Openflex Boardview: New boardview software (linux, windows and OSX)
  • inflex
    • Aug 2012
    • 545
    Just a notice to people out there looking for an alternative to the existing boardview software for BRD, BRV and FZ files.
    Youtube video showing it in action: https://www.youtube.com/watch?v=Fq97L6jjeUo
    Linux users can pull the git repo and build locally ( instructions on the git page ).
    Windows users can get the binary directly (Windows 7, 8, 10).
    There's a LOT of features added in this fork relative to the original OBV release, thanks to the work of a couple of people.
    You don't need to install it, just run the binary directly in a folder. For Windows people it'll create a obv.conf and obv.history file in the folder.
    To handle annotations, the software creates a .sqlite3 file with the same boardfile filename.
    Issues can be submitted at the git page.
    Thankyou.
    Main git page: https://github.com/inflex/OpenBoardView
    Issue-thread where I post the latest builds that aren't actually releases: https://github.com/inflex/OpenBoardView/issues/36
    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
  • inflex
    • Aug 2012
    • 545
    Re: Openflex Boardview: New boardview software (linux, windows and OSX)
    Bumping up.
    Been a lot of new things added since the previous post.
    • passete
      Living=Sharing
      • Jun 2015
      • 487
      • France
      Thanks for your hard work.
      I get a virus warning when i try to download
      • inflex
        • Aug 2012
        • 545
        Thanks for that, I'll have to see what's going on there and double check.
        • inflex
          • Aug 2012
          • 545
          I just scanned here with ESET NOD32 and it's come up clean.
          I've attached a new zip build here (off my linux build machine), see if that still gives you a warning ( I noticed the old one had two copies of each file in it, my fault there, as the Linux zip builder appended rather than built from clean).
          • inflex
            • Aug 2012
            • 545
            Feels like a false-positive on that; I'll try rebuilding with different parameters in VS2015 to see if it changes
            https://www.virustotal.com/en/file/0...is/1471016223/
            • inflex
              • Aug 2012
              • 545
              I just rebuilt it with different optimisations in VS2015, now shows up clean, so 99.99% likely the previous one was a false positive but thankyou for notifying me, I greatly appreciate that.
              https://www.virustotal.com/en/file/9...dbd1/analysis/
              • inflex
                • Aug 2012
                • 545
                bump.
                • alekk89
                  • Nov 2015
                  • 32
                  • United Kingdom
                  Can i ask where are the notes saved ?
                  Ok i'm blind, saw it
                  Thank you, brilliant work !
                  • inflex
                    • Aug 2012
                    • 545
                    I'll give an explanation anyhow for others who will likely ask ( and I should put it in the README ).
                    Annotations are stored in a modified-named version of the board filename, using a SQLite3 DB.
                    If you have a file
                    Code:
                    C:\boards\my_board.brd
                    then OFBV will create
                    Code:
                    C:\boards\my_board_brd.sqlite3
                    (since we're only focusing on W7 or later the long filename extensions aren't an issue, likewise no problem on linux or OSX).
                    I probably should start writing up a manual on all the options available and what they do. The colour schemes are going to be something that many people are going to tinker with and I'm still trying to think of a better way of doing the masking when you've selected something.
                    The last 3 months it's mostly been just a case of make the features that I find I want each day at work, and then later we'll clean it up a bit more. Not the most eloquent way of writing software but it does work acceptably well on smaller projects like this.
                    • electronica
                      • Apr 2014
                      • 89
                      • algeria
                      where is the osx version ???
                      • inflex
                        • Aug 2012
                        • 545
                        Try this URL -
                        https://github.com/piernov/OpenBoard...-R3-Darwin.dmg
                        • inflex
                          • Aug 2012
                          • 545
                          New update built. More items configurable.
                          * Selectable primary flip mode (viewport or mouse pointer, the latter so you can see what's under the board at the same point). Pressing shift+space/middle-mouse will flip the alternative method.
                          * Same-net web, connects each other pin on the same net with a line from the current pin (will probably add a nicer branching algorithm in the future to reduce the level of fan-out). Current NC, Unknown and GND nets are not drawn with this (meaningless or too prolific).
                          Picture showing the same-net web draw example. Fine blue lines are indicating that there's pins on the other side of the board at those locations.
                          • piernov
                            • Jan 2016
                            • 4439
                            • France
                            See https://github.com/piernov/OpenBoardView/releases for latest OS X binary, Debian package and Windows OpenGL build (may not work).
