Hello all, its good to be back on bcn! And now my latest problem: My Infocus SP4805 DLP projector from 2006 has been sitting in its box in a cool, dry place for the last year and a half. I pulled it out last weekend but it has decided that it doesn't want to work anymore.
It seems to power on, the fans spin up and the speaker beeps but then after a few seconds the fans slow down partially and it just sits there doing nothing. Eventually the power light blinks out a #1 code which means 'unable to strike the lamp after 5 attempts" The lamp had somewhere approaching 2000 hours (all in low power mode) on it, so it should be good for a while (up to 3000 hrs on low power).
I am pretty disappointed but figure it is probably fixable. I took it apart and did some more troubleshooting. It looked like the color wheel could be stuck since it was only twitching slightly. Apparently it has a speed sensor and will not light the lamp if the color wheel is not spinning at the right speed. I messed with it some more and noticed that after awhile it would twitch more and more and eventually spin up to full speed for a few seconds and then stop. It would do this in a repeatable fashion so I believe that the color wheel is ok and there is probably a power problem.
The power supply has a bunch of lovely suscon caps and a nichicon filter cap. I figure that caps can go bad sitting around so I replace all but one of the caps with Panasonic FC that I have onhand. I powered it back up and it is still doing the same thing. I put the scope on some of the output pins of the PSU and note that there is lots of ripple. So I ordered a new filter cap and one more Panny FC to replace the last suscon.
Those caps cap in today, I installed them but the projector still behaves the same. The ripple is the same as well as seen in the pictures.
TLDR: My projector won't work after 1.5 years in storage. The fans run but the lamp won't come on. I replaced all of the 'lytic caps (including the filter cap) on the power supply board but it still behaves the same. The attached pictures show what appears to be gnarly ripple on the output pins of the PSU. Is there anything else I could check or would I be better off to try replacement power supply for $25 on ebay?
Pics 5&6 show ripple on the 14v leg.
Pics 7&8 show the ac input board outputting ~60v square wave dc
Also attached is the service manual for the X1 which is similar. The voltage specifications are on page 83. The SP4805 seems similar. P/S interrupt was 3.2v, Lamp enable was 1.0v. Lamp lit was 0v.
Power supply/ballast board part number is 510-1894-02
