Ga-p35-s3g
  • Stratos
    • Sep 2015
    • 18
    • Greece
    Ga-p35-s3g
    Hello i have some 40-50 motherboards GA-P35-S3G and all have bad Caps KZG 6.3 1000uf if i am correct the size is 8X11.5mm,the bad caps are side by side with ram dimm and they are 4,i have pics to show my case,i find this replacements Nichicon HZ 1000uf 6.3v 8X15mm and Nichicon HM 1000uF 6.3v 8X15mm http://www.ebay.com/itm/5-Pcs-Pack-N...item256f8d401b or SANYO 6.3v 1000UF 8X11.5 http://www.ebay.com/itm/50pcs-SANYO-...item4ac90cbf87 i am ok with them? Any advice is welcome.
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Re: Ga-p35-s3g
    hi there, and woooah there
    those 'sanyo' caps are suncon [look at the picture] close up. That is a horrible brand.
    the nichicon look suspicious, the printing on them looks fake
    caps from ebay are generally a crapshoot, and the ones up there are crap
    nichicon HN are a good replacement and those caps are horribly bloated [top and bung]. But you need to get them from an electronics site like mouser or digikey. Some of the people here might know good ebay users with non-fake caps as well. i'll just wait for their input
    i'm not sure if the fact you live in greece might make it more difficult to get from US distributors at this point in time
    • Wester547
      • Nov 2011
      • 1269
      • USA.
      Re: Ga-p35-s3g
      No, Suncon was always the company that Sanyo contracted to build their electrolytics for them. Sanyo sold their electrolytic divsion to Suncon sometime in 2009, I believe, and their division of polymers to Panasonic in 2008. However, you will want to be sure you're getting genuine capacitors, and that means eBay is a no-no. An authorized distributor is a must.
      And wow, those KZGs really blew some crud out of their bungs.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5045
        • US
        Re: Ga-p35-s3g
        i didn't know this. however saying that suncon is producing quality of what sanyo has in the past is something i'm unsure of
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3266
          • Singapore
          Re: Ga-p35-s3g
          i can testify they're good. i've been using suncon wg 1000uF 6.3V on my asus p4c800 for two and a half years already and they're still going strong.
          also, i heard the sale of the electrolytic division to suncon was simply a change in name and owner. the same employees still remained so the quality should still be preserved considering japanese "honor" yea?
          • Stratos
            • Sep 2015
            • 18
            • Greece
            Re: Ga-p35-s3g
            All of you guys, I really thank you i was ready to get them from ebay,now i will try to get them from Mouser Electronics i see they have facilities in Munich
            Germany probably they will send.
            this moterboards was really reliable but after 6 years of constan running and poor cooling conditions this was more than expected,and now i have install on them xeon cpus for some extra life.
            i get some performace inprovment.
            • c_hegge
              • Sep 2009
              • 5219
              Re: Ga-p35-s3g
              Mouser are fine
              http://eu.mouser.com/ProductDetail/N...pYm8VP5sFo4%3d
              Those are about the only electrolytic caps I could find there which I know would work
              You could also poly-mod your board using these:
              http://eu.mouser.com/ProductDetail/N...73kf%2fkZ5c%3d
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5045
                • US
                Re: Ga-p35-s3g
                this motherboard does not support xeon. Xeon is lga 771 [i also looked at the cpu support sheet]
                you have 50 of these things? what do you run a internet cafe?
                • Stratos
                  • Sep 2015
                  • 18
                  • Greece
                  Re: Ga-p35-s3g
                  You are right,they don't support them officially but whith some mod is full operational,already i have mod the half of them and they are rock stable i pass them some tests and all was fine,in this price range was better choice and i get similar performance,was a cheap way for life expansion on this old hardware,yes i am technician in internet cafe.check this for more information http://www.overclock.net/t/1431723/m...a771-xeon-cpus also see this performance comparison http://cpuboss.com/cpus/Intel-Xeon-E...lon-II-X4-605e
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5045
                    • US
                    Re: Ga-p35-s3g
                    wow, I can't believe I guessed that right
                    what processor did you have in them before?
                    • Stratos
                      • Sep 2015
                      • 18
                      • Greece
                      Re: Ga-p35-s3g
                      yeah!you get it!before i have on them core 2 duo e7200 i get the double performance
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5045
                        • US
                        Re: Ga-p35-s3g
                        does it detect them as xeons?
