Boost output voltage on a 7805 regulator
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Hey all I'm helping my dad fix his instrument cluster, the old regulator died and is $40 mechanical regulator. We also replaced the fuel sending unit as it had corroded away and lost it's pick up tube and no longer worked.
    We are using 7805 voltage regulator with a 10uf cap, and it works except voltage is too low and is causing the fuel and temp gauges to read inaccurate.
    Full is read as 3/4 tank full on gauge and temperature reads too low when the engine is at operating temperature
    Measurement of 7805 Vout is 4.94v.
    The fuel gauge is 16 ohms and temp gauge 14 ohms and fuel sending unit is 8.5 ohms when full and 75 ohms when empty. Did not measure temp sensor for ohm reading. When I measured the whole fuel sending circuit, it read 24.8 ohms when full and 91 ohms when empty.
    When using a power brick/wall wart that outputs 5.2 voltage, the gauges read proper.
    The voltage from the vehicle is 13.5v with engine running, and 11.9v with no engine just on battery, the change in voltage did not change the output voltage on the regulator.
    This is what were using.
    http://www.digikey.com/product-detai...BPMS-ND/804682
    We're using a panny FC 10uf 50V capacitor on the Vin of the 7805.
    I want to boost the output voltage of the 7805 up to 5.1 volts or just at least over 5 volts to remedy the issue.
    • 31131
    Re: Boost output voltage on a 7805 regulator
    put a 1n4007 between the 7805 ground tab and ground to create a volt-drop.
    add more till you get what you need.
    or switch to using an ajustable regulator.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Unusual application...
      Wire your 4.94 volt 7805 like a LM317T where GND = ADJ, and with the "bottom" resistor 27 ohms and "top" resistor 1.5K ohms. However these need to be fairly accurate else it will be off (don't substitute, and you may need 1%, 5-10% resistors you will get significant error).
      Be ware that the ground tab will now be floating it must be isolated from the chassis. Be ware that this eats power now. You're better off using a LM317T.
      Last edited by eccerr0r; 06-23-2016, 05:39 PM. Reason: removed first option, it's horrible.
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        Wouldn't that diode fluctuate with temperatures?
        Something like this?
        http://www.rason.org/Projects/regulator/regulator.htm
        R1 would be top and R2 would be bottom correct?
        • fzabkar
          • Mar 2009
          • 772
          If you decide to stick with a linear regulator, you might like to consider adding a power resistor in series with the supply. This will reduce dissipation in the regulator. Of course you would need to allow for the minimum input voltage and the maximum load current.
            What is the maximum circuit current requirement. It sounds like you need precision power source with low sensitivity to wide temperature range.
            How was it done before?
            • fzabkar
              • Mar 2009
              • 772
              In the opening post the OP refers to a $40 mechanical regulator. I can't imagine that these would be very accurate. In fact the last time I remember seeing one was in a 1967 Chrysler Valiant (aka Plymouth).
              • Mad_Professor
                A Mech Warrior
                • Feb 2011
                • 1587
                It's a VRC-601 limiter.
                I'm not sure, it's a pretty simple design, The gauges are wired in series with the sensors then grounded via body or engine block. The voltage limiter pulls power from ignition source and used a poly film box capacitor 0.47 uf 250v rated to input. I can find some information on it here. But Specification wise... nada.
                http://www.allpar.com/history/mopar/electrical2.html
                The bits of data I can gather is dodge recommends voltage to be between 4.99 - 5.02.
                  You should at least put 0.1uF cap on the output.
                  You can also add the diode to the GND pin to raise the Voltage and see how well it maintain the output Voltage, It probably performs better than the VRC-601. But you are probably better off using LM317 and 1% resistors to set the output Voltage.
                  Did you use heat sink as shown in the link? You should, just do not Gnd the heat sink if you add the diode.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    No, or at least not that much. But you'd get increments of 0.7 volts. Maybe with a schottky you could get less... that may work.
                    Yes.
                    And the decoupling caps would be good too.
                    Oh... and the values I picked out (27/1k5) ... calculated to get about 5.2 volts with your 4.94 volt regulator... Might need to adjust that if that's not what you wanted... Increasing the 1k5 will decrease the voltage, though it is already pretty close to minimum load...
                    • Mad_Professor
                      A Mech Warrior
                      • Feb 2011
                      • 1587
                      Yes.
                      What's the difference from using a resistor from diode in this scenario?
                      I'm curious how did you get those values?
                      why is LM317 better? other than "it's designed for it."
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        The diode has discrete increments in voltage. And yes they are somewhat temperature sensitive but many things are.
                        The formulas are on the 78xx datasheets though I did try to pick standard values and did a little rounding. I hope that I don't have a math error, but I chose R2=27 as this seems to work OK and only results in one equation with one unknown.
                        R1=4.94V/((5.2V-4.94V)/(R2=27)-0.0065)=1578 ohms. Actually you should go 1575 but there's no standard value there unless you do 1500+75.
                        The LM317 is better because it doesn't leak as much current through the ADJ tab as much as the 7805 in the GND tab, not to mention the lower minimum voltage (1.25V vs 5V). These affect the resistor calculations (see datasheet) - the LM317 leakage is low enough it almost can be neglected; the 7805 is significant.
                          • 31131
                          i would use a switching module.
                          i have a bag of these.
                          http://www.ebay.co.uk/itm/121645448049
                          you can get them single for about a $ and everybody sells them - Ebay, DX, BangGood etc.
                            Or this:
                            http://www.ebay.com/itm/4-38V-to-1-2...sAAOSwfcVUHPKq
                            • Andrew F. Ali
                              • Jan 2014
                              • 2450
                              • Trinidad & Tobago
                              I'll go with the e-bay regulator budm suggested.
                              • R_J
                                • Jun 2012
                                • 9578
                                I would splurge and go for the one with the built in meter http://www.ebay.com/itm/5A-DC-DC-adj...ht_5674wt_1274
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  Oh hell, why not get an Keysight E3634A with a Tripp Lite APS2012SW.
                                    • 31131
                                    but that would need a recap
                                      • 31131
                                      btw, what does the original regulator look like?
                                      it would be interesting to fit the new pcb inside it - keeping the original look.
                                        The trim pot needs to be changed.
