Hard drives with oxidized HDA contacts
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Was reading the thread "<plays taps> 500GB bites the dust..."
    There it was mentioned that oxidation of the HDA contacts on the PCB is a common mode of failure on modern hard drives.
    As I had never heard of this before I went through my pile of dead drives.
    They have already had all data recovered and are just in storage before being destroyed permanently as I don't want to risk customers data being adrift...
    One drive in particular stood out, a Samsung Spinpoint F1 1TB model HD103UJ
    But there where more drives like a HD501LJ and several Western Digital drives with the same issue too.
    This Spinpoint F1 was decommissioned because it was racking up on bad sectors, it was up to 30MB at this point, I even posted about it in the hard drive failure thread.
    When I tried running Samsung ESTOOL on it back in 2011 it stopped with a message asking to RMA the drive if it was within warranty due to bad sectors.
    As you can see from the above the oxidation was really bad.
    I cleaned it with a rubber and then some IPA.
    After this ESTOOL passes, only complaining about bad sectors in one area of the drive.
    I ran HDD Scan after this, and there are some drops in speed.
    I'm thinking this is where the drive has reallocated sectors.
    So the drive has to seek while doing the sequential test, thus creating those spikes...
    So it would be interesting to delete the drives list of reallocated sectors and then make a new scan, but I don't know how to do that.
    I also went through my box of decommissioned drives not due to problems but old age.
    It's all the same here, extreme oxidation on pretty much all "modern" SATA drives.
    But my old SCSI and IDE drives are fine because they where not victim of the RoHS directive!
    HDAT2 S.M.A.R.T report and VERIFY/WRITE/VERIFY test:
    Code:
    HDAT2 v5.0 (c) 2013 CBL 15.10.2016 16:01:36
    Read Attribute Data [SAMSUNG HD103UJ]
    HEX ID# S Attribute name          Threshold Value Worst Raw data DEC->
    ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ
    01h  1  Raw Read Error Rate           51  100  98 -          00-0000-0000-005B-62h CR OC PR ER
    03h  3  Spin-Up Time              11  73  73 8890        00-0000-0000-22BA-49h CR OC PR
    04h  4  Spin-Up Times / Start/Stop Count     0  98  98 2080        00-0000-0000-0820-62h OC EC SP
    05h  5  Reallocated Sectors Count        10  100  100 0          00-0000-0000-0000-64h CR OC EC SP
    07h  7  Seek Error Rate             51  100  100 0          00-0000-0000-0000-64h CR OC PR ER
    08h  8  Seek Time Performance          15  100  100 0          00-0000-0000-0000-64h CR PR SP
    09h  9  Power-On Time              0  98  98 12622        00-0000-0000-314E-62h OC EC SP
    0Ah 10  Spin-Up Retry Count           51  100  100 0          00-0000-0000-0000-64h CR OC EC SP
    0Bh 11  Drive Calibration Retry Count      0  100  100 0          00-0000-0000-0000-64h OC EC
    0Ch 12  Drive Power Cycle Count         0  98  98 2069        00-0000-0000-0815-62h OC EC SP
    0Dh 13  Soft Read Error Rate           0  100  98 91         00-0000-0000-005B-62h OC PR ER
    B7h 183  SATA Downshift Error Count        0  100  100 98         00-0000-0000-0062-64h OC EC SP
    B8h 184  End-to-end Error Count          0  100  100 0          00-0000-0000-0000-64h CR OC EC SP
    BBh 187 * Uncorrectable Error Count        0  100  100 391         00-0000-0000-0187-64h OC EC SP
    BCh 188  Command Timeout Error Count       0  100  100 0          00-0000-0000-0000-64h OC EC SP
    BEh 190  Airflow Temperature           0  84  65 -          00-0000-1010-0010-41h OC SP
    C2h 194  HDA Temperature             0  83  65 17øC/62.6øF     00-0000-1110-0011-41h OC SP
    C3h 195  Hardware ECC Recovered          0  100  100 -          00-0000-0000-00D2-64h OC ER EC
    C4h 196  Reallocation Event Count         0  100  100 0          00-0000-0000-0000-64h OC EC SP
    C5h 197 ! Current Pending Sectors Count      0  100  100 3          00-0000-0000-0003-64h OC EC
    C6h 198  Uncorrectable Sectors Count (UNC)    0  100  100 0          00-0000-0000-0000-64h EC SP
    C7h 199 * Ultra DMA CRC Error Count        0  100  99 1453        00-0000-0000-05AD-63h OC PR ER EC SP
    C8h 200  Write Error Rate/Count          0  100  100 0          00-0000-0000-0000-64h OC ER
    C9h 201  Soft Read Error Rate           0  253  253 -          00-0000-0000-0000-FDh OC ER
    S(tatus): * = Warning ! = Error
    Attribute flags:
    CR - Pre-Failure      OC - Online collection
    PR - Performance related  ER - Error rate
    EC - Events count     SP - Self-preserve
    Thresholds revision: 0010h
    Data    revision: 0010h
    Thresholds checksum: O.K. [reported 10h, should be 10h]
    Data    checksum: O.K. [reported 99h, should be 99h]
    Code:
    HDAT2 v5.2 (c) 2016 CBL 16.10.2016 17:23:45
    LOG: Fix with VERIFY/WRITE/VERIFY [SAMSUNG HD103UJ]
    Device parameters
    Model     : SAMSUNG HD103UJ
    Device    : SATA
    Serial number : S13PJDWQ205941
    Firmware   : 1AA01117
    Device sectors: 1953525168 [1.00 TB]
    Sector size  : physical 512 bytes = 1 logical x 512 bytes
    ATA C/H/S   : 16383/16/63
    Current C/H/S : 16383/16/63
    BIOS C/H/S  : 1023/240/63
    BIOS sectors : 15467760 [7.92 GB]
    DPT C/H/S   : 16383/16/63 (not valid)
    DPT sectors  : 1953525168 [1.00 TB]
    Max. LBA mode : 48-bits
    Cache     : 33.55 MB
    SMART     : enabled, status: ERROR
    ATA major ver.: ATA/ATAPI 3 4 5 6 7
    ATA minor ver.: ATA8-ACS rev.3b
    Mode supported: Ultra DMA 7/ATA166
    Mode active  : Ultra DMA 6/ATA133
    Translation  : ?
