Direct uploading of files and pictures in posts?
  • boofoo
    • Jul 2016
    • 14
    • U.S.
    Can one directly upload pictures and files to this site?
  • mariushm
    • May 2011
    • 3799
    Re: Direct uploading of files and pictures in posts?
    Yes, you can, if you satisfy the minimum requirements (you may need to have at least 10-20 posts, something like that)
    Also the uploads need to satisfy the upload restrictions (various maximum resolutions for pictures, maximum file sizes for zip or pdf and some other file formats).
    When writing a reply, click on the Go Advanced button to see all the options, then click on the Attachments button (looks like a paperclip) and you'll see there what limitations are there when it comes to upload.
    • foramlaptop
      • Feb 2015
      • 50
      • pakistan
      how can upload bios file
      i have more laptop ok and test bios file
      but i trying upload file not load file
      every one help me with pictuer
      • R_J
        • Jun 2012
        • 9624
        Use Go Advanced, Chose the paper clip, Browse to your file, (you can add more than one file), then click on Upload.
        The file types and sizes are listed in the Attachement Key
        • m1ch43lzm
          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
          by m1ch43lzm
          Hi everyone
          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
          There's also an extra OTP Secu.R...
          09-06-2025, 05:47 PM
        • to5it0
          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
          by to5it0
          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
          I have opened the laptop and identified the main BIOS chip...
          10-24-2025, 01:35 AM
        • Forest79
          Lenovo ThinkStation P520 BIOS file needed
          by Forest79
          I got a Lenovo ThinkStation P520 (Type 30BF) from a friend, asking me for a repair. Windows 11 offered a firmware upgrade as an optional update, and it failed.
          The emergency flash procedure from the hardware manual has also failed. So, I asked an acquaintance with better skills to flash the BIOS directly.
          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
          07-23-2023, 07:39 AM
        • Citymin
          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
          by Citymin
          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
          The charging red LED lights up, but the charging screen doesn't show any indication.
          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
          (I've tried removing the battery and resetting the device, but the issue persists.)
          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • cr4zychriss
          [Problem/ Request] Bricked TongFang GK7MRFR BIOS
          by cr4zychriss
          I am requesting urgent assistance to unbrick my laptop, a rebranded TongFang GK7MRFR chassis. The laptop is completely dead following a faulty in-OS EC flash attempt.
          I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details
          • Barebone / Chassis: TongFang GK7MRFR
          • MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
          • Rebrand: PC Specialist
          11-14-2025, 04:04 PM
