DELL e6220 bios need
  • balattc
    • Feb 2015
    • 153
    • india
    Plate number : Vida-6050a2428801-mb-a01
    pls any one send bios
  • kadi144
    • Aug 2015
    • 690
    • algerie
    Re: DELL e6220 bios need
    try this
    • techman1025
      • Jun 2014
      • 497
      Hi
      Any donor bios you will need to rebuild me region on intel platform only... unless dell has full update's then and only den you will be ok .... also if it has bios password on this model you will need to replace Bio' and Ec bin then rebuild me region using the intel fit tool
      Techman1025
      • toufik sat
        • Feb 2016
        • 136
        • los angles
        Thank you so much
        • highpulse
          i hate HP
          • May 2013
          • 1489
          • portugal
          hum this EC seems way to empty than the original file , is this dumps working ==??? wel in any case going to pay again vinafix today and going to donwload good working dump with ME clear allready and post it here to all
          • techman1025
            • Jun 2014
            • 497
            Here
            Techman1025
            • jatoi
              • Jan 2015
              • 83
              • pakistan
              thanks kadi144
              • Pascal Komlassan
                • Jan 2017
                • 809
                • TOGO
                good Bro
                • laptech
                  • Sep 2014
                  • 33
                  • pakistan
                  thanks bro
                  • Pascal Komlassan
                    • Jan 2017
                    • 809
                    • TOGO
                    Thanks Bro
                    • youssef_57
                      • Apr 2017
                      • 13
                      • egypt
                      thank you
                      • mberbouch
                        • May 2014
                        • 109
                        • Morocco
                        Thanks, working perfectly.
                        • Bilal@pc
                          • Jun 2021
                          • 43
                          • Algeria
                          thanks kadi144​
                          • Doniciputat
                            • Aug 2022
                            • 111
                            • Indonesia
                            try this
                            THANKS SIR
                            • Muhammad Hussain
                              • Oct 2023
                              • 4
                              • Pakistan
                              try this
                              Bro this Bios have password,please can you remove this password
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
                              • mikeybass
                                Dell 9010 MT BIOS Update Always Fails
                                by mikeybass
                                Hi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
                                04-23-2025, 04:30 PM
                              • capoplays
                                Help with BIOS update on Dell G15 5515 after chip replacement
                                by capoplays
                                Hey everyone,
                                I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                When I check the BIOS using the F12 menu Flash...
                                10-24-2025, 06:53 AM
                              • Akhlz001
                                Dell Pro 13 Plus PB13250 Bios Unlock
                                by Akhlz001
                                Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                                09-20-2025, 07:15 PM
                              • jhanra
                                by jhanra
                                in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                11-02-2024, 04:19 AM