    Base unit size: decimal
    Test parameters
    Name of test  : Fix with VERIFY/WRITE/VERIFY
    Used commands/access:
      1. VERIFY  : ATA_NON_DATA [48-bits]
      2. WRITE   : PIO_MULTI [48-bits]
      3. VERIFY  : ATA_NON_DATA [48-bits]
    Error mode   : SECTOR MODE
    First LBA sector: 0
    Last LBA sector: 1953525167
    Tested sectors : 1953525168 [1.00 TB]
    Test buffer size: 784 sectors [401.41 KB]
    Write pattern  : 'HDAT'
    Test direction : forward
    SMART in test  : disabled
    *** Report: pass 1 of 1
    Start of test: 16.10.2016 11:27:42.50
    *** 1. ERROR BLOCK 0006610688-0006611471
    1. VERIFY  : 0006610688-0006611471 Uncorrectable data error
    --> switch to sector mode
    1. VERIFY  : 0006611409 Uncorrectable data error
    2. WRITE  : 0006611409 O.K.
    3. VERIFY  : 0006611409 O.K.
    1. VERIFY  : 0006611410 Uncorrectable data error
    2. WRITE  : 0006611410 O.K.
    3. VERIFY  : 0006611410 O.K.
    1. VERIFY  : 0006611411 Uncorrectable data error
    2. WRITE  : 0006611411 O.K.
    3. VERIFY  : 0006611411 O.K.
    1. VERIFY  : 0006611412 Uncorrectable data error
    2. WRITE  : 0006611412 O.K.
    3. VERIFY  : 0006611412 O.K.
    1. VERIFY  : 0006611413 Uncorrectable data error
    2. WRITE  : 0006611413 O.K.
    3. VERIFY  : 0006611413 O.K.
    1. VERIFY  : 0006611414 Uncorrectable data error
    2. WRITE  : 0006611414 O.K.
    3. VERIFY  : 0006611414 O.K.
    1. VERIFY  : 0006611415 Uncorrectable data error
    2. WRITE  : 0006611415 O.K.
    3. VERIFY  : 0006611415 O.K.
    End of test : 16.10.2016 14:29:45.15
    COMMAND ERRORS:
    1. VERIFY  = 1 block(s)
           7 sector(s)
    2. WRITE  = 0 block(s)
           0 sector(s)
    3. VERIFY  = 0 block(s)
           0 sector(s)
    NUMBER OF SECTORS:
    Tested  = 1953525168 [1.00 TB]
    Elapsed time: 03:02:02.65
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Hard drives with oxidized HDA contacts
    I am not sure if this site might help you. http://superuser.com/questions/38409...pending-sector
    • diif
      • Feb 2014
      • 6978
      • England
      The idea of cleaning the contacts originally came from one fzabkar's posts.
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        i wonder if anything can be done to it to prevent it from corroding again? looks like time for some very smarty-pants ghetto modding... searched for a couple of ideas from wikipedia like galvanization and anti-corrosion methods. im no metallurgist but perhaps some ideas for ghetto modding the contacts can be found.
          • 31265
          gold plating - but the stuff isnt cheap.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            had a customer come to me in sheer panic.a 1tb wd blue with 600gb of irreplaceable data not spinning up.yep it was corroded pads.from the smell it had they must chain smoke over it.cleaned it up and cloned perfectly to a new drive.
            and they now know the value of a good backup!
            i wiped with deoxit for good measure.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8705
              How much "erasing" did it take to clean them that much?
