Win7 updates for upgrading to Win10
This is a sticky topic.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    The following is a list I have compiled of updates pushed for the seamless upgrade from Windows 7 SP1 to Windows 10.
    The list has two uses, either you want the free upgrade to Windows 10 and then it confirms what updates you need to have installed.
    Or maybe you prefer Windows 7 SP1 or you have a company computer where you want to restrict the upgrade to Windows 10.
    In the latter cases you should untick the checkbox "Give me recommended updates the same way I receive important updates" in Windows Update.
    Follow this link for a post with more details with pictures of that setting.
    Code:
    [URL="https://support.microsoft.com/en-us/kb/2952664"]KB2952664[/URL] Compatibility update for upgrading Windows 7
    [URL="https://support.microsoft.com/en-us/kb/2990214"]KB2990214[/URL] Update that enables you to upgrade from Windows 7 to a later version of Windows
    [URL="https://support.microsoft.com/en-us/kb/3021917"]KB3021917[/URL] Update to Windows 7 SP1 for performance improvements (Telemetry)
    [URL="https://support.microsoft.com/en-us/kb/3035583"]KB3035583[/URL] Update installs Get Windows 10 app in Windows 8.1 and Windows 7 SP1 (GWX.exe)
    [URL="https://support.microsoft.com/en-us/kb/3068708"]KB3068708[/URL] Update for customer experience and diagnostic telemetry (Replaces: [URL="https://support.microsoft.com/en-us/kb/3022345"]KB3022345[/URL])
    [URL="https://support.microsoft.com/en-us/kb/3075249"]KB3075249[/URL] Update that adds telemetry points to consent.exe in Windows 8.1 and Windows 7
    [URL="https://support.microsoft.com/en-us/kb/3080149"]KB3080149[/URL] Update for customer experience and diagnostic telemetry
    [URL="https://support.microsoft.com/en-us/kb/3123862"]KB3123862[/URL] Updated capabilities to upgrade Windows 8.1 and Windows 7
    [URL=""https://support.microsoft.com/en-us/kb/3123862"]KB3173040[/URL] Windows 8.1 and Windows 7 SP1 end of free upgrade offer notification
    Code:
    [URL=https://support.microsoft.com/en-us/kb/3161647]KB3161647[/URL] Windows Update Client for Windows 7 and Windows Server 2008 R2: June 2016 (Replaces: [URL=https://support.microsoft.com/en-us/kb/3138612]KB3138612[/URL] [URL=https://support.microsoft.com/en-us/kb/3135445]KB3135445[/URL] [URL="https://support.microsoft.com/en-us/kb/3112343"]KB3112343[/URL] [URL=https://support.microsoft.com/en-us/kb/3083710]KB3083710[/URL] [URL="https://support.microsoft.com/en-us/kb/3083324"]KB3083324[/URL] [URL="https://support.microsoft.com/en-us/kb/3075851"]KB3075851[/URL] [URL="https://support.microsoft.com/en-us/kb/3065987"]KB3065987[/URL] & [URL="https://support.microsoft.com/en-us/kb/3050265"]KB3050265[/URL])
    This last update adds the ability to force Windows to not give the option to update to Windows 10 in the local group policy editor.
    gpedit.msc path listed below in italics, further explained in: KB3080351.
    I recommend you install it because it also addresses an issue in which system performance can be decreased during scans.
    And errors you may encounter with Windows Update.
    Computer Configuration > Policies > Administrative Templates > Windows Components > Windows Update
    Double-click "Turn off the upgrade to the latest version of Windows through Windows Update", and enabled the setting.
    Please note that Microsoft is constantly revising these updates with the data that the telemetry provides them.
    For example KB2952664 is at version 13 as of this writing.
    For this reason when you uninstall KB2952664 it might appear that nothing happens because it just reappears again with the only change that the "install date" changes to the current date.
    Actually what it's really doing is downgrading from KB2952664-v13 to KB2952664-v12 if you previosuly had version 12 of the update intalled...
    This is handled by the WinSxS folder in the Windows directory and during my testing even on high-end machines with SSD's this can take over an hour to complete per update!
    For this reason to reduce the size you your WinSxS folder I recommend that you run the following command.
    It will remove the files kept to support the uninstallation of Service Pack 1 on your system.
    This only applies if you first installed Win7 RTM and then upgraded to SP1, a slipstreamed install will not need this.
    Code:
    dism /Online /Cleanup-Image /spsuperseded /hidesp
    This can also be done in the "Disk Cleanup" interface, select to "Clean up system files" and finally "Service Pack Backup Files"
    But this does nothing for the hundreds of updates released after SP1, with Windows 8.1 really powerful dism tools were added to control this.
    And thankfully atleast a subset was backported to Win7 with update KB2852386.
    When you have this update installed you will be able to select "Windows Update Cleanup" which removes all superseded updates.
