Philips 32PFL7762D/05 - Stuck in standby - LED blink code
  • tn245
    • Oct 2013
    • 530
    Originally got this one months ago and it was turning on but had some weird display issues. Just got back to it and it's not coming out of standby and it's flashing an error code. Voltages are all there at the PSU.
    The blink pattern doesn't seem to match that described in the service manual (attached - see pages 21&22). It seems to be: medium blink (~1.5secs), then four short blinks, a long pause, long blink (~3secs) and then the pattern repeats. I've attached an animated GIF of the pattern.
    Does anyone know anything about this error code?
  • tn245
    • Oct 2013
    • 530
    Re: Philips 32PFL7762D/05 - Stuck in standby - LED blink code
    So I followed the procedure described in the service manual to load default NVM values. With SDM jumper shorted which also bypasses protection, the TV powers up, responds to remote, menus work and I get DTV sound and picture, but the display is distorted (see photo). I think a new SSB will sort this but as they seem expensive and not too common I'd rather see if I can fix this one.
    Assuming the error code is error 4 (4 short flashes, though the longer flashes don't seem to fit the described pattern) - it is listed as general I2C error and the service manual gives some hints, so I'll look into that.
    • Diah
      • Feb 2013
      • 6426
      i can read from yours SDM photo on screen you have error 14 its SDRAM defect, or on the photo other No ?
      • tn245
        • Oct 2013
        • 530
        Good point! I hadn't even noticed that through the distortion. It looks to me like error 14 and error 10. I guess the longer blink stands for the decimal digit as in other Philips models, so 1 long + 4 short = 14, but I was confused because on this model the service menu describes a different blink system where error 14 would just be 14 short blinks.
        That gives me something more to go on thanks! Error 10 and 14 means both SDRAM chips defective. Perhaps more likely a problem with supply voltage to those chips? Will check voltages around there.
        • Diah
          • Feb 2013
          • 6426
          the 10 or 18 ??? it is related also to SDRAM, freezing it ot heating it you will find whats going on freezing it bad sector of 8 bits, heating are bad soldering out and in of the ram. good luck
          • tn245
            • Oct 2013
            • 530
            Could be 18 actually yes - but 18 in the manual just says 'Reserved'. I will try what you say. Thanks again.
            • tn245
              • Oct 2013
              • 530
              Freezing and heating had no effect.
              • Diah
                • Feb 2013
                • 6426
                then replace SDRAM. , if you cant i think replace SSP doesn't worth on this TV
                • tn245
                  • Oct 2013
                  • 530
                  Does anyone speak any Russian? This guy seems to have had the same issue:
                  http://monitor.net.ru/forum/philips-...fo-320361.html
                  But from the google translation I can't make out if he fixed it, but I think he says he changed the SDRAM and it didn't help.
                  Google translated version:
                  https://translate.google.co.uk/trans...ml&prev=search
                  • alro7779
                    Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                    by alro7779
                    Hello, guys!
                    The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                    09-14-2025, 12:25 AM
                  • G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                    by G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                    It does power up when pressing the power button.
                    I already try the power button while plugin the plug with no result.
                    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                    Could this be an PSU or eMMC issue ?
                    07-19-2025, 03:43 AM
                  • lepak06
                    TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                    by lepak06
                    Hello
                    I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                    The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                    Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                    All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                    But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                    01-12-2023, 01:43 AM
                  • djordje
                    Philips 55 oled 804/12 red light blink
                    by djordje
                    Hello all,
                    I have Philips Oled 55 (804/12) with black screen and red light blink.
                    I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                    Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                    When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                    My questions is what should i do next...
                    01-03-2025, 04:00 PM
                  • Bad_IC
                    Philips TV 37pfl5604h/12 no standby voltage
                    by Bad_IC
                    I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
                    These are the voltages in some pins of IC fsq510:
                    Vcc=18v
                    D=320v
                    Vstr=154v
                    Unfortunately, I couldn't find the schematic
                    What else could I check?
                    Is it possible to provide standby voltage from an external source to allow the TV to turn on?
                    Thank you​...
                    11-08-2024, 01:07 PM
