MSI 945GCM5 V2 Full Poly-mod
  • c_hegge
    • Sep 2009
    • 5219
    I've said before here that I've found MSI boards to be fairly tolerant of being poly-modded, and today, I did another one. A 945CGM5-F V2 to be exact.
    The CPU VRM high got 470uF Nich LG 16V polies, while the low side got 820uF 2.5 OS-CONs.
    The others which originally had 470uF either got that or 330uF as replacements
    There were two 1500uF caps on the RAM VRM which were replaced with 820uF 6.3V Nichicon L8, and there were 3 220uF 10V caps near the chipset which were replaced with 220uF 6.3V NCC PSC.
    Everywhere else (which originally had 1000uF 6.3V lytics) got either 1000uF or 820uF 6.3V Nichicon L8.
    I was quite interested in doing this board as there is what appears to be a linear regulator in the 3rd picture here (in between the CMOS battery and DIMM slot), which gets very hot, and the lone cap immediately above it is usually the first to go on these boards. Hopefully, the poly will handle the heat a bit better.
  • mikail13
    • Aug 2013
    • 93
    • Turkiye
    Re: MSI 945GCM5 V2 Full Poly-mod
    i have msi 945gcm7 board that wasn't start. only 1-2 second fans spins
    after the i have change vrm caps fans spin properly but there is no beep sounds or display.
    what is the problem.
    could i rewrite the bios?
    • TechGeek
      Computer Geek
      • Jan 2015
      • 2254
      Say reflash it? If that, then with an external controller, yes
      If it's a real rewrite, then pretty much no.
      Permanently Retired Systems:
      Kooky and Kool Systems
      sigpic
      • mikail13
        • Aug 2013
        • 93
        • Turkiye
        i mean hot reflash.
        Another healthy mobo starts. we go to bios update screen.
        at that moment we desolder original bios chip and solder patient chip and reflash.
        i've repaired 9 msi g31m3 mobo this way..
        i have many corrupted boards that new or old.
        no needs to greed. i don't pay the thing because of that is new.
        my g31m3 is enough win7 and for me
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Don't know how I missed this thread. Nice one, c_hegge. Looks really good. What were the brands of the original caps?
            • 31144
            why the mix of brands and types?
            • c_hegge
              • Sep 2009
              • 5219
              OST and Teapo, and possibly a few KZGs
              Because that was what I had on hand.
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Were any of the original caps bulging? I'm a big fan of 945 boards, especially well built ones. They're extremely reliable in my experience.
                • c_hegge
                  • Sep 2009
                  • 5219
                  I think they might have still been OK on this particular board, but it was only an old lady who used it, and probably only once every couple of weeks. The cheap sleeve bearing case and PSU fans hadn't even seized
                  • BleedCap
                    • Aug 2015
                    • 30
                    • Malaysia
                    Hello, I'm new here. I've been here for a few days observing and learning little by little. I plan to recap my old dead P4 MSI board with poly in a few months.
                    I want to ask, can we use higher uF poly to replace wet electrolytic cap.
                    For example, using Nichicon L8 6.3V 1200uF to replace 6.3V 1000uF lytic?
                    Thank you.
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      Yes, you can do that. Especially the VRM would benefit from such low ESR caps. However, in my opinion I think that is a waste of money. Poly caps are pretty expensive. You can use 560uF 6.3V to replace 1000uF 6.3V lytics and they will still perform much better.
                      • BleedCap
                        • Aug 2015
                        • 30
                        • Malaysia
                        Thank you for the feedback. Actually I already know that you can use lower uF poly caps in the VRM side, but I still cannot find about replacing higher uF poly caps other than VRM.
                        Yes it's a waste of money. But should there be a situation for example where I don't have lower uF poly to use only a higher uF available, can I still use it?
                        It's just a hypothetical question for a reference in the future.
                        VRM (CPU/RAM):
                        Lower uF poly replacing higher uF lytic = OK
                        Other than VRM:
                        Lower uF poly replacing higher uF lytic = OK or Not?
