Asus X102ba bios dump.. need..
  • ry x hunter
    • Jun 2013
    • 184
    • philippines
    hello guys i need help to find bios dump for my asus x102ba netbook..
    thanks..
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: Asus X102ba bios dump.. need..
    try
    • dj_ricoh
      • 2073
      • uk
      whats wrong with it mate?
      • ry x hunter
        • Jun 2013
        • 184
        • philippines
        the monitor goes blank
        • josuemcp
          • Feb 2012
          • 2
          Show...
          Thanks.....
          • youssef_57
            • Apr 2017
            • 13
            • egypt
            thank you
            • alas3376
              • Nov 2011
              • 382
              • BENIN
              hi
              need ec dump for this
              thank you
              • peste
                • Dec 2016
                • 13865
                • ROMANIA
                Originally posted by alas3376
                hi
                thank you
                try..
                • alas3376
                  • Nov 2011
                  • 382
                  • BENIN
                  Originally posted by peste
                  try..
                  thant you
                  • chemseddine
                    • Jul 2017
                    • 34
                    • algeria
                    thankssssssssss
                    • MasterEd
                      • Oct 2020
                      • 4
                      • Philippines
                      X102ba rev 2.0 need bios dunp working thankyou
                      • peste
                        • Dec 2016
                        • 13865
                        • ROMANIA
                        try post#2
                        • mkdj
                          ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                          by mkdj
                          Dear all,
                          I have a ASUS ZenBook UX480F with the following symptoms:
                          I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                          I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                          10-19-2025, 04:41 AM
                        • razor_amd
                          [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
                          by razor_amd
                          With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
                          For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
                          I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
                          This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
                          12-15-2020, 07:07 PM
                        • pirati
                          by pirati
                          10-27-2025, 04:20 PM
                        • DynaxSC
                          Need real mobo dump of BIOS v402 for ASUS PRIME Z590-A - stock image no help
                          by DynaxSC
                          I have a serious problem to program the Z590 chipset SRAM with a Management Engine after replacing the chipset.
                          The new chipset is factory new and is not containing any Management Engine. Any attempts to program it into the chipset under Windows ends with a failure (eg. Error 20: Management Engine Device not present, or something similar).
                          Due to the lack of the ME several ports on the board, including all M.2 ports aren't working, booting OS works only on USB. So it's now other way, as to program the chipset with a ME.
                          Usually on ASUS boards it worked...
                          06-14-2024, 03:49 PM
                        • Ahari
                          by Ahari
                          I...
                          08-13-2025, 06:12 AM
