Need Bios Sony Fit 15E (DA0HK9MB6D0 REV.D) Dump available
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello friends
    I have here a sony laptop with corrupted bios !
    Model is : Sony Vaio SVF 1521A6EW
    Motherboard is : DA0HK9MB6D0 REV.D
    I already tested a file found on this forum, it doesn't work and it's worse then the actual corrupted!
    Here the dump :
    https://mega.nz/#!fVFEXLJD!um21wOz_z...3fIuN1C7qVqG8g
    Please help guys
  • ivanxxx
    • Nov 2012
    • 10
    • Croatia
    Re: Need Bios Sony Fit 15E (DA0HK9MB6D0 REV.D) Dump available
    try this one
    • imranromi
      • Jan 2015
      • 1288
      • Pakistan
      try this
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        Thank you very much guys, you are the best !
        I didn't test the above bios, but i'm sure that they work.
        I've received a good dump from a russian forum.
        Thanks again
        • TossDon
          AKA Masood
          • Jun 2013
          • 26
          Please post the working BIOS so some one can use it.
          • passete
            Living=Sharing
            • Jun 2015
            • 487
            • France
            The one from post #2 is the same i used and worked.
            • Nasir Raja
              • Mar 2014
              • 21
              • United Kingdom
              Above Ivanxxx one dump is working but language is polish or Russian.
              Thanks guys
              • rata@abv.bg
                • Oct 2015
                • 4
                • Bulgaria
                both dumps working fine...first one is on czech language, 2nd is spanish
                thanks
                • walid1992
                  • May 2016
                  • 36
                  • tripoly
                  thank you
                  • polytek
                    • Dec 2013
                    • 496
                    • TUNISIA
                    Originally posted by ivanxxx
                    try this one
                    is this bios for DA0HK9MB6D0 REV: D or for DA0HK9MB6D0 REV:E ?
                    i want to flash this board : DA0HK9MB6D0 REV: D
                    • rioreno
                      • Feb 2009
                      • 540
                      • Indonesia
                      i think passete has confirm if ivanxxx file worked with his board, his board same with your board...
                      • babak
                        • Jul 2016
                        • 2
                        • Iran
                        Hi evry one I need bios for Sony SVF14NA da0f12mb6d0
                        can you help me?
                        • arcssssc
                          • Feb 2016
                          • 4
                          • azerbaijan
                          THANKS Ivanxxx
                          • cihancyber
                            • Mar 2017
                            • 22
                            • tejhi
                            thanks
                            • elaamraouiyouness
                              • Feb 2017
                              • 9
                              • morroco
                              thank you
                              • eccoqualamail
                                • Jun 2017
                                • 1
                                • italy
                                Originally posted by elaamraouiyouness
                                thank you
                                hallo, can u help me re-programming same bios?
                                tks
                                • dolunay79
                                  • Oct 2016
                                  • 18
                                  • turkey
                                  • jonaspc
                                    • Nov 2017
                                    • 1
                                    • Brazil
                                    Very very THANKS Ivanxxx!!!
                                    you save day today!
                                    • reigneilmax
                                      • Jan 2017
                                      • 9
                                      • philippines
                                      thanks for sharing...god bless u
                                      • Kamar
                                        • May 2016
                                        • 8
                                        • india
                                        thanksssssssssssssssssssssss
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Habble7
                                          I need a BIOS dump for the Samsung S49CG934SU monitor
                                          by Habble7
                                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                          Suspected Cause:
                                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                                          by Citymin
                                          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                                          The charging red LED lights up, but the charging screen doesn't show any indication.
                                          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                                          (I've tried removing the battery and resetting the device, but the issue persists.)
                                          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                                          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • DynaxSC
                                          MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                                          by DynaxSC
                                          Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                                          I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                                          11-17-2023, 10:56 AM
