchased a CF-20 (mk1) supposedly was all working. However, the seller had done a fresh install of windows 10 but did not install any driver. Seller was adamant the trackpad/touchpad was working.
The touchpad/trackpad does not work. No led lights near the trackpad. The keyboard works, the USB 2 port on the base does not work, The USB 3 ports will recognise a USB 3 flashdrive but did not recognise a USB mouse. The ethernet port on the keyboard section works.
The USB 3 port on the actual tablet section works with no issues.
... - Loading...
- No more items.