              The oxidation on my board just wouldn't budge...
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                I had a WD like that... A green line so i didn't have much hope, but i tried anyway.... Tin the pads. Use Good flux like Rubyfluid. After i did a SMART test, cleared the reallocated sector table, then zero'd the drive and ran a SMART test again, it came back with only 3 bad sectors. It only took 5 years to run the SMART tests too! Damn greens.
                Telling by the gouges in the mask of the headstack interface pads, he used one of those abrasive arse pink erasers on the back of a pencil.
                Follow the white rabbit.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Thanks, I didn't know about the /B switch to chkdsk.
                  The one included in Server 2003 does not have it so guess I have to find a more modern machine to test on
                  Yes I've seen his post over at hddguru about it too now.
                  On the 5 drives I've tried so far the oxidation has come off very easily.
                  Only like 10 "wipes" back and forth or so with the rubber eraser from a lead pencil...
                  How did you clear the reallocated sector table?
                  It's the main question of my thread after all.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16959
                    Well I'll be damned.... I have a couple 36GB raptors and a few other random SATA drives that were wonky. Cleaned contacts and they're back to life... whodda thunk it!
                    <--- Badcaps.net Founder
                    Badcaps.net Services:
                    Motherboard Repair Services
                    http://folding.stanford.edu/
                    Team : 49813
                    Join in!!
                    Team Stats
                    • dragos2009
                      • Mar 2013
                      • 110
                      • Romania
                      i don't know how to delete the reallocated sector table but i can tell you that a tool called ''hdd regenerator'' might help you to repair them or move them to defective list and put the spare ones in their place i successfully repaired one 500gb seagate laptop drive that was reporting bad sectors and it works great now in my playstation 3 also you might have to pirate it because it's a paid tool
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        Here is a more elaborate one in linux. I think it must be the same type of procedure with any hard drive.
                        http://linoxide.com/linux-how-to/how...ocks-in-linux/
                        Here is a explanation of Fdisk from old.
                        https://en.wikipedia.org/wiki/Fdisk
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          Looked further at this now, the 30MB bad sectors where only what Windows had allocated in the NTFS metadata file $BadClus
                          I ran checkdisk with the /B switch "Re-evaluates bad clusters on the volume"
                          It successfully recovered all sectors that it had marked as bad!
                          If you look in my first post the "Reallocated Sectors Count" is actually at 0.
                          It's not accurate though because further down is "Current Pending Sectors Count" at 3.
                          This has now turned to 0 after testing the drive but the "Reallocated Sectors Count" remains at 0 as well, so I think this is being hidden by the drive.
                          Here is the current lowdown, first after running a normal chkdsk /R last week from a Win2K3 install followed by chkdsk /B right now on a Win8 install.
                          And the resulting SMART attributes after that had completed.
                          Code:
                          >chkdsk /R I:
                          The type of the file system is NTFS.
                          CHKDSK is verifying files (stage 1 of 5)...
                          221696 file records processed.
                          File verification completed.
                          477 large file records processed.
                          0 bad file records processed.
                          2 EA records processed.
                          44 reparse records processed.
                          CHKDSK is verifying indexes (stage 2 of 5)...
                          839613 index entries processed.
                          Index verification completed.
                          5 unindexed files processed.
                          CHKDSK is verifying security descriptors (stage 3 of 5)...
                          221696 security descriptors processed.
                          Security descriptor verification completed.
                          49029 data files processed.
                          CHKDSK is verifying Usn Journal...
                          37436904 USN bytes processed.
                          Usn Journal verification completed.
                          CHKDSK is verifying file data (stage 4 of 5)...
                          221680 files processed.
                          File data verification completed.
                          CHKDSK is verifying free space (stage 5 of 5)...
                          72879198 free clusters processed.
                          Free space verification is complete.
                           976657407 KB total disk space.
                           684657912 KB in 154359 files.
                             95204 KB in 49030 indexes.
                             [COLOR="Red"]30988 KB in bad sectors.[/COLOR]
                            356511 KB in use by the system.
                             65536 KB occupied by the log file.
                           291516792 KB available on disk.
                             4096 bytes in each allocation unit.
                           244164351 total allocation units on disk.
                           72879198 allocation units available on disk.
                          Code:
                          >chkdsk I: /B
                           319756 index entries processed.
                           0 unindexed files scanned.
                           0 unindexed files recovered.
                           49031 data files processed.
                           37441712 USN bytes processed.
                          [COLOR="red"]Removing 7747 clusters from the Bad Clusters File.[/COLOR]
                           72886944 free clusters processed.
                          CHKDSK discovered free space marked as allocated in the volume bitmap.
                          Windows has made corrections to the file system.
                          No further action is required.
                           684657916 KB in 154362 files.
                             95204 KB in 49032 indexes.
                               [COLOR="red"]0 KB in bad sectors.[/COLOR]
                           291547776 KB available on disk.
                           72886944 allocation units available on disk.
