Need help finding a replacement resistor.
  • Winston Chadwick
    • Mar 2016
    • 34
    I've been working on some H240AS-00 PSUs from the Dell Optiplex 790.
    Apparently, it's made by HIPRO.
    PCB is labeled Rev. 02
    I've been seeing a failure that was reported in this thread.
    The 1kV rated ceramic snubber cap (C52) blows and takes Q51, R25, and IC301 with it.
    According to stj, who posted in the above thread, this failure can also kill various diodes and resistors around the MOSFET. Thankfully, this hasn't been the case for me yet. I was able to repair a similar H240 by replacing only C52, Q51, R25, and IC301 with parts from a working donor unit. It passed 48 hours of stress testing with Prime95 and is still running.
    The original C52 is marked 681K 1KV. I assume I'll need a 680pF cap here. Based on stj's advice, I plan to replace C52 with a 2kV cap like this one on all of my H240s.
    IC301 is marked CP012A. According to the posters in this thread, the CP012A is only available from 3rd party Chinese suppliers. I guess I'll be getting these from AliExpress.
    Finding a replacement for R25 is the problem for me. It appears to be a .27 ohm resistor. I believe stj described this as a fusible resistor. Unfortunately, I am unable to find a .27 ohm fusible resistor. Does anyone know where I might find a suitable replacement for R25? What kind of power rating do I need?
    I'm aware of the bulging output filter caps on the example used in the pictures. I've also included pics of a naked H240 board in case that helps anyone, but the naked board is not from the same PSU.
    • 31040
    Re: Need help finding a replacement resistor.
    they are often refered to as flameproof resistors.
    • Winston Chadwick
      • Mar 2016
      • 34
      I was hoping it would be a simple misunderstanding. Thanks for your help.
      If I go through Digikey, it looks like my choices are 1W or 3W.
      I guess I'll get 3W rated resistors like this unless it's overkill.
      • Gabriel
        • Jan 2010
        • 620
        • Norway
        How many CP012A do you need ? I'm the guy who maked the thread you linked to and at work we dump still working Dell 990 and 9010 with this psu as we have a 3 year rule for replacing these.
        I dumped ~10 working ones not long ago.....
        • Winston Chadwick
          • Mar 2016
          • 34
          Eventually, I will probably need hundreds of CP012A ICs. The company I work for owns over 2,000 Optiplex 790 SFFs. I estimate that about a third of our 790s have an H240AS-00 installed. Many of those are Rev 04 boards where they used two 1kV snubber caps in parallel (I'm hoping these won't fail like the Rev 02 boards). That still leaves quite a number of rev 02 H240s.
          However, I would like to get between 10-20 CP012A for my first purchase so that I can be sure that I can get the repair running smoothly before we go full swing.
          Edit: To clarify, these PCs are remote. When they fail, they are shipped to us in operations. I can't repair all of the field units proactively, so I have to wait for them to fail. This is why I expect I'll need to do the full repair even though I plan to upgrade the snubber cap on all of the ones that I can get my hands on.
            • 31040
            the CP012A's have glue under them so they dont come off very cleanly.
            as for the resistor, try to match length and diameter
            actually, if your going to buy used chips, you may be saving a lot of time if you just buy the sub-boards with the chip & related parts on.
            • Winston Chadwick
              • Mar 2016
              • 34
              I noticed that when I tried to desolder them. Using hot air, it seemed like the circuit layer delaminated from the backboard as soon as the solder joints reflowed. There's still a bit of a bubble under both of the boards I worked on. The board I tested worked even after delamination, but I think I'll try Chip Quik next time I have to remove that IC.
              The 3W that I linked above is much closer in dimension than the 1W I was looking at, so I'll go with the 3W.
              actually, if our going to buy used chips, you may be saving a lot of time if you just buy the sub-boards with the chip & related parts on.
              Good idea. I hope Gabriel is able to sell me some of those little boards.
