Electrolytic capacitor leakage current – what is it and how to measure it
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Okay, I know this is likely covered much better by many other places online. However, I have been playing with a home-built electrolytic capacitor reformer recently, so I thought I'd include a brief mention of what leakage current is, based on the research I have done so far. In particular, what I am trying to do here is focus more into the practical side of things – i.e. how to measure leakage current of an electrolytic capacitor in order to determine if the cap is (going) bad or not.
    Basically, all electrolytic caps self-discharge, much like a battery does when you leave it in storage for a long time. This discharge rate is known as the leakage current. High leakage currents are undesirable because they produce heat inside the capacitor. Essentially, this wastes energy and makes a capacitor behave… well, less like an ideal capacitor and more like a resistor (especially if the leakage current is relatively high). In such cases, the cap is said to be “leaky” (which, by the way, has nothing to do with a bad capacitor that is physically leaking electrolyte.)
    Therefore, cap datasheets specify a maximum leakage current for each cap. It is usually given as:
    I_leakage ≤ 0.03 • C • V
    or
    I_leakage ≤ 0.01 • C • V
    and
    I_leakage ≥ 3 μA
    ...^ where I_leakage is the cap's leakage current measured in micro amps (μA), C is the rated capacitance of the cap in microfarads (μF), and V is the rated working voltage of the cap in Volts (V).
    Let's say you have a 16 V, 1500 uF cap (something typical from a PC PSU or motherboard). First determine from the datasheet how the leakage current is calculated. For this example, I will assume it is the second formula from above. Then the maximum allowable leakage current for the cap is:
    I_leakage ≤ 0.01 • C • V = 0.01 • 1500 • 16 = 240 μA = 0. 240 mA
    The next step would be to find out the cap's actual leakage current and compare with the above value. There are two ways to do this:
    (1) Put an ammeter in series with the cap and connect to a voltage source that has a voltage output as close as possible to the capacitor's maximum rated working voltage (but not higher). Let the capacitor sit connected to the source for a few minutes (datasheets usually specify 2-3 minutes minimum). Then note down the current (should be 3 μA to several thousand μA, depending on cap's rated voltage and capacitance, so set your multimeter scale accordingly if it is a manual one.)
    (2) Measure the voltage across the cap in a cap reformer circuit (after the cap has been reforming for at least 30 minutes). Then, take the source voltage of the cap reformer and subtract the voltage across the cap from that. Finally, divide by the resistance of the current-limiting series resistor.
    Example: let's say you have 15.5 Volts as the source voltage for that same 16 V 1500 μF cap above, and the cap has 14.9 Volts across it. If the series resistor is 10 KOhms (10000 Ohms), then the cap leakage current, I_leakage is:
    I_leakage = (15.5 – 14.9) / 10000 = 0.00006 Amps = 0.06 mA = 60 μA
    Thus, for the above example, comparing the actual leakage current (60 μA, at least from part 2 above) with the calculated from the datasheet (240 μA), we can conclude that the capacitor is likely okay and not leaky. I actually based those numbers above on some experiments I did with my cap reformer (therefore they are not too fictitious or arbitrary.)
    So what if a capacitor has higher leakage current that stated maximum in datasheet?
    Well, this is obviously not desirable, as stated previously. Moreover, if you are trying to measure the capacitance with a capacitance meter, chances are your meter will probably show higher capacitance than what the cap actually has. Also, there have been numerous instances on the forums here, where a cap with high leakage current would show excellent low ESR (0.02 or less) on an ESR meter, despite the cap actually being popped (i.e. bulged). I've experienced this myself too with some clearly bad Nichicon HM and HN caps from the faulty batches produced between years 2001 and 2005. Of course, for those of you who have ESR meters with capacitance measurement capability, you might have noticed that the cap probably also showed ridiculously high capacitance – and if that was the case, then you definitely had a bad cap in your hands.
    Anyways, what I am really trying to get to here is show how to measure cap leakage current. This can come handy if you have some new-old stock (NOS) caps. In particular, you might want to know if they are still good after you reform them. Measuring the leakage current won't tell you if the caps are still good, but if you do have an ESR and/or capacitance meter, at least you will know that it is not showing you some bogus measurements. And of course, if your caps do have an abnormally high leakage current, then perhaps they are just too tired (too old?) and it is likely time to discard them.
    • 31218
    Re: Electrolytic capacitor leakage current – what is it and how to measure it
    we need some reference-numbers.
    i'v noticed that aging poly's have higher leakage but the other figures look o.k.
    • japlytic
      • Oct 2005
      • 2086
      On a related subject: how to measure electrolytic capacitor ripple current
        • 31218
        i'v seen expensive benchtop testers that do that.
        i suspect they charge the cap, then dump it into a load through a shunt and capture the current-flow.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Polys, in general, do tend to have about three to ten times higher leakage current - at least the ones I've worked with. That would be Chemicon PSA and PSC, Nichicon FPCAP R7 and R5, Sanyo OS-CON SEPC, as well as Fujitsu FPCAP RE. This is why you should always check what's in the datasheet for your specific cap.
