Sharp Lc-70le650u only backlight, weird screen on reset, no on screen menu.
  • snake91876
    • Feb 2013
    • 236
    Don't know the history on this set. Powers on backlight then dims down, if u press up or down backlight lights up brighter. No on screen menu. Tried plugging up with volume down and input pressed and I get a messed up screen. What u think, I tried reseating the tcon ribbon cables but it didn't help anything. Turned on several times resetting and get a lol different image every time.
  • mmartell
    • Oct 2013
    • 3189
    Re: Sharp Lc-70le650u only backlight, weird screen on reset, no on screen menu.
    I would guess tcon since the main is responding to remote commands etc.
    • snake91876
      • Feb 2013
      • 236
      It doesn't change channel , volume or show on screen
      Menu. Not really responding to anything but vol - and input gets it to that screen I showed before.
      • budwich
        • Jul 2015
        • 3097
        actually, its more than likely a panel issue which has been "saved" in a number of thread. One test that will likely get you further (ie. a picture) is to unplug the small corner interconnecting cable running from the little lower boards of the panel to the little side boards. Try one side first and then the other. Go from there.
        PS. looking at your pictures, you can see the horizontal line across the top... it looks like it originates from "screen right".... thus, you likely have a bad panel tab on the right side.
        • snake91876
          • Feb 2013
          • 236
          Well I got a picture, I took the bottom right cable connecting side board to bottom board.I got a picture, sound , on screen menus. Color is distorted and still a horizontal line up near top 4" down about 3/4" wide. OK so how can I fix it all the way.
          • budwich
            • Jul 2015
            • 3097
            Good... well good that you got a picture... bad because that is likely a panel problem. The set can be "saved" to basically give you back a clear working picture. The tab drivers CAN NOT be fixed, they can only be removed, hence the "save" as the set is no longer working on "factory spec / design".
            You need to remove all the tabs along the right side of the panel... these are brown /orange flex tab cables bonded to the side of the panel connecting the little side boards (probably two). You basically "gently" pull the tab away from the bonding surface as cleanly as possible. Disconnect the corner cable (which you already have done) and "throw" the boards out as they are of no use now.
            Search around on the forum for sharp aquos type threads that will outline a bit more of the effort.
            NOTE: the process (tearing away the tabs) IS NOT reversible. IF you have chosen the wrong side (unlikely but you can confirm by testing with disconnecting the other little corner cable on the left side... you will likely get no picture as the set is trying to only run with the bad side connected... which will confirm that indeed the right side is bad).
            IF everything goes as planned, your set will be "saved" and could work in this mode for a very long time... "long" is unknown however, my neighbor's set which I saved has been working in this mode for about 10 months now... and he smiles every time he sees me.... :-)
            • snake91876
              • Feb 2013
              • 236
              Okay I will try removing right side tabs to screen, when u say it's not in spec what will be off about it, can u tell a difference.
              • snake91876
                • Feb 2013
                • 236
                Alright let me double check I'm gonna pull the two little right boards upper and lower that are connected together. I'm gonna pull there bonding from the LCD screen. And I will no longer have these boards inside the TV.
                • budwich
                  • Jul 2015
                  • 3097
                  while I have never known any manufacturer to put in technology / component just for the sake of putting them in the product. What's off? The forum is not a manufacturer design "shop"... I don't know of any posts from any one identifying an "issue"... most are so happy that their set works again that I don't think they are concerned that some "aspect" isn't quite "right".
                  Having said that, if you are expecting to "re-sell" the set as a "fully working set" then I think that is... an "issue" of "disclosure" which of course, is your "prerogative".
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    They are there to help the deselecting of rows be alot faster, bigger lcd panels have bigger capacitance in them so essentially just helps the panel work a little better, it will work with out them drivers but you might notice a little lower refresh rate and possibly the odd distortion here and there. They fail as they didnt heatsink them properly so they just get too hot and die.
                    • snake91876
                      • Feb 2013
                      • 236
                      Okay I'll let you know how it goes
                      • snake91876
                        • Feb 2013
                        • 236
                        Well guess what took the frame off removed the ribbons and she's fixed like new. I can't tell any distortion or anything. Thanks for all the help.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          Thanks for the follow up and another tv saved it looks a nice picture too on that sharp.
                          • Slavabusy
                            • Jan 2020
                            • 31
                            • Usa
                            Hello! I am having same problem! How can I get more details about this fix? Will take apart tv tomorrow.
                            • nomoresonys
                              • 12283
                              • U.S.
                              It's right there in this thread, read it carefully and follow procedure, do those tests described before tearing off tabs because it can not be reversed and only works for this specific problem. Take it slow do the tests to verify problem.
                              • Slavabusy
                                • Jan 2020
                                • 31
                                • Usa
                                First, I want to thank you for a reply! Appreciate it! Now, that I have some pictures taken and back panel is off, I will post them in new post with some explanation.
                                Hoping for your experience and support!
                                Thanks again!
                                • Yehuda170
                                  ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
                                  by Yehuda170
                                  original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
                                  replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
                                  now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
                                  with original broken screen i can see in device manager touch screen in human interfaces
                                  but with the new screen it's not showing in device manager
                                  is it lenovo blocking it? is it driver missing?
                                  I²C is a headache
                                  07-14-2023, 01:29 AM
                                • EazyBone
                                  Sharp LC-65Q620U White Screen
                                  by EazyBone
                                  Another TV topic!!
                                  I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                  The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                  Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                  08-21-2024, 12:56 PM
                                  LCD LED TV Service Menu Codes
                                  ALL LCD LED TV SERVICE MENU CODES
                                  Service Menu Code with Board Name
                                  China Universal Board / Jumper Board Service Menu Code
                                  Changhong Ruba Service Menu Code
                                  Ecostar LED TV Service Menu Code
                                  Orient LED TV Service Menu Code
                                  Haier LED TV Service Menu Code
                                  TCL LED TV Service Menu Code
                                  Samsung LED TV Service Menu Code
                                  LG LED TV Service Menu Code
                                  Videocon LED TV Service Menu Code
                                  Supra LED TV Service Menu Code
                                  Toshiba LED TV Service Menu Code
                                  Symphony LED TV Service Menu Code
                                  Veste/ LED TV Service Menu Code...
                                  10-31-2024, 03:58 AM
                                • reformatt
                                  Macbook Air M2 A2681 Kernel panics after screen replacement
                                  by reformatt
                                  Just had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
                                  It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...
                                  07-31-2025, 08:37 PM
                                • ahoonid
                                  MacBook Pro A1398 L2013 weird jumping screen.
                                  by ahoonid
                                  Hey everyone.
                                  I have a 820-3787-06 board from a MBP A1398 which has a screen issue. The problem starts with a bit of noise just like old TVs when booting and when the OS is on, screen jumps are added to the little noise on the screen. The jumps are millisecond and go back to the original place.
                                  Since there's a little crack in the corner of the screen, I thought it has to be the display. But to my surprise it wasn't since I tried it with a fully functioning screen.
                                  The same issue isn't happening with an external display. I did a gpu/cpu stress test on external...
                                  02-07-2024, 05:56 AM