                          Code:
                          HDAT2 v5.0 (c) 2013 CBL 31.10.2016 22:16:42
                          01h  1  Raw Read Error Rate           51  100  98 -          00-0000-0000-001A-62h CR OC PR ER
                          03h  3  Spin-Up Time              11  73  73 9010        00-0000-0000-2332-49h CR OC PR
                          04h  4  Spin-Up Times / Start/Stop Count     0  98  98 2091        00-0000-0000-082B-62h OC EC SP
                          09h  9  Power-On Time              0  97  97 12710        00-0000-0000-31A6-61h OC EC SP
                          0Ch 12  Drive Power Cycle Count         0  98  98 2079        00-0000-0000-081F-62h OC EC SP
                          0Dh 13  Soft Read Error Rate           0  100  98 26         00-0000-0000-001A-62h OC PR ER
                          BBh 187 * Uncorrectable Error Count        0  100  100 406         00-0000-0000-0196-64h OC EC SP
                          BEh 190  Airflow Temperature           0  70  65 -          00-0000-1E0F-001E-41h OC SP
                          C2h 194  HDA Temperature             0  71  65 29øC/84.2øF     00-0000-210F-001D-41h OC SP
                          C3h 195  Hardware ECC Recovered          0  100  100 -          00-0000-0BED-7C03-64h OC ER EC
                          C5h 197  Current Pending Sectors Count      0  100  100 0          00-0000-0000-0000-64h OC EC
                          C9h 201  Soft Read Error Rate           0  100  100 -          00-0000-0000-0000-64h OC ER
                          Attribute flags:
                          Data    checksum: O.K. [reported 9Ch, should be 9Ch]
                          • goontron
                            5000!
                            • Dec 2011
                            • 4108
                            • US
                            It was a little bitbangign over the serial 3.3v TTL. I'll have to look for the post i learned it from.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8705
                              Really it depends on the firmware of the drive that it will clear reallocated sectors in SMART. I've seen some drives that seem to dynamically reallocate sectors and some, when a sector is remapped, will never use that sector again.
                              The bad clusters seen by the OS is tracked by the OS and can easily be cleared, that's something completely different.
                              • keeney123
                                Lauren
                                • Sep 2014
                                • 2536
                                So here you are talking about the flash drive with-in the hard drive as oppose the the actual hard drive disk? Or are you talking about an actual space on the hard drive dedicated for the firmware on the hard drive? Because beyond that I would think the rest of the hard drive could be cleared.
                                • mariushm
                                  • May 2011
                                  • 3799
                                  I've had bad sectors removed from SMART after using Western Digital's Data Lifeguard Diagnostic for Windows tool (works with other drives not only WD) : https://support.wdc.com/downloads.aspx?lang=en
                                  I've used the zero fill option which zeroes out each sector on the drive so you lose everything including partition definitions, so save data first. After filling all with zeroes and rebooting, smart info got updated and showed fewer sectors and the drive actually worked better.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8705
                                    Yes, the recent WDs I've seen it been able to clear out SMART errors after clearing sectors. However I don't recall seeing this behavior on Hitachi/IBM SMART.
                                    • Stefan Payne
                                      • 1267
                                      Had the same issue with one of my WD Drives recently. It was a 640GB Blue one that just didn't want to start...
                                      The connectors did indeed seem suspicios...
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        Code:
                                        ENG>PSL
                                            ++ SU
                                              MaxPhyHead = 0006
                                                       RPM at Handoff: 06AA
        §UÿtSHOS - Released on 2009/04/
                                        21 16:46 by sangyun.jung
                                        DRAM=32MB SoC=26A3
                                        SHOS-(1AA17aqM.a38)
                                        L=00000000,00000000
                                        <SpinOn_2>KeepSpinOn!