          I don't think there is an easy way to do that.
          First off, the ripple current spec for a capacitor is not a "solid number". The cap will be able to handle different amounts of ripple current at different frequencies. Second, you can push any amount of ripple current through the cap that you want. However, the ripple current produces heat inside the cap. Therefore, it must be kept to a level that doesn't make the capacitor overheat internally. And to measure that, I think you would need some seriously sophisticated equipment.
          So no simple answer here.
            • 31218
            the ripple current can be considered the same as the total holding current if you charge it and then do a load dump for most purposes.
            that's how i think the bench testers do it.
            • socketa
              Asbelowsoabove
              • Jun 2014
              • 662
              • samsara
              That was very well written and explained!
              i seriously doubt that - at least not in terms of simplicity and ease of understanding.
              • CuloumbGuy
                • Mar 2018
                • 2
                • ZA
                Thanks for a really informative post! You saved me from buying an expensive leakage tester
                  • 31218
                  leakage can be metered with a $7 component tester.
                  • vhr
                    • Aug 2012
                    • 21
                    • Russia
                    Yes,Vloss.
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      They're not always accurate., as Dave from eevlog noted himself. ESR and capacitance? -Yes. Vloss (leakage)... flip a coin and maybe pray a little. I get crappy Sacon FZ caps fooling my meter all the time. Same with some leaky Nichicon HN/HZs.
                        • Jul 2011
                        • 6069
                        So what do you do then
                        how do what is good
                        or
                        do you just replace them
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          ^ If capacitance is over 20% of stated value on the sleeve, the cap almost always has high leakage current and is likely on its way out. For those cases - yes, replace the cap for continued reliability.
                          If capacitance and ESR are normal, I sometimes also charge the cap to full rated voltage and leave it like that for some time to see how much the voltage falls down. For big caps over 1000 uF with a fairly low voltage rating (less than 50V), the cap should hold a significant portion of the voltage for at least 10-30 minutes - that is, only after you have reformed the cap, of course. Unreformed used capacitors will tend to drop down to whatever voltage they had across them while used in a circuit (i.e. for motherboard with DDR2 RAM, you will likely see the caps filtering the DDR2 Vdd voltage to drop down to 1.9-2.0V when left with a charge over a very long time).
                          This method with leaving the cap charged is not very precise, but will accurately show you if you are dealing with a cap that has severe high leakage current.
                          Alternatively, you can measure the drop across a 1-10 KOhm resistor while reforming a capacitor (but only after the cap has finished reforming for a good 10 minutes). Then divide that voltage drop by the resistance, and you get the leakage current.
                          • edugimeno
                            How to correctly measure a mixed low&high current
                            by edugimeno
                            Hi there!
                            Im trying to determine the consumtion rates of a module Im testing. Particularly it's a Decawave DWM1001 module, which is expected to use around nanoamps during normal state so a LiFePo4 battery should last months
                            This module has peak spikes of around 100mA once a second, while the TX module is active, and then goes to sleep for the rest of the time (this is when the uA rates are expected)
                            But I'm having issues to measure this current.
                            1.-Using a multimeter. Obviously all I see is values jumping all the time, as this is not expected...
                            11-15-2020, 03:51 PM
                          • quickname
                            Cyberpower 1500AVR UPS repair
                            by quickname
                            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                            Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                            I decided to verify that the batteries were...
                            11-12-2023, 09:57 AM
                            Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                            by sam_sam_sam
                            I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                            I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                            I tested the battery cells there are installed right now and they are testing good with no issues that I...
                            02-04-2025, 08:08 PM
                            Diodes AP21X2SG-13 AP21X2MPG-13 Current Limited Power Switch for Laptop Computer Datasheet
                            The AP2182 and AP2192 (AP21X2SG-13 AP21X2MPG-13) are integrated high-side power switches optimized for Universal Serial Bus (USB) and other hot-swap applications. The family of devices complies with USB 2.0 and available with both polarities of Enable input. They offer current and thermal limiting and short circuit protection as well as controlled rise time and under-voltage lockout functionality. A 7ms deglitch capability on the open-drain Flag output prevents false over-current reporting and does not require any external components.
                            All AP21X2SG-13 AP21X2MPG-13 devices are available...
                            10-23-2024, 03:33 AM
                          • DynaxSC
                            Extreme High Current & Low Voltage Short Killer ??
                            by DynaxSC
                            Hi Folks
                            I'm looking for a extreme high current short killer solution for a reasonable cost.
                            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                            After taking off the socket, the shorts dissappear again.
                            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                            10-15-2024, 10:13 AM