    Meaning if you currently have version 13 of KB2952664 installed but also the former 12 versions it will remove the former 12 versions.
    So this way when you uninstall KB2952664 it will not downgrade to the next older version and so on...
    It also goes without saying that antivirus programs and the system restore feature greatly slows down this process.
    So you might at least want to disable your real time antivirus scanner until the process is done.
    Also note that this list is specific for Win7 SP1, there exists two updates for Win7 RTM aswell, called: KB2977759 & KB3163589.
    Last edited by Per Hansson; 07-02-2016, 09:16 AM. Reason: Changelog: 2015 August: KB3080149, KB3075249 & KB3065987 September: KB3083324 October: KB3083710 2016 February: KB3123862, KB3112343 & KB3135445 March: KB3138612 June: KB3161647, KB3173040 &am
  • lti
    • May 2011
    • 2557
    Re: Win7 updates for upgrading to Win10
    This is good to know.
    My computer has all of these except KB3068708 (it still has KB3022345 instead) and KB3035583 installed.
    KB2952664 keeps appearing in Windows Update, even though it's already installed. Updating the updates could explain that. Also, it won't uninstall. Attempting to uninstall it just causes the date it was installed on to change.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      anymore, I do Win7 SP1 and then disable all updates thereafter. so sad that windows has come to this.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
        • 31255
        so "telemetry" is ms new word for spying i see.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          You might need to uninstall it up to 13 times, since removing for example the latest KB2952664-v13 update would mean going back to KB2952664-v10 if you had previously installed that update.
          Please try it and see if I'm correct, it's only a theory
          EDIT: I saw the same thing as you on my company laptop, I had to uninstall 5 editions of KB2952664 and then it finally does not show up as installed anymore
          • diif
            • Feb 2014
            • 6978
            • England
            When you install Win 7, select important updates only. Then there will be no sign of Windows 10 and the updates that are listed above will all remain Optional.
            Disabling important updates is unnecessary and a bad idea, there are far to many exploits that rely on an unpatched Windows.
              • 31255
              didnt microfuck change it to an "important" category recently?
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                There where certainly some reports of that, in any case right now on my system all those updates I've listed are shown as optional...
                Keep in mind there is also an option in Windows Update to show optional updates as important updates...
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Not on my PC although i have seen it on a couple.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16959
                    if they stay as optional only, I'm fine with that. I never install optionals unless I know exactly what they do.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      Saw the telemetry in action on my parents PC today, it's a Dimension 9200: Socket 775 with a Xeon X3230 CPU (2.66Ghz 8MB cache) 3GB memory and two 500GB 7200RPM HDD's in RAID-1
                      Firefox felt sluggish, it's running Win7 SP1 with all updates applied.
                      Fired up Process Explorer and saw that CompatTelRunner.exe (Microsoft Compatibility Telemetry) was causing allot of disk I/O.
                      So yea, unless you are intending to do the free upgrade probably best to just uninstall those updates listed in my OP...
                      The file is included in the update KB2952664 which gets constantly revised. (Currently at revision 13 as said previously).
                      Also I found out that this particular update has a version that is compatible with Win7 RTM: KB2977759
                      All the updates I've listed in my OP require SP1, and Microsoft has said the same when it comes to upgrading from Win7 to Win10 (requires SP1)
                      I found a list of what it checks on my work laptop on which I have deleted all those Windows updates in a leftover Temp folder.
                      Basically it's information about the hardware and all installed software, so the system can advice what things you need to upgrade etc for compatibility with Win10.
                      Last edited by Per Hansson; 08-31-2015, 09:05 AM. Reason: Added links to pictures.
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        Updated the OP for Augusts "patch tuesday"
                        I added two patches: KB3075249 & KB3080149 that are related to Telemetry...
                        I also moved some off topic posts to the more relevant thread "more win10 stuff"
                        Please try to stay on-topic.
                          • 31255
                          do the "emergency" patches just released have any relation to this junk?
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            No the IE fix only patches IE related files, apply it immediately if you actually use IE, as it's used in exploited advertising networks etc, so simply visiting any website could be game over, since they buy their AD's from a network...
                              • 31255
                              wouldnt using a diff browser be safer!
                              • lti
                                • May 2011
                                • 2557
                                I had to uninstall KB2952664 four times.
                                After KB3035583 installed itself, I configured Windows Update to not install recommended updates automatically. These updates won't install automatically unless they are marked as important. I also check the list of available updates to make sure none of these updates are selected.
                                • lti
                                  • May 2011
                                  • 2557
                                  I uninstalled KB2952664 yesterday, and it seems to be gone now. Strangely, I only had to restart after the first three uninstall attempts.
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    lti: I had the exact same experience.
                                    What's good though is that I learned something new in the process:
                                    Revised updates need to have all their revisions uninstalled.