                                        RV Circuit Enabled
                                        Temp : 32 degC
                                        SpinOk
                                        SK C:112386 H:0
                                        ServoTable Loaded
                                        FdtTable Loaded
                                        Hd:  0 Zn:  0 Avg.:-  134
                                        Hd:  0 Zn:  1 Avg.:   105
                                        PASS
                                        | 21 | SET_MAX | 3 | 0 | 142 | B98B |
                                        | 21 | SET_MAX | 3 | 1 | 142 | B98B |
                                        | 21 | SET_MAX | 3 | 2 | 142 | B98B |
                                        | 22 | SECURITY | 3 | 0 | 143 | B98B |
                                        | 22 | SECURITY | 3 | 1 | 143 | B98B |
                                        | 22 | SECURITY | 3 | 2 | 143 | B98B |
                                        | 159 | DCO   | 27 | 0 |  0 | B98B |
                                        | 159 | DCO   | 27 | 1 |  0 | B98B |
                                        | 159 | DCO   | 27 | 2 |  0 | B98B |
                                        RecordValid : 00078021
                                        No DRM
                                        PwrOn NoLink
                                        Code:
                                        ENG>HE
                                        [CMD LIST]
                                        HE RT RC RF PD D DS DL DB DW DI M MD MS ML MB
                                        MW FB FW DX SB CA DN DT DG BI SP TP RB ZM DZ SI
                                        SE SD UL LE PP RP FE FU CR EP EF RD WR SK QT QB
                                        QK QN QA QL QS QG QW QR QD R0 R1 XT XL XN XA XC
                                        XE XS SL OU ST SU SD PK UV SM SG EI WI MI PR PW
                                        IF TF RU WU TI TU IC TC DV LI WS CB BD BS BC GO
                                        SS NS DA DR MR LL LM LR LS LV LT LB LD LC L4
                                        Code:
                                        ENG>LB
                                        | SerialNo |S13PJDWQ205941
                                        | FWREV  |1AA07n8B.a28
                                        | BIStat  | 00000002 |
                                        | StopCond | 00000000 |
                                        | LastCmd | 000000FE |
                                        | LastStp | 0000009B |
                                        | ErrCnt  | 00000000 |
                                        | TACnt  | 00000000 |
                                        | DfCnt  | 00000000 |
                                        | FailErr | 00000000 |
                                        | LastCyl | 00000000 |
                                        | LastHead | 00000000 |
                                        | LastSect | 00000000 |
                                        |AvailZone0| 01FFFFFE |
                                        |AvailZone1| 01FFFFFE |
                                        |AvailZone2| 01FFFFFE |
                                        |AvailZone3| 01FFFFFE |
                                        |AvailZone4| 01FFFFFE |
                                        |AvailZone5| 01FFFFFE |
                                        Code:
                                        ENG>LD
                                        | LZ | PZ | HD |TYPE| StartABA | StartLBA | NumDefect|
                                        | 00 | 01 | 00 | 00 | 00000000 | 00000000 | 00001C96 |
                                        | 01 | 01 | 01 | 00 | 010C5DE8 | 010C4134 | 00001B1E |
                                        | 02 | 01 | 02 | 00 | 020FAE78 | 020F7688 | 00006452 |
                                        | 03 | 01 | 03 | 00 | 030E47B8 | 030DAB58 | 00001D41 |
                                        | 04 | 01 | 04 | 00 | 041F9E3A | 041EE47B | 00001C34 |
                                        | 05 | 01 | 05 | 00 | 051ADACA | 051A04B9 | 00001CFE |
                                        | 06 | 02 | 00 | 00 | 06305BBA | 062F688D | 000000CB |
                                        | 07 | 02 | 01 | 00 | 073CB9A2 | 073BC58C | 00000064 |
                                        | 08 | 02 | 02 | 00 | 08400A32 | 083F159A | 0002FED9 |
                                        | 09 | 02 | 03 | 00 | 093EA372 | 093AAFE3 | 000039AF |
                                        | 0A | 02 | 04 | 00 | 0A4FF9F4 | 0A4BCC98 | 00001C2C |
                                        | 0B | 02 | 05 | 00 | 0B4B3684 | 0B46ECDE | 00006DBC |
                                        | 0C | 03 | 00 | 00 | 0C60B774 | 0C5BFFF4 | 000000A7 |
                                        | 0D | 03 | 01 | 00 | 0D6D155C | 0D685D17 | 00000034 |
                                        | 0E | 03 | 02 | 00 | 0E68CFD2 | 0E64173B | 0001A338 |
                                        | 0F | 03 | 03 | 00 | 0F5FF64A | 0F599A5D | 00000259 |
                                        | 10 | 03 | 04 | 00 | 10714CCC | 106AEE68 | 0000003A |
                                        | 11 | 03 | 05 | 00 | 11659B1C | 115F3C60 | 00002409 |
                                        | 12 | 04 | 00 | 00 | 1273744C | 126CF169 | 00000091 |
