New Capacitor Brands, Good or Bad?
  • jazzie366
    • May 2016
    • 304
    Hey BadCaps!
    I'm starting an electronic component resale business in 2017, and I want to sell all the known good brands of capacitors.
    However, when I source out some other brands, I find that there are a lot I haven't heard of before, and are only 1-2 years old. By this I mean the companies are only a few years old, some I have just never heard of before.
    Example companies: WMXON, AxBoom, AnXon, Yawei, Asco, TOPMAY, and others.
    If I acquired sample of these caps, would you guys like some of them to test or see how good they are? I wouldn't have a problem sending out a few packs of caps if you guys would like to see them.
    I don't have any equipment to test them myself, if you guys could point me in some direction as to where to get some that won't cost an arm and a leg, I'd be happy to purchase some myself.
    Thanks everyone.
    Popcorn.
    • 31051
    Re: New Capacitor Brands, Good or Bad?
    avoid all those.
    they will just be the usual junk that regularly changes names.
    • retiredcaps
      • Apr 2010
      • 9271
      Originally posted by stj
      avoid all those.
      +1. Even if they test okay today, you can't tell how they will work long term. It takes years, sometimes decades to earn a reputation. And only one scandal/screw-up to destroy it.
      --- begin sig file ---
      --- end sig file ---
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        "AxBoom"!
        PeteS in CA
        • dmill89
          • Dec 2011
          • 2534
          +2, the reason "good" caps are considered "good" is that they have reputations proven over decades. Is it possible these "new" caps are good, maybe, but it is far more likely they are cheap junk constantly re-branded (to avoid a "bad reputation" by the time anyone figures out they're junk the name changes) and it would take several years (5+, 10+ would be better) of reliable operation before they could be trusted.
          • jazzie366
            • May 2016
            • 304
            Thanks for all the input everyone.
            I get that some of the older companies can change names, but even the companies that are 1-2 years old might be bad?
            The only reason I'm asking is because some of these have quite good reviews as manufacturers.
            I'll try to keep my distance for the most part though, thanks guys.
            Popcorn.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Let's put it this simple way: if the brands you are being offered are NOT legit Panasonic (Matshushita), Rubycon, Nichicon, United Chemicon, or Suncon (formerly Sanyo)... DON'T WASTE YOUR TIME!
              That said, there are also some other brands that are okay, like EPCOS, CDE (Cornell Dubilier), Elna, Wurth Electronics, and possibly a few others. But some of these don't have suitable low ESR series for motherboards and power supply use. Not to mention some of these are more expensive than the Japanese caps listed above.
              Lastly: beware of counterfeits! There are a lot of counterfeit caps online. The most faked brands are typically Sanyo, Rubycon, and United Chemicon. If you are not buying directly from the factory, forget it. You'll likely be selling junk caps just like every other eBay seller.
              • bestsystem
                • May 2011
                • 59
                http://www.wmxon.com/rohs-aluminum-c...00v_p2015.html
                10000UF 500V is totally misleading for the title, and look at the data section, their 500V caps are only 82uF
                they dont even bother to select a correct product picture, let alone getting the electrolyte formula correct
                • Behemot
                  • 4845
                  • CZ
                  Think Topmay is not that new but junk anyway.
                  BTW I've just cracked open second-generation APC Smart-UPS 450 VA (SU450INET) from 1997, thats 19 years old. All GP 85°C caps. There is one Samsung, one Matsushita and one Cornell Dubilier cap, these all test good. These always test good, maybe once in more than a dozen cases one of them was getting out of spec, but just little. Then six Teapos, half of them measure out of spec. As always.
                  Where is that Payne fool to tell me again how taiwanese brands make great caps?
                  • PeteS in CA
                    • Aug 2005
                    • 3581
                    Good quality general purpose caps used intelllligently can last a really long time. I've seen GP caps that had to be replaced that were 30 years old. The impression I get, though, is that GP caps commonly used in PSUs are not good quality, except for higher end PSUs.
                    PeteS in CA
                    • jjne
                      • Mar 2013
                      • 47
                      • uk
                      Is Wurth OK?
                      I bought one of their caps from Farnell a while back, as I needed a 10,000uF cap for an audio rebuild and Wurth was the only brand available at a reasonable price there. It does the job (it reads OK and it's only a bulk cap so I wasn't overly bothered with the quality) but it didn't exactly scream quality to me -- it had a bullseye-style bung and generally shouted 'cheap' as compared to the Nichicon it replaced. Not sure I'd use them in anything more demanding -- generally it seemed a bit 'meh' even next to something like a Samwha.
