Bob Parker's Blue ESR Meter Assembly & Comments
  • Krankshaft
    • Jan 2007
    • 2328
    Well I finally broke down and purchased an ESR meter and thanks to the posts here the Blue meter was the right choice for me.
    It's cool looking blue displays and low dropout regulator won me over.
    Another thing that these kits finally have is a battery cover for the 9 volt battery. So replacement doesn't need tools. That alone was reason enough for me to buy this meter.
    I have read a few posts about the Dick Smith meters screws getting worn out from battery replacement.
    I had a couple of issues during assembly and no I'm not talking about solder bridges.
    I will admit I was pretty tired during assembly and wasn't running on all fours if you know what I mean . But I think that these mistakes that held me up can happen to others.
    I've decided to share my assembly experience so that others can get this meter up and running with less head scratching.
    This is by no means the first time I've assembled a kit I have assembled many kits and they've all worked the first time.
    Okay so let's get on with how the kit was shipped to me.
    It came in a little white box from Anatek with foam wrapped around it for protection.
    When unpacked this is what I had:
    See attached picture 1:
    Here is a picture of the unassembled PCB:
    See attached picture 2:
    Please note that the probe ends in the large bag above WERE NOT included. I had to buy them for $10.00 a set. I purchased both the alligator clips and the standard multimeter probes.
    This is my first gripe about this kit there were NO probe ends included.
    This really disappointed me especially since NO WHERE on the Anatek site did it say that you needed to buy them separately.
    Not only that if you assembled the kit to realize this later you couldn't test the resistor to calibrate the meter (more on that later).
    So make sure that you get yourself a set of them. You Dick Smith guys were better off and had probes included.
    The next issue I had was there was no printed manual you can view the manual before purchasing on Anatek's site and they e-mail it to you after your purchase.
    This was a disappointment but no real issue.
    So all of those things aside lets get into kit assembly.
    The first thing that striked me as odd is on the silk screened PCB there were no component designation numbers like I'm used to (R25, C12, etc). There were only part values (220R, 27K, etc).
    While I'm sure that the intention of this was to make assembly easier it can also lead you astray. For example there are a couple of 1% resistors on the board with the same values as 5% resistors so in actuality you could place a 1% resistor where a 5% resistor was made to go and vice versa.
    The easy way to make sure you don't slip up is to look at a picture of the board with the component designation numbers on it in the manual. Then flip a page forward to see a picture of the board with the component values on it and make sure that the number of the component matches up with the component value.
    Personally I think it would have been alot easier with component designation numbers silk screened on the board.
    Moving on the next problem I had was with the 2 variable POTs included with the kit one was labeled 102 and the other 103. Unfortunately in the manual they were only referred to as a 10K trim POT and a 220 ohm trim POT. Simply measuring with my DMM with the POT turned in one direction solved that easily.
    But again a simple revision to the manual stating that 103 is 10K and 102 is 220 will prevent any POT mix up entirely.
    The rest of the assembly went easily the caps on this meter (unlike the EVB Portuguese meter that used bad Lelon caps) were Nichicon with 1 Panasonic in the mix. So you're using good caps to find bad caps and not the other way around .
    I decided to use some Panasonic FCs instead of the included caps and a Panasonic SU for the bipolar cap I placed a dab of hot glue under it so it stays firmly bent over. I also upgraded the SU Bipolar cap to 47uf from the stock 22uf the Dick Smith kits used 47uf and the Blue manual said that it was acceptable as well.
    Another thing left out of this kit that was included in the Dick Smith kits was IC sockets for the shift register and the microcontroller.
    While I don't hope to ever need to use them it's always a nice option to have in case the worst does happen.
    So a trip to Ratshack and I picked up 1 18 Pin socket (for the microcontroller) and one 16 pin socket (for the shift register) for just over 2 bucks.
    So I finish assembly and everything looks good so I decided for the heck of it to run the microcontroller diagnostics to check my assembly.
    So I make sure that VR1 is set to the center then make sure that R30 is bridged (this bypasses the voltage regulator I believe) and hold the power on button and F2 flashes on the screen.
    So I look up what it means and I chase ghosts for about an hour thinking I did something wrong. Until I decide to read the directions more carefully.
    They say in a nutshell that you can't use a 9 volt battery for this test and that the input voltage must be between 6.2 and 6.8 volts.
    Not having a truly variable bench supply I set my fixed variable supply with a rotary switch to 7.5 volts and ran the diagnosis again thankfully .8.8 appeared on the display which meant everything was fine.
    This mess up was all me and of course wasn't anyone's fault but mine but it's a good thing to remember if you want to use this function.
    The next step was to calibrate the meter for this purpose they included an 82 ohm 1% resistor calibration is easy simply zero out the probes and test the resistor then adjust VR2 until the meter reads 82.
    Take your time on this and make sure that you zero out the probes well. To test your calibration shut the meter down and power it back up zero out the probes again and test the resistor it should still read 82 ohms.
    Okay now let's get into the hazy part of the manual labeled "Battery Warning Setup".
