Trying Win 10 Install Preview!
  • ivtec
    • Dec 2008
    • 1967
    Hi guys; Today it came to my mind,why not to try to install Win 10 Preview on my Hp DV-6 1259DX, nothing to loose,
    So i removed the original 500BG HDD with Win7 Home Premium installed,and replaced it with an HDD 250GB that i had in my scrap.
    First i went to the same site where i downloaded Win Vista ISO for the other laptop HP-DV-5,and downloaded Win 7 Home Premium Iso and burned Image to a DVD-RW and installed it,i had no problems, everything installed and updated OK automatically accepted the activation key,o i went to the site for win 10 upgrade Preview and registered and started to download win 10 preview build 9926,at first it gave me some errors that failed upgrade to Win 10 Preview build 9926,these are the codes i came across.
    code;800401fd,802400b,80240055, i checked with Microsoft, what were those errors and how to fix, learned if i had error codes to try Dr Fix it, i did run Dr fix it, and afters a few tries to upgrade,rebooted and tried upgrade one more time, now the Upgrade started and installed and now everything is running smooth so far nothing to point out,installed Google Chrome and now i'm set,
    When i boot to desktop it gives me the choice of Win 10 preview and Rollback
    i don't know what that means is it I can go back to win7?
    Here's a pic attach of the desktop.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Trying Win 10 Install Preview!
    I wouldn't roll back unless your Windoes 7 iso has come feom a quality source.
    • ivtec
      • Dec 2008
      • 1967
      I don't care about the source quality, as long Win 7 works good without problems .
      • diif
        • Feb 2014
        • 6978
        • England
        When there are legitimate sources online for Windows 7 you should care.
        It might be working correctly for you but there's a very big chance its been meddled with and your system is compromised.
        • diif
          • Feb 2014
          • 6978
          • England
          http://answers.microsoft.com/en-us/w...f-662b56ef408c
          Has links to all of the digital river Windows 7 downloads with SHA1 checksums to verify.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            ^ or http://forum.notebookreview.com/wind...languages.html
            these have SP1 in them too! If you need SLP/SLIC, swap the cerificates and enter the corresponding key when activating (what I do, anyway) after the install.
            sigpic
            (Insert witty quote here)
            • ivtec
              • Dec 2008
              • 1967
              So far Win 10 Preview is working great from Win 7 upgrade from the suspect ISO,and hope it will keep that way,if not it will just take me 2 minutes to swap HDD to the original Win 7.
              Also can you tell me please what is the difference between Win 10 preview build 9926 and
              Current previews of Windows 10 such as Windows 10 Technical Preview build 9841, 9860, 9879 that will all expire April 15th 2015.thanks
              • mockingbird
                • Dec 2008
                • 5488
                I might have to give Win10 a try just for the new IE hardware acceleration in win8+. My mobile GPU is starting to lag a little.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16959
                  atleast theres a start menu and a classic looking desktop interface. If it was tiles and metro, its going to be another MS stillborn downs syndrome baby.
                  <--- Badcaps.net Founder
                  Badcaps.net Services:
                  Motherboard Repair Services
                  http://folding.stanford.edu/
                  Team : 49813
                  Join in!!
                  Team Stats
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    if you screen is smaller than 8in then you got tiles!
                    Follow the white rabbit.
                    • mockingbird
                      • Dec 2008
                      • 5488
                      My thoughts exactly. Free performance boost for doing nothing is great, especially on a laptop where it is so sorely needed. Only caveat is I have to say goodbye to SLIC activation and use AutoKMS.
                      Here's a tip. Go to the Microsoft section in Task Scheduler and disable a lot of useless Microsoft events that do nothing but bog down the system.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        By default? Or is it "locked"?
                        sigpic
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5091
                          • New Zealand
                          So when you have a small screen, it wastes more space on huge tiles?
                          -David VanHorn
                          • goontron
                            5000!
                            • Dec 2011
                            • 4108
                            • US
                            not sure, they didn't say.