                                        | 13 | 04 | 01 | 00 | 1379468C | 1372C2FA | 0000038A |
                                        | 14 | 04 | 02 | 00 | 14750102 | 146E79C8 | 0000EFA8 |
                                        | 15 | 04 | 03 | 00 | 156C277A | 1564B07A | 000003BE |
                                        | 16 | 04 | 04 | 00 | 167D7DFC | 16760320 | 0000002A |
                                        | 17 | 04 | 05 | 00 | 1771CC4C | 176A5128 | 00002283 |
                                        | 18 | 05 | 00 | 00 | 1877C07E | 187022B9 | 00000169 |
                                        | 19 | 05 | 01 | 00 | 1978B9CE | 19711A82 | 0000009C |
                                        | 1A | 05 | 02 | 00 | 1A6FD524 | 1A68351E | 0001EAF1 |
                                        | 1B | 05 | 03 | 00 | 1B60C39E | 1B573889 | 0000035D |
                                        | 1C | 05 | 04 | 00 | 1C6DE9CE | 1C645B3E | 00000041 |
                                        | 1D | 05 | 05 | 00 | 1D5C2CBA | 1D529DCB | 000000D3 |
                                        | 1E | 06 | 00 | 00 | 1E6701E8 | 1E5D7208 | 00000095 |
                                        | 1F | 06 | 01 | 00 | 1F633B18 | 1F59AA85 | 00000033 |
                                        | 20 | 06 | 02 | 00 | 2055C996 | 204C38B2 | 000018FE |
                                        | 21 | 06 | 03 | 00 | 21459D2C | 213BF32C | 00000565 |
                                        | 22 | 06 | 04 | 00 | 224684DC | 223CD559 | 00000041 |
                                        | 23 | 06 | 05 | 00 | 232C1B8C | 23226BAA | 000000C2 |
                                        | 24 | 07 | 00 | 00 | 242623B6 | 241C72F4 | 0000C60C |
                                        | 25 | 07 | 01 | 00 | 251F9874 | 25152188 | 00001865 |
                                        | 26 | 07 | 02 | 00 | 260FBDD6 | 26052E67 | 000021B3 |
                                        | 27 | 07 | 03 | 00 | 26FB875C | 26F0D61C | 00001D08 |
                                        | 28 | 07 | 04 | 00 | 280140CC | 27F67266 | 00001924 |
                                        | 29 | 07 | 05 | 00 | 28EA0F32 | 28DF278A | 00001968 |
                                        | 2A | 08 | 00 | 00 | 29EB3582 | 29E03454 | 00000086 |
                                        | 2B | 08 | 01 | 00 | 2AD9ABA4 | 2ACEA9D2 | 00000115 |
                                        | 2C | 08 | 02 | 00 | 2BC0E276 | 2BB5DF71 | 000075D6 |
                                        | 2D | 08 | 03 | 00 | 2CA18B8E | 2C961295 | 00000C1B |
                                        | 2E | 08 | 04 | 00 | 2D9C1A9A | 2D909568 | 00000067 |
                                        | 2F | 08 | 05 | 00 | 2E7C8530 | 2E70FF79 | 00000081 |
                                        | 30 | 09 | 00 | 00 | 2F71E0C0 | 2F665A6A | 0000004C |
                                        | 31 | 09 | 01 | 00 | 3061EE94 | 305667D4 | 00000051 |
                                        | 32 | 09 | 02 | 00 | 3145F60E | 313A6EDF | 0000000E |
                                        | 33 | 09 | 03 | 00 | 32282EFB | 321CA7A0 | 00000333 |
                                        | 34 | 09 | 04 | 00 | 331BE0AF | 33105603 | 0000002F |
                                        | 35 | 09 | 05 | 00 | 33F2F3E8 | 33E768EF | 0000002D |
                                        | 36 | 0A | 00 | 00 | 34E2F4C3 | 34D7697F | 0000004D |
                                        | 37 | 0A | 01 | 00 | 35CDA347 | 35C21798 | 00000028 |
                                        | 38 | 0A | 02 | 00 | 36ADE66B | 36A25A76 | 00000042 |
                                        | 39 | 0A | 03 | 00 | 378A1AD2 | 377E8E7D | 000004DA |
                                        | 3A | 0A | 04 | 00 | 38792532 | 386D93E5 | 00000043 |
                                        | 3B | 0A | 05 | 00 | 39527C91 | 3946EAE3 | 0000006F |
                                        | 3C | 0B | 00 | 00 | 3A428D1A | 3A36FADF | 00000058 |
                                        | 3D | 0B | 01 | 00 | 3B251C44 | 3B198993 | 000000B6 |
                                        | 3E | 0B | 02 | 00 | 3C01AFC4 | 3BF61C3F | 000061BD |
                                        | 3F | 0B | 03 | 00 | 3CD97CC4 | 3CCD8764 | 00000E09 |
                                        | 40 | 0B | 04 | 00 | 3DC691D0 | 3DBA8E49 | 00000029 |
                                        | 41 | 0B | 05 | 00 | 3E9971E0 | 3E8D6E12 | 0000003D |
                                        | 42 | 0C | 00 | 00 | 3F819D6B | 3F759942 | 00000099 |
                                        | 43 | 0C | 01 | 00 | 405EF7AB | 4052F2CB | 00000027 |
                                        | 44 | 0C | 02 | 00 | 4132FD73 | 4126F84E | 0000002B |
                                        | 45 | 0C | 03 | 00 | 4203841B | 41F77EAD | 00000308 |
                                        | 46 | 0C | 04 | 00 | 42EA35A6 | 42DE2D12 | 0000009F |
                                        | 47 | 0C | 05 | 00 | 43B974A6 | 43AD6B55 | 000000A8 |
                                        | 48 | 0D | 00 | 00 | 449B0BE6 | 448F01CF | 00000052 |
                                        | 49 | 0D | 01 | 00 | 4573FD66 | 4567F2DF | 00000041 |
                                        | 4A | 0D | 02 | 00 | 4644C9D9 | 4638BEF3 | 00000308 |
                                        | 4B | 0D | 03 | 00 | 471217FE | 470609F2 | 000001B8 |
                                        | 4C | 0D | 04 | 00 | 47F177AC | 47E567CA | 00000017 |
