Anker 71an7105 Usb power adapter - blown fuses
  • clearchris
    • Dec 2013
    • 687
    These are great little power supplies, except that are known for blowing fuses. The newer model has resettable fuses, so after 3 blown fuses, it was time...
    Original with fuses:
    After adding resettable fuses:
    Not the prettiest, but considering the size of the new fuses vs the old ones, not too bad really. Each port is rated for up to 2.5a, I chose a 1.6a resettable fuse that throws at about 3a.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Anker 71an7105 Usb power adapter - blown fuses
    Nice fix!
    By the way, what brand caps are in the PSU? Could we maybe get a pic of the topside of the board?
    -Ben
    Muh-soggy-knee
    • clearchris
      • Dec 2013
      • 687
      You got it.
      Top, bottom.and close ups of caps.
        Great Sage é½Šå¤©å¤§č–
        • 31139
        you need to resolder the bridge rectifier & power inlet.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Wow, that is better than I expected! They even used polymer caps!
          Muh-soggy-knee
          • clearchris
            • Dec 2013
            • 687
            sti: Is that because they are a little light on solder or do you see something else?
            ben7: Yeah, aside from the fuses, it's not a bad device. I was surprised to see what appears to be polymer caps as well. These came pretty cheap too, on sale for like 15$ or so. They do up to 8A across 5 ports with 2.5a max from any 2 ports at a time.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              nice ring cracks.
                • 31139
                Originally posted by kc8adu
                nice ring cracks.
                exactly, the solder is cracked.
                • clearchris
                  • Dec 2013
                  • 687
                  Hmm, thanks for the heads up. I took a closer look and couldnt tell if they were cracks or some kind of residue . There were certainly rings of some sort. I removed the lead free solder and used some 63/37 instead. Nice and shiny now.
                  • clearchris
                    • Dec 2013
                    • 687
                    Newer version of the power adapter.
                    This version seems constructed for easy replacement of fuses, the board has more room for the fuses (still not resetable) and the board has slots underneath the fuses so its a lot harder to solder it in wrong. The solder on the board is a different alloy, it requires a LOT more heat to melt.
                    Resetable fuses soldered in:
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      Nice! Now they should use a synchronous rectifier on the output :P
                      Muh-soggy-knee
                      • airsky98
                        • Sep 2015
                        • 1
                        • Singapore
                        what part number should i buy for the resettable fuse ? i have one lying around, got it from HK last year, too troublesome to get it fix.
                        • clearchris
                          • Dec 2013
                          • 687
                          Sorry, didn't see the reply. Probably late, but here's what I bought.
                          Digikey:
                          652-MF-NSMF150-2
                          MFG Part No:MF-NSMF150-2
                          MF-NSMF150-2
                          Bourns Resettable Fuses - PPTC
                          US HTS:8533290000 ECCN:EAR99 COO:CN
                            Surface Mount Fuses Fundamentals Datasheet
                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                            10-07-2024, 06:07 AM
                          • MrzPdlch
                            Blown fuses on Gigabyte GTX 980TI 6GB
                            by MrzPdlch
                            Hey everyone,
                            I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                            Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                            Find some pictures of the actual GPU together with a picture of how it should look like.
                            I also wonder whther it might be a problem that there...
                            03-10-2024, 04:14 PM
                          • BMCappelletti
                            Sonos Play 1 with blown cap and fuses
                            by BMCappelletti
                            Hi there.
                            I was given a Sonos Play 1 (yeah, very old) that does not turn on.
                            Checking the main board, I can see a blown cap, that connects to two blown fuses. Right by the LAN port.
                            Where should I start looking for the main fault?
                            Thank you....
                            08-10-2023, 04:02 PM
                          • gozotto
                            Sharp LC-40LE812E fuses blown
                            by gozotto
                            I repaired a Sharp LC-40LE812E TV with the main power board DPS-126CP B.
                            All fuses blown and the capacitor C7813 (220pF 1KV) was cracked. After replacing both, the TV works again without any problems. After 2 weeks the same problem apears with the same symptoms. What can the C7813 blown again and again? The schematic can be found here.
                            Thanks in Advance
                            gozotto
                            04-04-2022, 12:14 PM
                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                            by sam_sam_sam
                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                            12-14-2023, 07:45 PM
