Setting up a network
  • Hondaman
    • Sep 2008
    • 1089
    Recently I discovered that I can stream media (.MPG, .MP3) from my Win 7 Pro machine to my Blu-Ray player (Panasonic DMP-BDT 500). Then I thought about setting up a dedicated media server. Possibly running XBMC/Kodi. AFAIK, this media server would appear as another drive letter to Windows, and another DLNA server to the Panny. Windows Media Player would probably add directory locations to the "libraries" that WMP sets up.
    Could this media server be headless most of the time? Where can I find resources on remote management that won't be too confusing? Trust me, it's easier to "overload my brain" than you might think.
    I remember the paper manuals I had for Borland Pascal for MS-DOS. They were trying to introduce many concepts in only a few pages, and I didn't have an overview of Pascal yet. So I didn't know that I didn't need advanced features for the simple program I wanted to write.
    Basically, any computer (and the Panny) should be able to view any shared directory, and play the media. Files can be deleted only on the local machine, unless remote access is set up. I'm using a mixture of wired and wireless computers, with a 4-port name-brand router.
    Would Ubuntu be a good choice here? I've played around with setting up a file server with Ubuntu a few years ago. Perhaps if the media server is mostly headless, it doesn't need a fancy GUI.
    I hate to admit my ignorance, and I don't want to get flamed. I'm smart, but easily overloaded. Any help would be greatly appreciated, flames would not.
    (Hopefully soon I will have more test-bed PCs coming online. Finding the time to play around with them will be hard though.)
    Thanks!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Setting up a network
    Depending on how many concurrent users you want accessing the media perhaps you could get away with using your current pc and think about upgrading depending on the bottleneck.
    If you have a spare machine there is Kodibuntu.
    Also to consider instead of using the panny (it may have media restriction issues?) there are pre built android media boxes that act more like smart tvs. I hear some come with access to films and other premium stuff, or a raspberry pi.
    Depends on budget I guess.
      • 31246
      some routers have a usb port that can network-share usb-media such as harddrives.
      they dont tell you this in the documentation - you have to try it.
      • diif
        • Feb 2014
        • 6978
        • England
        I have £20 media box. HDMI out USB and Cf slot, plays every format i sling at it, and 1080 too.
        • wannagofast83
          • Apr 2015
          • 6
          Check out Plex. It supports DLNA and also has a app for almost every platform. It has a paid for version which unlocks extra features and a free version. It is outstanding!
          https://plex.tv/features
          It can run on Windows, OSX, and linux and even a NAS.
          http://www.engadget.com/2013/02/14/s...x-environment/
          • wannagofast83
            • Apr 2015
            • 6
            It also has a really easy to use web interface to manage media.
            • omega
              Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
              by omega
              Hello all,
              as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
              Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
              02-09-2024, 03:34 PM
            • howardc64
              Samsung UN55JU650DF network/streaming problem
              by howardc64
              Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
              This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
              07-09-2025, 12:44 PM
            • davg
              Home network connection problem
              by davg
              I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
              03-06-2021, 07:13 AM
            • japlytic
              Maximum speed should be marked on network ports
              by japlytic
              I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
              One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
              12-19-2024, 05:04 PM
              HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
              This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
              09-06-2024, 11:39 AM