                        • Stratos
                          • Sep 2015
                          • 18
                          • Greece
                          Re: Ga-p35-s3g
                          yes normaly,but is depends of motherboard in some cases if the motherboard is old you need modify the bios,update the CPU microcodes,for full support,in my case was all fine,in the site you have all the information how to mod the bios in each case(AMI/Award).
                          • Stratos
                            • Sep 2015
                            • 18
                            • Greece
                            Re: Ga-p35-s3g
                            hello guys the replacement for KZGs was perfect (Nichicon from mouser)
                            now a have other problem on Tk 470uf 16v ATWY 728A 105C
                            any suggestion for replacement is welcome
                            Thank you
                            • Wester547
                              • Nov 2011
                              • 1269
                              • USA.
                              Re: Ga-p35-s3g
                              This would work fine:
                              https://www.badcaps.net/store/produc...products_id=51
                              If you want to go an extra step and polymod that location if you have a hot graphics card installed or something along that nature, this could also work:
                              http://gr.mouser.com/ProductDetail/N...apl8TKVDOMtXo=
                              • Wester547
                                • Nov 2011
                                • 1269
                                • USA.
                                Re: Ga-p35-s3g
                                Sorry to double post, but if Digikey is your preference they also have the latter in stock (for now):
                                http://www.digikey.gr/product-detail...2-1-ND/5269781
                                • Stratos
                                  • Sep 2015
                                  • 18
                                  • Greece
                                  Re: Ga-p35-s3g
                                  Thank you for your answer,one more question,from your suggestion i see the replacements on solid state are 270uF,is diferent on solid?i have some spares solid,is possible to use them? here i have picture of them
                                  • ChaosLegionnaire
                                    HC Overclocker
                                    • Jul 2012
                                    • 3266
                                    • Singapore
                                    Re: Ga-p35-s3g
                                    yes those can certainly work also for replacing the tk 470uF 16v caps. i see u got the best polymer caps there. the blue cap on the left is a chemicon psc series polymer while the purple one on the right is a panasonic (formerly sanyo) oscon sepc series polymer. those are the best polymer caps around.
                                    if u are using powerful, hot high end graphic cards on those boards in an internet or lan gaming cafe, i recommend changing the two tk 16v caps around the blue pci-e x16 slot to polymers so they last longer. there have been quite a number of forum topics on here showing boards with bloated caps around the video card slot.
                                    • DrewPhillips
                                      Capacitor Diarrhea - Nichicon PL Series
                                      by DrewPhillips
                                      Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                                      The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                                      03-02-2025, 10:18 PM
                                    • nick3092
                                      Mid/late 80's Nichicon Yellow Caps
                                      by nick3092
                                      I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                                      08-28-2022, 03:56 PM
                                    • ssl6
                                      MSI K7T266 Pro (Ver. 1.0)
                                      by ssl6
                                      Hey Everyone,
                                      Long time lurker, but I think this is my first time posting.
                                      Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
                                      I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
                                      11-09-2023, 01:00 PM
                                    • chth96
                                      Is there any datasheet for nichicon RT(M) series?
                                      by chth96
                                      A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                                      https://www.badcaps.net/forum/troubl...e-been-blew-up
                                      and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                                      But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                                      I have spare console...
                                      11-28-2023, 03:36 AM
                                    • mrmazda
                                      2 no-POST Tyan Tsunami S1846 motherboards
                                      by mrmazda
                                      I have twin S1846 boards that won't any longer POST, and Slot1 Coppermine 700MHz and Katmai 600MHz to fit them. A slocket with 933 Coppermine won't POST either, No beeps. The graphics card does put a cursor on the display on power-up. Mixing the parts up doesn't change anything. Three different PSUs, and other RAM sticks don't help either. If there's anything on the web about S1846s routinely dying of old age, I've yet to find it.
                                      These have 5 UCC LXF 1000uF 10V 10x20mm (codes 8(2) &4H), 4 Sanyo CG 1000uF 6.3V 8x11.5mm, 1 Gemcon seriesless 330uF 16V. All are near CPU slot. All...
                                      12-13-2020, 01:54 AM