                        • c_hegge
                          • Sep 2009
                          • 5219
                          What I've been lead to believe is that the half-capacitance when poly-modding rule only applies blanketly to the CPU VRM and other similar DC-DC conversion circuits on the motherboard. I haven't tried it much on the other 1000uF caps on any motherboard.
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            I've used a 330uF poly caps to replace a 1000uF lytics, and never ran into any stability issues even after 18 months.
                              • 31144
                              good, because i want to replace a 3300uf lytic with a 2000uf poly on a motherboard power input.
                              • Boyxba
                                mr
                                • Jul 2016
                                • 25
                                • Greece
                                i have the same mainboard which after psu fail it did not open again . i have put a new psu but the mainboard does not respond . the only think lights its the stand by led nothing else. what shall i check ?
                                • jiroy
                                  • Jun 2016
                                  • 2416
                                  • Lebanon
                                  If you left the mobo for longer than a month or two , and since the 945 is already relatively old , then the first thing to begin with is to check for a failed Cmos battery .
                                  • Pentium4
                                    CapXon Be Gone
                                    • Sep 2011
                                    • 3741
                                    Unplug the 12V power connector. Does the motherboard still not boot up?
                                      MSI 945GZM3 945GCM5 945GZM3-L (MS-7267) Motherboard Schematic
                                      MSI 945GZM3 945GCM5 945GZM3-L (MS-7267) Motherboard Schematic...
                                      10-18-2024, 03:42 AM
                                    • OriginalDaggers
                                      XBox 360 All Polymer Capacitors
                                      by OriginalDaggers
                                      As the title says, Xbox 360 Polymer Capacitors, replacing all on a Kronos 1 revision board.
                                      I went over a thread here (Xbox 360 with blown caps) and gather some extremely useful knowledge!
                                      If I have things right, I can replace them TO
                                      x9 : 1500uF 16V 10x20mm
                                      TO: 470uF Nichicon FPCAP R7
                                      x2 : 820uF 6.3V 8x12mm
                                      TO: 2.5V 820uF Nichicon FPCAP R5
                                      On this revision, there are other 820uF polymer capacitors for GPU/CPU - I'll be replacing those anyway with the above FPCAP R5
                                      What's a good replacement for the smaller...
                                      This can be anything from game consoles to arcade games to anything else that doesn't really fit into any of the above categories. When starting a new thread, please put the make AND model of your device in the thread title. Also be VERY descriptive of your issue, that way you'll get the best answer possible!
                                      02-20-2024, 12:49 PM
                                    • Alfieh
                                      NAD C320BEE repair possibly bad capacitors
                                      by Alfieh
                                      hey Im very new to repairing electronics with capacitors as well as using a multimeter so I need so help/guidance fixing this issue
                                      recently I was handed a family members old NAD C320BEE that they had in their loft for storage for a few years but when powered on it went into power safety mode due to a problem on the protection circuit somewhere before it went into storage I was told it worked fine I found lots of people online talking about how the capasitors are known to be pretty bad in this model and can cause this issue the only problem being I don't have much experience sorting...
                                      11-19-2024, 04:55 PM
                                    • usernameunknown
                                      ASUS P4P800SE/P4C800-E recap (polymod?)
                                      by usernameunknown
                                      I have two P4P800SEs, a P4C800-E Deluxe and all three boards show the same issue: difficulty POSTing (getting stuck on POST code 0D), or crashing under light load (but bizarrely, the P4C800-E is rock solid running Prime95 with a water cooled 4.3 GHz Pentium 4 3.4)
                                      Should I consider recapping the boards? If so, what caps do I need? Is polymodding these boards worth it?
                                      Do note I have never recapped a board myself, nor do I own good soldering equipment to do so.
                                      08-20-2024, 11:02 AM
                                    • burom
                                      Xbox 360 Xenon Modern Capacitor Replacements
                                      by burom
                                      I found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
                                      I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have...
                                      06-07-2024, 05:10 PM
