Oh no! USB Type-C cable problems
  • japlytic
    • Oct 2005
    • 2086
    http://www.myce.com/news/apple-repla...gn-flaw-78600/
    I've read about the power delivery capabilities of USB Type-C: a maximum of 100W (20V @ 5A).
  • japlytic
    • Oct 2005
    • 2086
    Re: Oh no! USB Type-C cable problems
    Danger! Poor quality USB Type-C cables can damage or destroy your devices (or even cause a fire)!
    http://www.zdnet.com/article/poor-qu...-your-gadgets/
    A list of cables tested by APC Magazine: http://tinyurl.com/apc427-usb
    If Amazon can do that , so can eBay!
    http://www.valuewalk.com/2016/03/ama...cable-sellers/
    http://androidcommunity.com/amazon-n...ters-20160331/
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • Patch2
      Cable Repair
      by Patch2
      I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
      01-02-2025, 06:04 PM
    • Tr0ll
      by Tr0ll
      Original T-con:
      First replacement T-con:
      10-07-2023, 07:48 PM
    • conghuyms
      I need datasheet cable eDP LCD 30 pin slim pls help me!
      by conghuyms
      Hi everyone,
      My 30-pin eDP cable from the mainboard to the LCD screen got cut and damaged at the screen connector side. I found another cable and took the screen-side connector from it, but the wire colors are different. So I really need the wiring diagram for both ends of the eDP cable to solder it back properly. If anyone has the diagram, please kindly help me out. Thanks a lot...
      08-22-2025, 11:16 AM
    • jean luc ferre
      laptop hp g72 b52sf screen problems
      by jean luc ferre
      on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
      the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
      i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
      i don't understand the reasons of the white stripe at the bottom of the screen below the task...
      06-07-2025, 03:27 PM