                                        | 4D | 0D | 05 | 00 | 48BA2EBC | 48AE1EA5 | 00000094 |
                                        | 4E | 0E | 00 | 00 | 49972C14 | 498B1B4B | 00000048 |
                                        | 4F | 0E | 01 | 00 | 4A681F04 | 4A5C0DD5 | 0000002E |
                                        | 50 | 0E | 02 | 00 | 4B30D516 | 4B24C39B | 0000000D |
                                        | 51 | 0E | 03 | 00 | 4BF62979 | 4BEA17D3 | 0000083D |
                                        | 52 | 0E | 04 | 00 | 4CD25B79 | 4CC64178 | 00000013 |
                                        | 53 | 0E | 05 | 00 | 4D933271 | 4D87183F | 0000004B |
                                        | 54 | 0F | 00 | 00 | 4E687C09 | 4E5C616E | 0000013A |
                                        | 55 | 0F | 01 | 00 | 4F3112DF | 4F24F6EC | 00000018 |
                                        | 56 | 0F | 02 | 00 | 4FF2486F | 4FE62C46 | 0000001F |
                                        | 57 | 0F | 03 | 00 | 50AF56DF | 50A33A79 | 000032FB |
                                        | 58 | 0F | 04 | 00 | 51841857 | 5177C8D8 | 0000298B |
                                        | 59 | 0F | 05 | 00 | 523E258F | 5231AC67 | 00002F94 |
                                        | 5A | 10 | 00 | 00 | 530BEF47 | 52FF466D | 00000049 |
                                        | 5B | 10 | 01 | 00 | 53D0C227 | 53C418E6 | 00000031 |
                                        | 5C | 10 | 02 | 00 | 548AF119 | 547E4789 | 0000002C |
                                        | 5D | 10 | 03 | 00 | 55420139 | 5535575F | 00005BA3 |
                                        | 5E | 10 | 04 | 00 | 560EBA1F | 5601B484 | 0000293E |
                                        | 5F | 10 | 05 | 00 | 56C1E8DF | 56B4B9E8 | 00004164 |
                                        | 60 | 11 | 00 | 00 | 57874724 | 5779D6AB | 00000145 |
                                        | 61 | 11 | 01 | 00 | 584267DB | 5834F5FF | 00000011 |
                                        | 62 | 11 | 02 | 00 | 58F914DB | 58EBA2D0 | 0000000A |
                                        | 63 | 11 | 03 | 00 | 59A903C3 | 599B9190 | 00000192 |
                                        | 64 | 11 | 04 | 00 | 5A6EA3F3 | 5A613010 | 00000023 |
                                        | 65 | 11 | 05 | 00 | 5B1B2FBB | 5B0DBB97 | 000000FC |
                                        | 66 | 12 | 00 | 00 | 5BD93F3B | 5BCBC9FD | 0000002A |
                                        | 67 | 12 | 01 | 00 | 5C8C5A13 | 5C7EE48D | 0000003C |
                                        | 68 | 12 | 02 | 00 | 5D3BDF3E | 5D2E695E | 0000000E |
                                        | 69 | 12 | 03 | 00 | 5DE8274C | 5DDAB140 | 00000217 |
                                        | 6A | 12 | 04 | 00 | 5EA295A4 | 5E951D63 | 00000090 |
                                        | 6B | 12 | 05 | 00 | 5F4774E0 | 5F39FBF1 | 000001A0 |
                                        | 6C | 13 | 00 | 00 | 5FFE1552 | 5FF09AA5 | 0000122A |
                                        | 6D | 13 | 01 | 00 | 60AA694E | 609CDC59 | 00001156 |
                                        | 6E | 13 | 02 | 00 | 6152EB80 | 61454D17 | 0000115E |
                                        | 6F | 13 | 03 | 00 | 61F85D28 | 61EAAD43 | 0000142F |
                                        | 70 | 13 | 04 | 00 | 62ABAD60 | 629DE92E | 00001153 |
                                        | 71 | 13 | 05 | 00 | 634A6ECA | 633C9927 | 00001949 |
                                        | 72 | 14 | 00 | 00 | 63F9C950 | 63EBDA46 | 00000048 |
                                        | 73 | 14 | 01 | 00 | 649F90DE | 6491A16E | 0000016E |
                                        | 74 | 14 | 02 | 00 | 6540EFCE | 6532FED2 | 00000051 |
                                        | 75 | 14 | 03 | 00 | 65DBF92F | 65CE07C4 | 00000328 |
                                        | 76 | 14 | 04 | 00 | 6688FC33 | 667B0782 | 0000000D |
                                        | 77 | 14 | 05 | 00 | 67211B2B | 6713264F | 0000451B |
                                        | 78 | 15 | 00 | 00 | 67C9245B | 67BAEA46 | 00000040 |
                                        | 79 | 15 | 01 | 00 | 6866D133 | 685896C0 | 00000024 |
                                        | 7A | 15 | 02 | 00 | 68FC8423 | 68EE496E | 0000001D |
                                        | 7B | 15 | 03 | 00 | 698F9AC5 | 69815FD5 | 00000321 |
                                        | 7C | 15 | 04 | 00 | 6A348DA5 | 6A264F76 | 000000FE |
                                        | 7D | 15 | 05 | 00 | 6AC4D97E | 6AB69A33 | 00008927 |
                                        | 7E | 16 | 00 | 00 | 6B6438E2 | 6B557052 | 00000084 |
                                        | 7F | 16 | 01 | 00 | 6BFB1BA6 | 6BEC5274 | 00000062 |
                                        | 80 | 16 | 02 | 00 | 6C88B836 | 6C79EE84 | 00000019 |
                                        | 81 | 16 | 03 | 00 | 6D13C176 | 6D04F78D | 000002A2 |
                                        | 82 | 16 | 04 | 00 | 6DB15835 | 6DA28B8C | 00000008 |
                                        | 83 | 16 | 05 | 00 | 6E3BF535 | 6E2D2866 | 00001B78 |
                                        | 84 | 17 | 00 | 00 | 6ED51035 | 6EC627D0 | 00000100 |
                                        | 85 | 17 | 01 | 00 | 6F601975 | 6F512FF2 | 00000057 |