                              • 31285
                              will all the spyware be removed in the "release" version?
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5091
                                • New Zealand
                                Apparently, but why should we believe that?
                                -David VanHorn
                                  • 31285
                                  we shouldnt, i'm just reminding noobs that it's there.
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    From the EULA
                                    When you acquire, install and use the Program, Microsoft collects information about you, your devices, applications and networks, and your use of those devices, applications and networks. Examples of data we collect include your name, email address, preferences and interests; browsing, search and file history; phone call and SMS data; device configuration and sensor data; and application usage. For example, when you:
                                    install the Program, we may collect information about your device and applications and use it for purposes such as determining or improving compatibility,
                                    use voice input features like speech-to-text, we may collect voice information and use it for purposes such as improving speech processing,
                                    open a file, we may collect information about the file, the application used to open the file, and how long it takes any use it for purposes such as improving performance,
                                    or enter text, we may collect typed characters and use them for purposes such as improving autocomplete and spellcheck features.
                                      • 31285
                                      well if the font is big enough it should boost the number of Linux users.
                                      • ivtec
                                        • Dec 2008
                                        • 1967
                                        For the spy thing,believe it or not it is everywhere,and no way to avoid it, as long you use any kind of tech this days connected to the internet, if you don't want to be spied on, just don't go in the Internet, don't use phones and so on,that's the risks one takes,besides
                                        with me i don't care , have nothing to hide,i don't have nothing in my computer that is any good for spy's,only use web for surfing web and streaming,don't keep bank accounts in my Pcs,i'm more worried about damn adds and virus and malware, that can destroy my computer's health,the rest is bull that one has to leave with,you may take some steps to minimizing the spy thing but that costs money and is not bullet prove,nobody is safe as long you want to benefit from the tech.
                                        • japlytic
                                          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                                          by japlytic
                                          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                                          Tried (only with keyboard/mouse connected):
                                          • BIOS + database update
                                          • Using latest Windows 11 image built with official image creation tool
                                          • Previous setup version for Windows 11 installer
                                          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                                          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                                          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                                          06-19-2025, 04:59 PM
                                        • 24gsm
                                          MacBook Pro A1708 install macos fail
                                          by 24gsm
                                          hi to all
                                          i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                                          after enter to recovery and format hdd 1to .
                                          after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                                          can help please
                                          Serial Number: FVFXP0U0HV2J
                                          Config Code: HV2J
                                          Find My Mac: OFF
                                          04-16-2025, 03:57 AM
                                        • duwane
                                          A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                                          by duwane
                                          Hi All.
                                          Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                                          The issue:
                                          Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                                          10-26-2022, 07:02 AM
                                        • eccerr0r
                                          win7 home iso? can I get 10?
                                          by eccerr0r
                                          Well I think that I have a GTX660Ti that's dead but I think I should give it one last try with its original OS and drivers: win7 home premium. While I can't stomach using win* of any type (I'm 100% Linux these days) I think I have to give benefit of the doubt to drivers, etc.
                                          So... I have the original CoA for Win7 home premium and it's an OEM license. And I have the whole computer that the GTX660Ti came in (it was reportedly working too), minus the original hard drive, what could I download and run the machine temporarily to verify the GTX660Ti works with Windows or not?
                                          09-14-2023, 07:35 AM
                                        • chappers
                                          Nvidia MATS help please - 33 errors on two cards?
                                          by chappers
                                          I'm new to MATS and can only use it after watching a Youtube video, downloading the one he linked to (version 400.184) and running it without changing anything. I have no great understanding of it.
                                          I have 3 graphics cards in the house.
                                          My son's - Palit GTX 1080 used for 3D games constantly.
                                          Mine - Nvidia GTX 1080 not used for 3D games, just basic stuff.
                                          Inno3D RTX 2080 I bought faulty hoping to repair for my son's PC.
                                          Running MATS on my son's GTX 1080 gives a pass with no errors.
                                          Running MATS on my GTX 1080 gives...
                                          08-09-2023, 01:28 PM