    The point of this circuit is to trigger a flashing b on the display and dim the display to conserve power when the output from the 9 volt battery drops to 5.5 volts (the regulators dropout voltage).
    Of course as you've read above I don't have a truly variable bench supply and 5.5 volts isn't exactly a standard output voltage.
    So I build the little voltage regulator circuit pictured in the manual.
    Sadly the components for this circuit weren't included but can all be found at Ratshack. I happened to have the components in that huge mess which is my parts drawer.
    See attached picture 3:
    I used an NTE123AP that I had on hand which was a sub for a common NPN 2N3904.
    It is VERY IMPORTANT that you adjust this circuit while the meter is running if no load is being placed on the battery the input voltage will be off.
    I soldered the output leads from the regulator circuit to the PCB while leaving the included battery clip installed then I simply connected the battery to the little circuit.
    I then placed my probes on the other battery clip so that I could measure the regulators output with one hand and adjust the regulators pot for 5.5 volts with the other.
    Now onto the actual calibration I had my next issue when the meter was powered on the low battery indicator started flashing I then attempted to turn the adjusting POT clockwise and the indicator didn't go off. Turning the POT to both extremes didn't shut it off.
    Puzzled I turn the POT fully clockwise and turned the meter off then on and the indicator turned off. I then turned the POT counter clockwise and the b indicator came on I then turned the POT clockwise again.
    You would think that this will turn the indicator off.
    However this is untrue the manual neglected to mention that the low battery indicator is a latching circuit in other words once it comes on the only way to shut the indicator down is to power the meter off then on.
    This makes sense to design the circuit this way since it would prevent the indicator from flickering on and off if the battery was jumping back and fourth past the threshold voltage.
    While this was again a misinterpretation on my part and the manual clearly stated turn the pot fully clockwise then turn it counter clockwise until the indicator comes on it not fully explaining why lead to some confusion.
    The assembled kit board:
    See attached picture 4:
    The fully assembled kit:
    See attached picture 5:
    I also put on some clear feet so that it won't skid all over my bench and so I don't elbow it onto the cement floor .
    See attached picture 6:
    Overall after assembly this meter is every bit as good as the Dick Smith kits with some extras like the battery cover and the more efficient blue displays.
    I am very pleased with this meter and it's a great option for those of you who haven't been able to grab the quickly vanishing Dick Smith kit.
  • zeus
    • Dec 2007
    • 16
    Re: Bob Parker's Blue ESR Meter Assembly & Comments
    ROTFL!!! I think I found my long distance (Type A) twin. Looking at the pics,
    I saw you did all the anal crap I did:
    - Tolerance bands on resistors are all down and to the right.
    - All transistors are straight as an arrow, and probably the same height.
    - Caps are all facing in a way that you can read them.
    - HERE's THE BIG ONE; going over to $hit Shack and buying dip sockets.
    I love it!
    The only thing I did different is cutting off the banana end and soldering small
    alligator clips to the leads. I just couldn't see spending another $10 on cheap
    test lead ends. My little mod works great, when I touch the clips together the
    meter reads 0.03 before I zero it out.
    BTW Krankshaft, your PCB board looks great. LOL!
    Take care; brother from another mother.
    • Agent24
      I see dead caps
      • Oct 2007
      • 4996
      • New Zealand
      I am thinking of buying one of these kits myself, would you recommend it?
      -David VanHorn
      • Krankshaft
        • Jan 2007
        • 2328
        Holy ancient post Batman!!!
        Yes I would it's saved my ass more than once sniffing out tons of bad caps in TVs. Including 85C Rubycon's that looks completely fine.
        If you're serious about servicing and you want to save time it's a must.
        • PlainBill
          • Feb 2009
          • 7034
          To me, it's a toss up. I have one of these meters, and it does it's job quite well. But I've been looking fondly at the ESR 3.1 Micro in this thread.
          PlainBill
          • Krankshaft
            • Jan 2007
            • 2328
            That meter may not have autoranging and that's a major negative for me.
            Next to the testing socket it's labeled 1, 10, and 100 I think those are measuring ranges for ESR.
            • Huckfinn
              • Jan 2009
              • 43
              By the way, if any of you are currently getting a Bob Parker Blue ESR meter kit and also want to have the satisfaction of assembling it to the max level of "perfection", use the info Krankshaft gave you and also consider adding my mod. I also used sockets for the two IC units as well as the display and the blue discrete leds that make the decimal points, but I upgraded the socket from the standard side wipe Kovar metal style to machined contact gold plated style for reliability. The two brands that work well are the old Augat [might still be available or no] and the current Mill-Max brand. I just bought single long socket strips that can be cut [broken with care] to the right length from the strip, one row at a time. And since winter is coming up, [USA] it might be a good idea to get and use a grounded anti-static mat and wrist strap when handling the IC units and the displays. A 3M mat works well, and so does the one Radio Shack sells.
              Huck
              • sds
                • Jul 2010
                • 2
                Thank you for Imformation.
                • Bob Parker
                  Technician
                  • Feb 2007
                  • 182
                  Yeah, thanks for all that! I think that somehow I've missed ever seeing this thread before now.