              • Gabriel
                • Jan 2010
                • 620
                • Norway
                I got 2 on my desk for dumping tomorrow and if I'm lucky the container has not been dumped there might be some there too.
                I check tomorrow.
                  • 31040
                  maybe Gabriel can sell you the resistors & fets too.
                  • Gabriel
                    • Jan 2010
                    • 620
                    • Norway
                    Ok, on my desk I had one D240ES-01 from a 9010 i7 and one L255ES-00 from a 9020 i5 - as you can see the 9020 psu is 12V only as mb provides 5v for drives.
                    Did not have time to have a look in the container today but I will at first chance.
                    If you want parts from these thats no problem.
                    • Winston Chadwick
                      • Mar 2016
                      • 34
                      I've seen those PSUs from the 9020. I haven't opened one yet, but they are also found in the Optiplex 7020 SFFs that we use.
                      I know how much trouble it is to get parts off of those boards. You aren't planning on desoldering components are you?
                      I appreciate the offer but, I don't want to ask you to go through too much trouble especially considering I'm not doing this as a personal project.
                      We might be interested in just buying the entire PSUs if they're still working. Of course, I don't know how much it would cost to ship from Norway. Have these been recapped or do they still have the Elite, Ltec, Capxon, and Taicon caps?
                      • Gabriel
                        • Jan 2010
                        • 620
                        • Norway
                        No, I'm not planning on keeping any parts on these for my self - if I had not seen this post they would have been in the container dump in a few days.
                        They are still working and have not been opened or recapped in any way, if you want me to desolder what you want thats no problem. I have a fr300 so it will not take much time.
                        Postage prices for you, US will be ' the rest of the world'.
                        Also,we have signed up for the new Dell 7040 sff and even if non of these have failed yet I'm planning to open a psu to have a look at the inside.
                        Not sure but I think it might be the same as the 9020 12v only version.
                        • Winston Chadwick
                          • Mar 2016
                          • 34
                          OK, thanks for the info. I sent this thread to my manager. He should be contacting you soon. Thanks again for the offer.
                          • Gabriel
                            • Jan 2010
                            • 620
                            • Norway
                            Had a look in the container and found one more, it's a H240AS-01.
                            • jinu_j
                              Dell 2209WA - power supply - Fusible Resistor replacement
                              by jinu_j
                              Hi
                              I am trying to repair an ancient Dell 2209WA Monitor which suddenly shut off with a pop sound. On investigation found that one of the fusible resistors had blown. Further investigation identified multiple components as faulty because of which the fusible resistor blew. Please refer the attached circuit diagram showing the components that were found to be damaged.
                              1. FR950 - blown fusible resistor - 0.2 Ohm 1W
                              2. Q950 - shorted Q950 MOSFET - 650V 10A N Channel Mosfet
                              3. R835 - Blown Resistor - 20KOhm SMD resistor
                              4. D930 - Shorted Schottkey Diode...
                              05-03-2025, 10:51 PM
                            • gica69
                              Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
                              by gica69
                              I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
                              Resistor shows orange range silver gold and green lines.
                              Thanks in adv...
                              07-21-2025, 09:49 PM
                            • Tomylee
                              No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                              by Tomylee
                              Hi everyone,
                              Sorry for the person who’s going to read all this !
                              I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                              While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                              During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                              07-11-2025, 11:52 AM
                            • bluto
                              Is this a fusible resistor?
                              by bluto
                              This is from the power supply of an LED shop light. The light went completely dead suddenly. I removed the SMPS board and it looked really good except for some bad solder joints. I touched all of them up but the light was still dead. I then found this open resistor that was between the neutral wire of the plug and the transformer. The color bands seem non-standard. Does it indicate 13 ohm, 30 ohm...? I am not sure. What should I replace this with?
                              07-01-2025, 01:30 PM
                            • mikey5791
                              Need help to replace burned resistor in 350w atx psu
                              by mikey5791
                              Hi to all forum members,
                              Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                              The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                              Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                              Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                              12-26-2024, 04:55 AM
