Samsung UN24H4000AF red blinking
  • CraigR
    • Dec 2013
    • 959
    Samsung UN24H4000AF LED tv whn turned on the front light either stays on steady and pushing the power blinks a few times then goes out. Never any backlight and nother ever on screeen using flashlight. I get 165v constant at the big cap and the 5 wire cord from the power to main I get 12.3v on 4 and ground on the other and does not matter if red light is on or off in front. I was thinking the main but am not sure what to test next. Thanks in advance for any help!
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8118
    Re: Samsung UN24H4000AF red blinking
    Measure on the PSU the CNM803 connector all pins and post them. Then disconnect the main board and plug the TV in, the backlights should come on.
    • CraigR
      • Dec 2013
      • 959
      Yes that's the connector I was talking about it's actually 12.9volts pin 1-4 then 5 is nothing. Unplugging that connector then powering the board still no backlight so Power board shot?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8118
        O.k. maybe the PSU doesn't have a pull up resistor to fire up the backlights. I haven't seen a schematic for it.
        You wont see more than 170V on the main filter cap, as the PSU is not getting turned on (no PSon) and thus the PFC isn't working. With the PFC working, voltage on the main filter cap is >360V DC.
        Nothing on pin5 is bad. That defiantly indicates a bad main board. I guess you need a new replacement board. You could try to trace back the PSon signal on the main board, but I had not much luck fixing an issue like that as mostly the main IC was bad.
        You can try to unplug the PSon pin from the connector and jump 13V DC through a 1k resistor on it and force the PSU on?
          You need to report the readings of all 10 pins and follow each pin with pin names per chart as printed on the board: CONNECTOR:CNM803.
          Per chart:
          PIN 1, 3, 5, 7 are A13V (Always on 13V)
          PIN 8, 9, 10 are GND
          PIN 2: OD_UD
          PIN4: BLU_PWM
          PIN 6:PWR ON/OFF
          The ODD pins can be access form the top side of the board.
          The EVEN pins are accessed from the bottom side of the board.
          This power supply does not have PFC Voltage booster due to low power and it only has only one transformer and it is always running.
          Pictures provided by SHOPJIMMY.
          • CraigR
            • Dec 2013
            • 959
            Well CapLeaker bad guess. Got the new main today and same thing. Even went as far as taling the LED's out and testing them. Wish I would have seen budm's post before I ordered it. Out $25
            • CraigR
              • Dec 2013
              • 959
              1,3,5,7 are all 12.9v
              2=3.2v
              4=1.5v
              6=5.4v
              8,9,10 are good ground.
                2=3.2v
                4=1.5v
                6=5.4v
                So 2, 4, and 6 change state when the power switch is toggle ON and OFF?
                  Samsung BN44-00746A
                  BTW, you need to check the DCV of the LED connector CNL802 pins with and without the connector in place when TV is ON. I have a feeling you have bad LEDS.
                  • CraigR
                    • Dec 2013
                    • 959
                    No change in voltage when on/off button toggled in 2,4 and 6
                    I have 18V on the LED connector. I removed the LED's and tested each bulb with a bench power source and all of them lit. I also noticed the led in the digital audio connector always stays on when toggling the on/off switch.
                    • vankbg
                      • Dec 2013
                      • 4
                      • Bulgaria
                      Can I check the power without other boards?
                      What to include on the PowerOn?
                      • nomoresonys
                        • 12116
                        • U.S.
                        In what way is your tv malfunctioning vankbg? be as specific as you can.
                        • vankbg
                          • Dec 2013
                          • 4
                          • Bulgaria
                          No power. Red LED is not illuminated.
                          Board power supply - checked, MOS, Diode ,.
                          There are 375 V input capacitor.
                          There is no output voltage.
                          I measure when the power circuit is disconnected from the TV.
                          • nomoresonys
                            • 12116
                            • U.S.
                            Don't understand "I measure when the power circuit is disconnected from tv". Did you try disconnect cable from powerboard to mainboard leave it out, then plug power cord into powerboard, do backlights come on and stay on?
                            • vankbg
                              • Dec 2013
                              • 4
                              • Bulgaria
                              I measure when the power board is disconnected from tv(Mother board and LED) Only Power 220V
                              • vankbg
                                • Dec 2013
                                • 4
                                • Bulgaria
                                Power suppay works without you plug to Mother board?
                                • nomoresonys
                                  • 12116
                                  • U.S.
                                  It's a test to try to verify powerboard and backlights, don't be afraid no harm if done as instructed.
                                  • vank
                                    • Feb 2012
                                    • 11
                                    • Bulgaria
                                    Many thanks for your attention @nomoresonys !!!
                                    I repaired the power supply.
                                    The problem was PHOTOCOUPLER LTV-817B.
                                    I changed and everything is fine!
                                    Once again many thanks and all good!
                                    • nomoresonys
                                      • 12116
                                      • U.S.
                                      Good to hear, thanks for the feedback.
                                      • jurkozako
                                        • Feb 2020
                                        • 2
                                        • Slovakia
                                        Dear budm, can you help me?
                                        My TV(Samsung UE40JU6400W) still illuminated RED standby LED on front. The voltages on powersupply are:
                                        when mainboard is unplugged - connector CNM803 (then the LED backlight is switched on)
                                        1. F/C 0,26V
                                        2. A/D 2,67V
                                        3. A13V 12,7V
                                        4. OD_UD 3,53V
                                        5. A13V 12,7V
                                        6. BLU_PWM 3,11V
                                        7. A13V 12,7V
                                        8. POWER ON/OFF 3,86V
                                        9. A13V 12,7V
                                        10. GND 0V
                                        11. GND 0V
                                        12. GND 0V
                                        If I connect mainboard then the backlight is turned off and there are those voltages:
                                        1. F/C 3,20V
                                        2. A/D 3,26V
                                        3. A13V 9,28V
                                        4. OD_UD 0,0V
                                        5. A13V 9,28V
                                        6. BLU_PWM 0,0V
                                        7. A13V 9,28V
                                        8. POWER ON/OFF 0,9V
                                        9. A13V 9,28V
                                        10. GND 0V
                                        11. GND 0V
                                        12. GND 0V
                                        Is it bad mainboard, inst it?
                                        Thank you,
                                        Juraj
                                          09-07-2024, 05:50 AM
                                        • Asraf Atb
                                          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                          by Asraf Atb
                                          Hi everyone,
                                          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                          01-27-2025, 05:02 PM
                                        • JSin21
                                          Compatibility of main boards between different variations of samsung MU6100
                                          by JSin21
                                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                          11-27-2023, 04:54 AM
                                        • elpatxi_bcn
                                          Samsung HG75EJ690UB Hotel TV, change main?
                                          by elpatxi_bcn
                                          Hello!
                                          I just got a Samsung TV model HG75EJ690UB 75" and 4K. It is a hotel TV, with a slightly different version of the Tizen operating system than the TVs at home.
                                          Being a hotel, it is covered in many functions. With the service menu I can unlock some, but not others. For example, I can't install apps like Netflix etc...
                                          The fact is that it seems that I can replace the main by a, say, "normal". I think the one that corresponds is NU7105, ref BN94-02635. At work, which is a convention center and a hotel, I have many TVs from 55" to 85" that...
                                          05-19-2023, 03:21 AM
                                          09-06-2024, 11:40 PM