                  It is a good shrubbery. I like the laurels particularly...
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    Haha what can I say? The first kits I built were FM transmitters where you want the components as close to the board as possible. Especially in the RF circuits guess that mentality never wore off.
                    • bedford_repairs
                      • May 2010
                      • 6
                      Ive purchased the meter and after i finished assembly and im having an issue with the right side LED and Display lighting up.
                      I looked over a few posts for trouble shooting and the only thing i could come up with is IC3 may have been bad but i since replaced the IC and i am getting the same results.
                      Any ideas?? Here are some pictures of the front, back and the display.
                      Any input would be greatly appreciated.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4996
                        • New Zealand
                        If the 4094 was OK, I would check transistor Q13 which switches DISP2 and LED2.
                        -David VanHorn
                        • Bob Parker
                          Technician
                          • Feb 2007
                          • 182
                          Thanks for the detailed photos. I'll have a careful look at them and see if I can see what's causing this problem, and get back to you.
                          • Bob Parker
                            Technician
                            • Feb 2007
                            • 182
                            Stupid message board. I wrote out a detailed description of what to check, and then it wouldn't let me make an edit so I've lost it all.
                            OK, to summarise.... please resolder Q12's (2N3904) leads and R27's (4.7K) leads. All the solder joints should be smooth and shiny, and those connections in particular don't look like that in the photo.
                            Good luck.
                            • bedford_repairs
                              • May 2010
                              • 6
                              I appreciate the quick responses.
                              Agent 24:
                              Thank you for the information. I did first check continuity on the Q13 transistor and all checks out. I then removed it and checked the transistor to test it w my multimeter, guess this is where im a bit green. I know the transistor is a NPN and i looked up the data sheet and see pin 1 is the Collector, pin 2 is the Base and pin 3 the Emitter. So my question is what reading should i see on the meter as this is a switching transistor to verify if it is working properly?
                              Mr. Parker they came from my phone so i hope they show enough detail. If there is anything else you need information on or pictures of i will gladly post them ASAP.
                              Thank You both again for your time.
                              • bedford_repairs
                                • May 2010
                                • 6
                                Good luck.
                                Thanks Bob i will do that and let you know how it goes! Sorry about the message board screwing up on you, now im curious to what you had to say! Always open to learning about this. Ill let you all know soon.
                                • Bob Parker
                                  Technician
                                  • Feb 2007
                                  • 182
                                  Howdy again.
                                  I'm so buried in emails right now, that I don't exactly remember what I wrote in detail.
                                  For your info, it's exceptionally rare to encounter a defective transistor. You're about as likely to win the lottery as find one.
                                  The big killers of the ESR meter kits are (1) Soldering defects especially dry joints and to a lesser extent solder whiskers/bridges, and (2) Components in the wrong place. You would not believe how many people put the 220 ohm and 220K ohm resistors in the reversed places.
                                  Your phone photos are pretty good. Good enough to easily see all the component values and the general condition of the underside of the board. Thanks but for now I don't think I need photos any better than that.
                                  Also for your info, I've attached a photo of the back of a Blue meter board to show how the solder joints should look. I hope all this is of some kind of help.
                                  • Krankshaft
                                    • Jan 2007
                                    • 2328
                                    I'd say whiskers are more of a problem with lead free solder.
                                    Even manufacturers had a lot of problems with whiskers when the lead free ROHS craze started. Surface mount IC pin spacing doesn't leave much room for errors.
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4996
                                      • New Zealand
                                      Good luck.
                                      I thought that it would be Q13 that would be in question? Maybe I don't understand how the circuit works...
                                      Can you tell me why you would check Q12 in this case?
                                      -David VanHorn
                                      • Toasty
                                        • Jul 2007
                                        • 4171
                                        Your pictures are of...
                                        Leads shorted together?
                                        Leads not shorted?
                                        Swap the displays, verify operation of other.
                                        Decimal point LED in correctly? Does it even flash when leads are shorted?
                                        Do you get the ( - ) sign in left display without leads shorted?
                                        Toast
                                        veritas odium parit
                                        • chth96
                                          Is it possible to test small ceramic disc capacitor with analogue meter?
                                          by chth96
                                          I read EBOOK of Testing Electronic Component and found that
                                          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                          Is it really possible to test small ceramic disc capacitor with analogue...
                                          03-09-2024, 10:03 PM
                                          Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                          by sam_sam_sam
                                          I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                          I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                          12-31-2023, 06:04 AM
                                        • jorpec
                                          Changing the scale of an analog meter
                                          by jorpec
                                          Hi
                                          I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                          I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                          Thnaks
                                          01-23-2023, 10:37 AM
                                          How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                          by sam_sam_sam
                                          About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                          Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                          12-14-2023, 07:45 PM
                                        • Stephan Mathers
                                          EDMI ATLAS MK10 Electronic Meter Discussion
                                          by Stephan Mathers
                                          Greetings, new guy here but always interested in the crazy universe of modding
                                          We just finished construction of around 25 vacation houses, all inside the same private area.
                                          Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                                          The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                                          Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                                          05-20-2025, 09:09 AM