                                    And there is no way to see which revision you have in the "programs & features" console.
                                    The no-reboot requirement is probably due to the fact that the first revisions did not need to change so much in Windows, thus not requiring a restart...
                                    I just booted up an old install of Win7 I had on a RAID5 array that I replaced some months ago.
                                    It had the first version of update KB2952664 listed in WindowsUpdate.log it was dated April 2014...
                                    It had after that installed up to version 3, no reboot was required to uninstall it, and only one uninstall was enough.
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16959
                                      Ok, so is the root of all evil still these two updates?
                                      KB2952664 and 3035583
                                      If those are not installed, system is safe? True or False?
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        Those two are the main ones for doing the Win10 upgrade: KB2952664 is updated continuously (now at version 13) to provide compatibility fixes for the upgrade.
                                        And KB3035583 gives you the actual tray icon in the taskbar for offering you the free upgrade to Windows 10, unless your computer is part of a domain; then it's not offered.
                                        But I'm not sure I would call them the "root of all evil"
                                        Because if you look at the other updates I've written they provide "telemetry" data.
                                        That is they are what scan your system for compatibility problems, so that Microsoft can revise the KB2952664 update to fix upgrade issues that they detect.
                                        They can also provide fixes for other updates that these telemetry updates locate.
                                        Note in particular how this month two new ones where added, one related to the UAC prompt.
                                        So in my view it's actually these other updates that are "the root of all evil" because they are what send data back to Microsoft...
                                        • T4-BR
                                          T470S - TPM issue since TPM/BIOS update from Windows Update
                                          by T4-BR
                                          Many thanks for the high quality ressources available on your website.
                                          I'm currently facing some issues with my T470S:
                                          - I sat a Supervisor Password using special chars which was causing issues
                                          - Access to BIOS was locked but I was still able to use my PC
                                          2 weeks ago, I got an update of BIOS/TPM from Windows Update.
                                          Computer restarted and after Lenovo logo a loading bar appeared and at the end something went wrong + an error popped.
                                          Computer restarted one more time and I got the prompt for typing Bitlocker...
                                          09-26-2024, 02:50 AM
                                        • 0xx
                                          2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                                          by 0xx
                                          Hi folks,
                                          My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                                          What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                                          I assumed that Windows Update was interrupted due to closing...
                                          09-14-2025, 03:46 PM
                                        • davidebeatrici
                                          Asus X541UV Windows update KB5063060 deleting BootOrder EFI environment variable? bios fix
                                          by davidebeatrici
                                          I had 3 people contact me in a week because Windows suddenly didn't boot:
                                          As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
                                          The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
                                          Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...
                                          06-17-2025, 12:59 PM
                                        • bogart219
                                          Lenovo ideapad 5 windows 11 update disable charging circuit?
                                          by bogart219
                                          Hello fellows. My Lenovo ideapad5 151al7 doesn't charge my battery, this seemed to happen right after an win 11 update, at least that is when I noticed it. I rolled back the update but it didn't matter. The laptop doesn't work off of the power adapter, which btw, I always leave plugged in and never really use the battery. New power adapter and battery, same problem. USB-c connector. The battery monitor in setup says "charger not installed", (but it is). Using a usb tester, with the battery plugged in it reads 20 volts but no current. With the battery unplugged it only reads 5 volts with...
                                          05-05-2025, 10:31 AM
                                        • Topcat
                                          The 2025 Operating System Thread
                                          by Topcat
                                          What OS are you running these days? I am down to 3 Windows workstations and one Windows Server on my LAN, everything that doesn't have a windows-specific need has been moved to Linux. Printing abilities with my large document centers are Linux's kryptonite; the reason for 2 of the Windows machines. The third machine still has Win7 on it, and isn't connected to the outside world. It has tons of software on it I use for diagnostics and updating various hardwares. My main rig is still Win10 Enterprise, so I had to vote Win10 in the poll...but I have overwhelmingly more linux machines than windows...
                                          Windows 11
                                          27.78%
                                          15
                                          Windows 10
                                          25.93%
                                          14
                                          Windows 8/8.1 or 7
                                          12.96%
                                          7
                                          Windows Vista (I'm a glutton)
                                          0%
                                          0
                                          Windows XP (I just can't let go!)
                                          3.70%
                                          2
                                          Windows 2000 / ME / 9x (Ok, this one is a funny, maybe!!)
                                          0%
                                          0
                                          Some flavor of Linux (brag on your distro in a post)
                                          25.93%
                                          14
                                          MacOS - OSX (Poor diluted souls!!)
                                          3.70%
                                          2
                                          Google Chrome/chromebox/chromebook
                                          0%
                                          0
                                          What's a PC? (The option for those with a phone stuck in their faces)
                                          0%
                                          0
                                          01-01-2025, 10:19 AM
