Preface: I know these walmart black friday tv's are real piles of crap..
Emerson LF501EM5F LED TV
As soon as it's plugged in (to mains) it starts to "chirp" at around 2 second intervals repeatedly and will not power on.
Took the cover off and it seems to be originating in or around the bottom right transformer. I believe I tested all the diodes I could find, including the surface mount ones on the back and any that were 0.3v or lower I removed and retested, but they all seem good. Same with the mosfets. The main filter cap has ~160vdc when it's plugged in, but the 6 output pins on the left side of the board all show fluctuating random voltages. Also I'm not sure what they're supposed to be because it's not marked anywhere that I've seen. The 3 caps near those output pins are all 100v caps so am I right to assume they're probably supposed to be higher than 12v or 24v? I don't know anything about LED tv's or their driver circuits. I haven't replaced any components yet. Any help, guidance, or a hyperlink toward some would be greatly appreciated. Thank you!
