Need help picking correct capacitor
  • MK89
    • Nov 2014
    • 6
    I have a cheap 32 inch tv that has trouble turning on. It takes 3 or 4 trys to turn it on in the morning.
    I removed the back cover and discover 3 bulging capacitors. There are 2 purple capacitors labled as 680uf 35v with a number CD286C on them, and one green capacitor labeled 1000uf 25 v and a number CD286 on it. Both have a logo that says YST and F6 printed on them. I measured them and the 680uf 35v was 12.5mm Diameter and 22mm tall, and the 1000uf 25v was 10mm Diamter and 20mm tall.
    I looked for replacements and found these on digikey.com.
    http://www.digikey.com/product-detai...2417-ND/613778
    http://www.digikey.com/product-detai...1305-ND/589046
    Will these work?
    Here is a pic.
    • 31254
    Re: Need help picking correct capacitor
    EEUFR1V681
    EEUFR1E102 <<< NOT "L" version on either of these.
    what other caps does it have? specially small ones.
    better to not have to open it again!
    • mntegra01
      • Nov 2014
      • 31
      Originally posted by stj
      EEUFR1V681
      I completely agree. I was only going to replace the larger caps on my TV power supply board because 3 of the large ones had 'popped' But I feel I was convinced to replace all 16 on my PSB from experienced members here.
      If you notice as you are selecting a cap, they have life ratings. So, every cap in your entire system is the exact same age and they could go in a day, a week, or a year later. Better to be safe than sorry. I have realized how dang cheap good caps are, I'm surprised companies actually use inferior quality caps. Is it so that we buy a new TV or AV receiver every couple of years?
      • MK89
        • Nov 2014
        • 6
        So i need two of these.
        http://www.digikey.com/product-detai...514-ND/2504783
        And one of these right?
        http://www.digikey.com/product-detai...?enterprise=44
        So it shouldnt matter if they are not the exact same size (diameter and height) as long as they aren't bigger than the old ones?
        Also I wrote down all of the capacitors on what i assume is the power supply here they are ( the measurements are as close as i could get them )
        2 - 680uf 35v ( above )
        4- 1000uf 25v ( above )
        2 - 470uf 35v 10 mm dia x 17 mm height
        2 - 470uf 25v 7 mm dia x 15 mm height
        1 - 47uf 50v 6 mm dia x 10 mm height
        1 - 22uf 35v 5 mm dia x 11 mm height
        1 - 4.7uf 50v 5 mm dia x 10 mm height
        1 - ( label was on other side and couldnt see) 16mm dia x 30 mm height
        I also wrote down the ones on the other board ( I assume the audio )
        Here are some pics
          Here is the link to the spec of the PANASONIC Caps, just get the size and value you need then type in the PANASONIC part numbers into the search box of Digikey.
          https://www.badcaps.net/forum/showpo...2&postcount=65
          • MK89
            • Nov 2014
            • 6
            Ok I have been looking at the datasheet and I think I have it figured out.
            A question I have though is what does a Y or L at the end of the part number mean.
            Example, what is the difference beside size and endurance.
            EEUFR1E471Y
            EEUFR1E471L
            EEUFR1E471
            Stj said not to get a L version, but the endurance hours are higher on the L and Y. Should I just stick with EEUFR1E471 even though it has the lowest endurance hours?
            • mariushm
              • May 2011
              • 3799
              The one without letters is the default model, which is 10 x 12.5 mm.
              L is 8x20 mm , Y is 8x15 mm ... so the L version is taller.
              Taller means more resilient to temperature, hence the higher temperature rating.
              You have the datasheet here: https://cdn.badcaps-static.com/pdfs/...6eee785988.pdf
              My advice, pick any version you want, whatever is most convenient and suitable. With the lifetime rating these have, you'll replace whatever you fix before these capacitors will fail.
                • 31254
                L are longer, look atthe size of the different ones in mm
                • mariushm
                  • May 2011
                  • 3799
                  Longer or taller, different words, same meaning.
                  • MK89
                    • Nov 2014
                    • 6
                    Thanks for the help everyone I appreciate it.
                    One more question, one of the capacitors i need is out of stock.
                    This one here.
                    http://www.digikey.com/scripts/DkSea...50160248686606
                    Would one of these one be a suitable replacement?
                    http://www.digikey.com/product-detai...884-ND/3563128
                    http://www.digikey.com/product-detai...854-ND/3563091
                    • mntegra01
                      • Nov 2014
                      • 31
                      can always use MFG part number from digikey and buy from Mouser, or buy them here. I bought some of mine from badcaps.net . I should get them in the mail today
                      • MORETTIGIAN
                        Capacitor detached from PCB – RTX 2070 Super Founders Edition
                        by MORETTIGIAN
                        Title:
                        Description:
                        During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                        I did not notice it detaching, so I am unsure of its original location on the PCB.
                        Procedure performed:
                        - Removed backplate
                        - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                        - Reapplied thermal compound
                        - Reassembled card
                        Observed behavior after reassembly:
                        - GPU powers on and operates normally under...
                        09-18-2025, 12:14 PM
                      • Agent24
                        Dick Smith Q-1760 linear power supply filter capacitor question
                        by Agent24
                        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                        It has at least one problem.
                        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                        I have already ordered a replacement potentiometer, so that's not an issue.
                        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                        All are CapXon...
                        10-21-2025, 05:39 PM
                      • chth96
                        If I replace with inferior capacitor, Is it No harm to other IC components at all?
                        by chth96
                        I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                        Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                        It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                        So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                        I know that these capacitor will not last as long as nichicon capacitor...
                        12-22-2023, 04:34 AM
                      • chth96
                        How can I test non-polarized capacitor?
                        by chth96
                        I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                        I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                        And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                        I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                        06-02-2024, 07:31 PM
                      • chth96
                        Is it no harm to replace with capacitor without ripple current rating?
                        by chth96
                        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                        Rubycon YK DataSheet (b...
                        04-19-2024, 05:19 AM
