I noticed there's very little info about RoHS here on badcaps.net, so I thought I'd start a thread about it. If you have any comments or info you want to add, please do so.
What is RoHS?
RoHS stands for Restriction on Hazardous Substances. It was adopted by the European Union on February 2003, and was put into effect on July 1, 2006. RoHS bans the use of the following 6 substances in concentrations higher than 0.1%:
1. Lead
2. Mercury
3. Cadmium
4. Hexavalent chromium (chromium xxx or Cr6+)
5. Polybrominated biphenyls (PBB)
6. Polybrominated diphenyl ether (PBDE)
RoHS does not apply to Control and Monitoring Equipment, Medical Equipment, and Military Equipment.
What does this mean, and how does it affect me?
Solder has traditionally been a mixture of Lead and Tin, commonly referred to as SnPb solder or 60/40 solder. Tin (Sn), is a metal that often grows small "whiskers". The exact reason why is not known, and such whiskers can grow very long and cause short circuits inside electronics, causing failure. The addition of Lead to Tin stopped these whiskers, so solder has always been a mixture of Tin and Lead. When RoHS was introduced, the Tin "whisker" problem was re-discovered. Take a look at this picture:
As you can see, Tin Solder without any lead in it has a tendency to grow "whiskers" which can cause short circuits and failure.
RoHS bans lead.
That means any RoHS compliant product (the majority of what's out there today) will use lead-free solder which has a tendency to grow whiskers.
What where those idiot politicians smoking?
The world may never know. Apart from the issue of whiskers, lead free solder also has a 260°C melting point instead of SnPb solder's 220-235°C melting point. This means companies have to spend lots of $$$ to upgrade their production lines, and the introduction of RoHS drove many small businesses bankrupt because they could not afford to retool their entire production line. Tin solder is also much harder than SnPb solder, which means it can crack more easily and lead to bad solder joints. Sn solder can also warp PCBs, and is harder to solder with. SnPb solder tends to flow onto the contact points on PCBs, making soldering easy, while Sn solder does not do the same. In addition, mixing SnPb solder with Sn solder can lead to solder joints cracking. All this to save a little lead? Electronics failing left and right and filling landfills is a lot more damaging to our planet than a little lead, but you know how politicians are. If it will help make them look like they give a shit about the environment, they're all for it.
Sources: Wikipedia, Google.
What is RoHS?
1. Lead
2. Mercury
3. Cadmium
RoHS bans lead.