                                        | 86 | 17 | 02 | 00 | 6FE78107 | 6FD8970F | 00000023 |
                                        | 87 | 17 | 03 | 00 | 706C722F | 705D87F6 | 00000270 |
                                        | 88 | 17 | 04 | 00 | 70FF932F | 70F0A668 | 00000016 |
                                        | 89 | 17 | 05 | 00 | 7181865F | 71729964 | 00003134 |
                                        | 8A | 18 | 00 | 00 | 72110FAF | 7201F162 | 00000DF2 |
                                        | 8B | 18 | 01 | 00 | 729600D7 | 7286D47A | 00000DA4 |
                                        | 8C | 18 | 02 | 00 | 7316BDB7 | 73078398 | 00001EE3 |
                                        | 8D | 18 | 03 | 00 | 73952337 | 7385CA17 | 00002213 |
                                        | 8E | 18 | 04 | 00 | 741F1227 | 740F96D6 | 0000325A |
                                        | 8F | 18 | 05 | 00 | 749B2C51 | 748B7E88 | 00008113 |
                                        • ahmedtou
                                          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                          by ahmedtou
                                          Hi everyone,
                                          help me please
                                          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                          I will share all the details with you, including the disc information.
                                          Code:
                                          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                          Current Profile: BD-R
                                          Disc Information:
                                          Status: Empty
                                          State of Last Session: Empty
                                          Erasable: No
                                          Free Sectors: 12,219,392
                                          Free Space: 25,025,314,816 bytes
                                          Free Time: 2715:27:17 (MM:SS:FF)
                                          Next
                                          08-27-2025, 08:49 AM
                                        • eccerr0r
                                          It's 2025: do you know where your 5¼" floppy drives are?
                                          by eccerr0r
                                          Oh wow.
                                          As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
                                          Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
                                          Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
                                          Weird. Seems the PC drive is having trouble clamping...
                                          07-07-2025, 12:49 AM
                                        • tarikabak
                                          PALIT RTX 3060 VRAM LOCATION
                                          by tarikabak
                                          Hello, one of the vrams of my palit rtx 3060 model graphics card is showing as faulty. I will replace the faulty vram with a new one, but I could not find out the locations of the vrams. Does anyone know the location map such as a0, a1, b0, b1?
                                          mats version 455.127. Testing GA104 with 20 MB of memory starting with 0 MB.
                                          Memory Errors on
                                          Read Error Count: 0
                                          Write Error Count: 410022
                                          Unknown Error Count: 0
                                          === MEMORY ERRORS BY SUBPARTITION ===
                                          SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
                                          01-13-2025, 09:21 AM
                                        • ChaosLegionnaire
                                          bug of the month: write caching setting for the hard drive in device manager
                                          by ChaosLegionnaire
                                          i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
                                          so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
                                          10-06-2019, 01:39 PM
                                        • vbogoev
                                          Lenovo S6000 won't turn on. Data recovery needed.
                                          by vbogoev
                                          Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
                                          Code:
                                          [PWRAP] pwrap_init_preloader
                                          [PWRAP] pwrap_init
                                          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
                                          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
                                          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
                                          [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
                                          [PMIC_WRAP]wrap_init pass,the return
                                          06-20-2023, 06:36 AM