                            https://github.com/inflex/OpenBoardView/issues/36 is still up-to-date for Windows DirectX 9 binary.
                            • inflex
                              • Aug 2012
                              • 545
                              Latest build adds only two small changes; more transparent default top-ray for NetWeb, and add a pin-circle for pads on the underside (which make it visually easier for you to then target to flip the board at that location without losing the mental context).
                              • mehtabbukhari
                                Lets help
                                • May 2016
                                • 26
                                • India
                                Keep up the good work. It is really very useful.
                                • inflex
                                  • Aug 2012
                                  • 545
                                  Have now setup a proper domain and web page for.
                                  http://openboardview.org
                                  • inflex
                                    • Aug 2012
                                    • 545
                                    We've switched over to a new build engine ( no longer using VS2015 for the Windows build ). New binaries available.
                                    Interestingly, I still get a single false positive on https://www.virustotal.com/en/file/d...is/1472262260/
                                    • inflex
                                      • Aug 2012
                                      • 545
                                      Almost at 500 additional commits since the master release of OBV.
                                      Would be nice if someone could fine-tune the dark theme on OFBV to make it feel crisper.
                                      • inflex
                                        • Aug 2012
                                        • 545
                                        Bump.
                                        • inflex
                                          FlexBV FREE Edition - Modern Boardview software for Win, macOS and Linux
                                          by inflex
                                          Now available, FlexBV Free edition is a slimmed down product of the full licenced version.
                                          https://pldaniels.com/flexbv5 ( available on the downloads page or most of the way down on the main page )
                                          If you're looking for a modern alternative to existing boardview programs that's also cross platform then consider giving FlexBV Free a go.
                                          So what's missing?
                                          * Schematic/PDF coupling
                                          * Butterfly view
                                          * Donor board part searcher
                                          * Jobs
                                          * Annotations
                                          What's new/improved compared to others?
                                          * OBData...
                                          10-10-2023, 12:29 AM
                                        • ivtec
                                          install Linux on Windows 10 | Install Ubuntu on Windows 10 using Virtualbox ?
                                          by ivtec
                                          Has anybody installed Linux on Windows 10 using Virtualbox? and since my old PC will have support after oct 25 and won't update to 11 , i just want to use win 10 for Music notation program and use Progdvb iptv player .
                                          01-17-2025, 12:54 PM
                                        • Topcat
                                          The 2025 Operating System Thread
                                          by Topcat
                                          What OS are you running these days? I am down to 3 Windows workstations and one Windows Server on my LAN, everything that doesn't have a windows-specific need has been moved to Linux. Printing abilities with my large document centers are Linux's kryptonite; the reason for 2 of the Windows machines. The third machine still has Win7 on it, and isn't connected to the outside world. It has tons of software on it I use for diagnostics and updating various hardwares. My main rig is still Win10 Enterprise, so I had to vote Win10 in the poll...but I have overwhelmingly more linux machines than windows...
                                          Windows 11
                                          26.32%
                                          15
                                          Windows 10
                                          26.32%
                                          15
                                          Windows 8/8.1 or 7
                                          12.28%
                                          7
                                          Windows Vista (I'm a glutton)
                                          0%
                                          0
                                          Windows XP (I just can't let go!)
                                          3.51%
                                          2
                                          Windows 2000 / ME / 9x (Ok, this one is a funny, maybe!!)
                                          0%
                                          0
                                          Some flavor of Linux (brag on your distro in a post)
                                          28.07%
                                          16
                                          MacOS - OSX (Poor diluted souls!!)
                                          3.51%
                                          2
                                          Google Chrome/chromebox/chromebook
                                          0%
                                          0
                                          What's a PC? (The option for those with a phone stuck in their faces)
                                          0%
                                          0
                                          01-01-2025, 10:19 AM
                                        • obelix24
                                          Boardview software for Ipad OS
                                          by obelix24
                                          As in the title is there any usable boardview software for ipadOS ?
                                          Something like flexbv or boardview ?
                                          I was not able to find anything
                                          11-06-2024, 03:25 AM
                                        • japlytic
                                          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                                          by japlytic
                                          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                                          Tried (only with keyboard/mouse connected):
                                          • BIOS + database update
                                          • Using latest Windows 11 image built with official image creation tool
                                          • Previous setup version for Windows 11 installer
                                          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                                          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                                          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                                          06-19-2025, 04:59 PM
