acer 5740 JV50-CP help disable DSC VGA
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    helo ppl, can you help me pls
    i have acer with vga problem (ATI 216-0774007) and inte i3-330m with vga
    here is scheamtics... is there any way to disable that failed ati (turn on, turn off normaly, no image on screen, num lock and caps lock works)
    i will reflow to confirm but it will only fail again so i was wandering how to disable it?
    could it be U52???
    can you help me magicians?
    Im Back... sort of...
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: acer 5740 JV50-CP help disable DSC VGA
    i think u52 is 1.8 volt for ddr2 ram.
    try remove l16 at first. if it works ok then we can make other try.
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      try for help
      reflowed ati vga, flashed bios, it gives image
      i removed L16, turns on and no image
      now we can begin experimenting any more ideas?
      it can be bios problem, on some platforms bios detect first descrete, then uma so if dsc disabled it does not post
      but, there is a version of the board without dsc vga so i might try to flash that bios but i will leave that for later
      any new ideas?
      what signal should be removed? +VGA_CORE?
      in new to this
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        we removed vga core.... now on page 57 we have ati power....
        on page 22 we have NV_BLON_IN and PCH_BL_ON that should be discrete and integrated backlight signals, so both ban turn on backlight.
        on page 24 we have
        L=>B0 -DIS
        H=>B1 -UMA
        but that ways is a bit complicated...
        let's try remove r658 (page 57) and see...
        ps: reballing the chip will fix ati problem.... or if u can buy new chip (25 dollar) reball and put in place
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          will try remove those in monday
          i do not own reballing station, nor i will soon
          plus, i try to learn as much on component level reapait and signal tracing as well as mastering schematics (very hard to understand to me)
          tnx for all help on this personal project
          i will report in monday
          best regards
          • JaroTech
            • Mar 2015
            • 351
            Hi, just an idea, if you want to disable (not functioning) the ATI chip, why not remove the crystal.
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              after intensive trying could not get intel vga to appear in device manager... whatever i do, only ATI dsc vga in in device manager so i suspect that even if cpu has uma vga it cannot be only vga on this platform
              giving up on this, tnx for all help, i appreciate it
              it helped me to understand that VGA_CORE should be disabled in order to hardware disable vga? some bios first detect dsc vga and then uma so i gues this trick is not doable on those platforms?
              • spidey
                climbs
                • Dec 2012
                • 644
                • Cyprus
                sorry for bringing back this old thread, i just wanted to add this info for who is searching for a solution on this platform.
                Put R2 - 0om.
                Set RN13 - 0om
                to rearrange RN22, RN23, RN24, RN25 to RN16, RN17, RN18, RN19
                to rearrange RN33 to RN20, RN34 to RN31, RN114 to RN21
                and R384 to 0
                Remove R380
                Remove Video Chip
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  it would be nice if you had picture or two but tnx anyway
                  • razu
                    • Jan 2015
                    • 218
                    • Bangladesh
                    Can any one give me the picture of the acer JV 50-cp discrete to uma convert.........File
                    • razu
                      • Jan 2015
                      • 218
                      • Bangladesh
                      heres are convert video but I can not translate chinese Language on video....any one help me.............. https://www.youtube.com/watch?v=lVbcaszewOY
                      • prestijpc
                        • Dec 2019
                        • 9
                        • Türkiye
                        [QUOTE=razu;859267]heres are convert video but I can not translate chinese Language on video....any one help me.............. https://www.youtube.com/watch?v=lVbcaszewOY[/QUOTE
                        I applied both the steps in the video above and the steps in the picture attached to my message. I've tried a lot. I didn't get any positive results either. İ tried with different bios and ec file but didn't
                        • mat2k
                          Disable faulty soldered RAM on Acer A315-22
                          by mat2k
                          Hello, I've been googling for some pointers on this but couldn't find anything that applies to this board. I have an Acer A315-22 (board NB8607) with faulty RAM between 142 and 174mb. I just wanted to disable the onboard RAM altogether, but this one doesn't seem to have any memory down ID resistors or strap in order to disable it. I'm attaching the schematic I found, the boardview for it also seems to be available somewhere in this forum but I still don't have a use for it lol.
                          How would I disable the RAM on this PC? Thanks for the help.
                          [MOD EDIT] LINK to boardview + schem...
                          06-02-2024, 11:26 AM
                          09-06-2024, 05:27 AM
                        • b-slayer
                          Acer A317-53 need help to disable faulty onboard ram
                          by b-slayer
                          Hello.
                          I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
                          - first one is to modify le bios to disable the onboard ram.
                          - second one is to disable the onboard ram by desoldering some components on the mainboard.
                          so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
                          so i found that my motherboard...
                          10-12-2024, 03:46 AM
                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                          09-07-2024, 05:00 AM
                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
