ESR meter upgrades
This is a sticky topic.
    • 31277
    ESR meter upgrades
    so - rotary encoder time.
    get your rotary encoder and bend and trim the center pin so it sits on the top of the board - like this:
    • 31277
    Re: ESR meter upgrades
    next, take the original switch off, and scrape some laq off the top of the pcb for the center pin like this:
    (only for this model of meter)
      • 31277
      next, solder the encoder in,
        • 31277
        next you need a pair of 1k resistors and a pair of 10k resistors and some thin wire.
        just to be clear, the place the 10k resistors join the wire is NOT connected to the pcb!
          • 31277
          next you need to link the 2 cpu pins to the resistors.
          WARNING - this is pro-soldering!
            • 31277
            if you do it clean, it should look like this:
              • 31277
              back to the top of the pcb,
              solder the center tab of the encoder to the ground-point you remembered to scrape-clean on the pcb.
                • 31277
                2 foto's i had left.
                  • 31277
                  and does it work?
                  NO - i have to compile new firmware first.
                  still, the hardware is done now.
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    Thank you for the walk through!
                      • 31277
                      AND - IT'S HERE!
                      latest firmware compiled for this model by me.
                      with rotary encoder, new fonts/gfx, serial-port etc.
                      • elval
                        • Nov 2015
                        • 2
                        • Hrvatska
                        Thank you
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          what extra functions does this firmware/encoder mod gain?
                            • 31277
                            depends.
                            if your tester is pretty new and id's as 1.12k then nothing really, just a lot easier to use the menu function.
                            if your tester is old and running 1.11k or older then probably lots of new stuff.
                              • 31277
                              i am going to be making some updates to that file.
                              just saying.
                                • 31277
                                update:
                                btw, i'm willing to compile this for the T3 / T4 boards if asked.
                                • SteveNielsen
                                  Retired Tech
                                  • Jun 2012
                                  • 2327
                                  Thank you man. You're sure to be on Santa's nice list for this
                                    • 31277
                                    bugfix.
                                      • 31277
                                      config fix.
                                      previous builds wont read inductors properly.
                                      • japlytic
                                        • Oct 2005
                                        • 2086
                                        There is one thing ESR meters should have, which is Kelvin sensing (4-wire measurement capability), which keeps measurement errors to a minimum.
                                        • chth96
                                          Is it possible to test small ceramic disc capacitor with analogue meter?
                                          by chth96
                                          I read EBOOK of Testing Electronic Component and found that
                                          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                          Is it really possible to test small ceramic disc capacitor with analogue...
                                          03-09-2024, 10:03 PM
                                          Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                          by sam_sam_sam
                                          I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                          I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                          12-31-2023, 06:04 AM
                                        • jorpec
                                          Changing the scale of an analog meter
                                          by jorpec
                                          Hi
                                          I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                          I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                          Thnaks
                                          01-23-2023, 10:37 AM
                                          How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                          by sam_sam_sam
                                          About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                          Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                          12-14-2023, 07:45 PM
                                        • irepair559
                                          ps4 1215 model Changed port and encoder still no video?
                                          by irepair559
                                          hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                          Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                          ps4 seems to boot fine blue light then solid...
                                          01-01-2023, 12:41 AM