                      • jjne
                        • Mar 2013
                        • 47
                        • uk
                        Old Japanese stuff is generally chock-full of general purpose capacitors and they are rarely bad in my experience even at 30+ years old. It's the surface-mount stuff from this period that tends to go bad.
                          • 31051
                          Originally posted by jjne
                          Is Wurth OK?
                          electrolytics - probably not.
                          the Poly's look good though - and cheap.
                          • PeteS in CA
                            • Aug 2005
                            • 3581
                            The cap I had in mind was a Sprague 30D series part made in 1977. I've seen parts in recently used equipment that had date codes in the early 1970s and late 1960s. OTOH, I would not be surprised to find equipment using ancient UCC/NCC SM series GP caps still fully operational.
                            The low quality modern GP caps I had in mind are the low value GP through-hole parts often found in PWM start-up circuits that result in the PSU being "dead". Given that they're often located sandwiched between the hot inverter heatsink and the hot rectifier heatsinks, I woldn't be surprised if they are operated somewhat closer to their 85°C than is good for PSU life, but they still seem pretty low quality.
                            PeteS in CA
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              "AxBoom"!
                              Lol the fact it has boom in its name is a straight up no go
                              • PeteS in CA
                                • Aug 2005
                                • 3581
                                Kind of like the Korean power supply company I heard of in the mid-80s, "Torch".
                                PeteS in CA
                                • ChaosLegionnaire
                                  HC Overclocker
                                  • Jul 2012
                                  • 3264
                                  • Singapore
                                  lol we need a "post funny capacitor names" thread. here's my lame funny name joke: a number of caps have "vent" printed on them. is that capacitor slang for a cap that farts and pisses on itself? i've seen plenty of "vent" caps venting their piss, shit and fart on circuit boards! not a pretty sight! if u wanted a gory capacitor movie, that was it...
                                  • jjne
                                    • Mar 2013
                                    • 47
                                    • uk
                                    I've seen a few different cheap caps where they can't even spell 'vent' correctly -- these have obviously been OCRd from another capacitor, as they have "VEHT" on them. This isn't a one-off either.
                                    You have to wonder about the quality of any cap which can't even get basic stuff like that right.
                                    • Behemot
                                      • 4845
                                      • CZ
                                      It has been previously for many years mistaken as manufacturer or serie name. But VENT means they have what it says, a vent. It's the thing on top, usually, made by pressing the aluminium can so it thins in the particular spot. If the cap goes on to die and the pressure risses too much, it is supposed to crack and "vent" the gases out to prevent explosion.
                                      Damn, two of my Rubycon MBZ caps on the PC board I write from are venting again. Wonder if I used wrong voltage or what, think they are the same as I have already replaced twice!
                                      • Wester547
                                        • Nov 2011
                                        • 1268
                                        • USA.
                                        Well, genuine Rubycon MBZ don't vent for no reason. If they vented twice or thrice, it could be an issue with polarity.
                                        • cook
                                          Good brands of run capacitor for house heat hump
                                          by cook
                                          Are there good brands for 'run capacitors' or 'start capacitors' that are used on electric motors or heat pump compressors? ... r are the good capacitor brands for electronics (power supplies, laptops, motherboards, etc.) also the good brands for run capacitors?
                                          Yeah I know this might be a novice question, but I just wanted to be sure. I did do a search on the forum but did not see this question asked before.
                                          09-13-2024, 12:53 PM
                                        • Prolog
                                          RTX 3080 FE Identifying capacitor
                                          by Prolog
                                          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                                          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                                          I hope these photos make it clear which component I am referring to:
                                          (yes, the soldering is a bit botched from removing the blown one, I know)
                                          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                                          12-01-2024, 08:27 PM
                                        • chth96
                                          If I replace with inferior capacitor, Is it No harm to other IC components at all?
                                          by chth96
                                          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                                          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                                          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                                          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                                          I know that these capacitor will not last as long as nichicon capacitor...
                                          12-22-2023, 04:34 AM
                                        • chth96
                                          How can I test non-polarized capacitor?
                                          by chth96
                                          I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                                          I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                                          And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                                          I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                                          06-02-2024, 07:31 PM
                                        • chth96
                                          Is it no harm to replace with capacitor without ripple current rating?
                                          by chth96
                                          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                          Rubycon YK DataSheet (b...
                                          04-19-2024, 05:19 AM
