No backlight on Sony Vaio Pro 13
  • jacobtc
    • Apr 2016
    • 274
    • Denmark
    So I purchased a defective Vaio Pro 13, which would not display anything on the screen, however the HDMI output works.
    I purchased a whole new screen assembly in the hopes that it would work, however still nothing. I took a flashlight and found that it was the backlight which was dead. I know how to solder, and have no problems with a multimeter, however I have never fixed a backlight fuse before, and I have no idea where the fuse is positioned. I took a picture of the display connector and the area around it, does anyone know where the fuse is? And could I just remove the fuse and solder between the pads to short it, to make it work?
    Image: http://imgur.com/RX3ViTE
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Re: No backlight on Sony Vaio Pro 13
    its a very small fuse , you got 2 near lvds but i dont believe are does ones . but one of them its green with a P on the right side of lvds , and the outher is like a little black resistor with the S letter on it . but my guess is that the fuse you look is on the outher side of the board .. best thing is to give us board code , for we can manage to tell you exact were to look
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      and yes you can remove fuse and ADD a very tin wire (from a speaker laptop cable , remove one wire of the multiwiring , and solder between pads ,,it will act like a fuse since its only a very tin wire
      • jacobtc
        • Apr 2016
        • 274
        • Denmark
        Thanks for the quick reply! I don't have the board close by right now, however where do you see the green one with the P on it?
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          the ones with a 0 insyde is 0ohm resistor it will act as a fuse also , so all does components i marked to you , must make continuity in continuity mode on your multimeter
          • jacobtc
            • Apr 2016
            • 274
            • Denmark
            I actually tried testing continuity on the one with a S inside, and I'm pretty sure no continuity was detected, will try the others as well, when I get to the computer again! Thanks for the great help! Would it be responsible to just short the pads with solder, on the fuses which has no continuity?
            • highpulse
              i hate HP
              • May 2013
              • 1488
              • portugal
              yes , but bether using one part of a multisectioned wire , to make a "fuse" you can add solder , but in case of highcurrent it can kill your screen fuse is a safety , so instead of using solder , use a very tin wire and solder 1 wire from pad to pad
              • jacobtc
                • Apr 2016
                • 274
                • Denmark
                Yes you are absolutely right, using a wire would be best, however instead of soldering a wire to two pads to test, I could just short them, and see if the backlight turns on, and afterwards solder a thin wire
                • jacobtc
                  • Apr 2016
                  • 274
                  • Denmark
                  Success! The screen now lights up! Is it possible to buy a fuse to replace it completely? Are there differences on fuses other than size?
                  • jacobtc
                    • Apr 2016
                    • 274
                    • Denmark
                    EDIT: I think I found the fuse to replace it with, a Bourns 2A, however I am unsure of the size.
                    • dorHeadley
                      • Jun 2016
                      • 1
                      Hi jacobtc and highpulse, I just registered to reply to you.
                      I got the same problem, I bought a Vaio Pro 13 with a broken backlight a few months ago. I disassembled it and at first I tought it was the cable that wasn't connected properly. I connected it and the backlight worked - till now. I disassembled the Vaio again before a few hours to renew the sticky tape behind the display, cause it didn't taped anymore and now my backlight is not working. I saw this thread and tried out highpulses suggestions and I find out it's the fuse with the S on it.
                      Is there another way to bridge this fuse? I don't have the equipment to change smd parts..
                      So how the heck could it worked all the time with this broken fuse? ^^
                      Did you find out the size of the fuse? I just measured about 170mA current but will have a break now and got to bed.
                      I would be glad to get a reply
                      • elusi0n
                        • Nov 2017
                        • 1
                        • Finalnd
                        Hi guys! I'm new to the forum and thanks to you and this thread I ALMOST fixed my backlight. So I followed the advice and replaced fuse (with S on the piture) with a wire ( , but in the process, because I was using a heatgun, I used aluminium tape to protect everything around the fuse from heat and while putting it in I of course forgot to take out the battery which resulted in a short somewhere in this region (). Why do I know it was a short? A little smoke came from somewhere there. Now the backlight works, but when you put it brighter, it begins to flicker and dimms out at about 80% of brightness. Below 80% it works fine. I suspect a blown cap somewhere? Or a resistor? I inspected the area with a microscope and it showed no obvious signs of burn. Without schematics Its hard for me to find the reason for this backlight flickering. Do you guys have any advice for me?
                          Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                          This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                          09-06-2024, 05:27 AM
                        • Carlos#2003%
                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                          by Carlos#2003%
                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                          02-15-2024, 07:52 PM
                          Sony VAIO VPCEE3J1E/WI E Specification for Upgrade or Repair
                          This specification for the Sony VAIO VPCEE3J1E/WI can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VPCEE3J1E/WI boardview and VPCEE3J1E/WI schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                          Sony VAIO VGN-TZ31WN/B TZ Specification for Upgrade or Repair
                          This specification for the Sony VAIO VGN-TZ31WN/B can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-TZ31WN/B boardview and VGN-TZ31WN/B schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                          Sony VAIO VPCEB4E0E/PI E Specification for Upgrade or Repair
                          This specification for the Sony VAIO VPCEB4E0E/PI can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VPCEB4E0E/PI boardview and VPCEB4E0E/PI schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
