Different Types of Capacitor Mounting
This is a sticky topic.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    There are several different types of capacitor mounting configurations and also capacitor types. The most common type for motherboard applications is radial lead/radial wire ended.
    Aluminium Electrolytic Capacitors - Radial Lead
    An example : Panasonic FC capacitors which are radial lead. This means that they have two leads + and - coming out of the capacitor on the same end. The negative lead is the shorter one and also indicated by the stripe down the side of the capacitor which also shows a - symbol, repeated along the length of the capacitor. The photo shows capacitors as you would receive them new with the full length of leads that you can cut to size. These capacitors are Aluminium Electrolytic which means that there is probably two layers of aluminium foil which are separated by paper that is impregrated with an electrolyte gel. The layers are then wound and enclosed in an aluminium or plastic tube. You can clearly see in the photo the capacitor bungs at the bottom of the capacitor. On good capacitors like the Panasonic FC they are made of EPT (Ethylene Propylene Rubber) which is a synthetic material. On the bad capacitors for cost reasons, natural rubber is used. This gets hard with age and the failure of the electrolyte can bust the bung out of the bottom of the cheap caps, leaking electrolyte on your nice smd components.
    Axial Lead
    This means that one lead is at each end of the capacitor.
    Surface Mount Chip Type Capacitors
    Surface mount chip capacitors on an Asus video card. See their black surface mount seats which are at the bottom of each cap. The black mark on the silver top of the cap indicates the negative lead. The seat is also square at the negative side. It is not clearly apparent from the markings, who manufactured these caps. Why would they use these surface mount chip capacitors instead of normal radial lead capacitors? Well it is easier to place and solder them to the board with machines.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Surface Mount Capacitors
    Very small components which are soldered to one side of the board, either at the front or the back.
    The above image shows the ceramic smd capacitors positions with the numbers preceded with CB or C. The resistors position numbers are preceded with R.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Surface Mount Tantalum Capacitors
      As indicated by the orange arrows. They come in case sizes A,B,C,D,E. The small ones in the photograph are B and the larger one is D. The bar on the cap indicates the POSITIVE side. These were used in motherboards, graphics cards, lan cards etc. I did not see them used after geforce1 though.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        need help with this thread guys....
        • TheInfamousJerry
          • Jun 2005
          • 15
          Re: Different Types of Capacitor Mounting
          Free-Standing Capacitors
          These are very popular among AMD users. These suckers will power up to an Athlon XP 2400! Installation is simple, bolt the capacitor to the side of your case, preferrably with a U-bracket and weld the leads to the most convenient and accessable area!
          Note: Don't do this! This post was merely a joke! Neither me nor the board moderator nor owner should be held responsible if you wire a huge capacitor to your board, rendering it(and probably yourself) inoperable!
          I helped!
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            all jokes aside those large screw terminal types are commonly called computer grade.
            my imsai 8080 has 2 of them.
            the smaller ones in the center are snap ins.
            used in some pc psu.
            I helped!
            • arneson
              • Sep 2005
              • 1267
              Why the disclaimer saying not to do this?
              It's not merely a joke.
              I have lined the inside of my case with these big boys and she's stable.
              But it takes an hour for the power light to go off.
              Jim
              • PeteS in CA
                • Aug 2005
                • 3581
                • USA, Unsure of Planet
                One of the nicknames for a computer grade types is a "beer can" (though some are more the size of a V8 juice can. Some larger snap-ins have an extra terminal or two to improve mechanical stability.
                PeteS in CA
                • OldeCrow
                  • May 2005
                  • 18
                  if you don't want to power your computer with them they are fun at parties too
                  • triplelatte
                    • May 2006
                    • 10
                    I have something close to that in the trunk of my car. I use them to store power for my amps so when the bass hits my light don't dim. the brand is lightning caps and they pack a punch to them. a friend of mine damn near blew his hand off messing with his .
                    • Gendo Ikari
                      • Jun 2008
                      • 62
                      I accidentally knocked one of these off an old ISA 10Mb network card I got from a guy. I was wondering what the heck it was. At least I can maybe replace it now if I really want too.
                      • gonzo0815
                        • Feb 2006
                        • 1600
                        Tantalum capacitors.
                        • Moopy
                          • Jan 2015
                          • 1
                          I'm new here and was looking for a nice spot for my first post and stumbled across this thread of knowledge. I've seen tons of these types of capacitors but I never knew their technical names. Now I just need to learn about diodes.
                          • jentoris
                            • Jun 2015
                            • 48
                            • Indonesia
                            that yellow capacitor is the smaller size of caps and give you the most stabel power output than the other caps pictured, and also it's more expensive.
                            • MORETTIGIAN
                              Capacitor detached from PCB – RTX 2070 Super Founders Edition
                              by MORETTIGIAN
                              Title:
                              Description:
                              During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                              I did not notice it detaching, so I am unsure of its original location on the PCB.
                              Procedure performed:
                              - Removed backplate
                              - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                              - Reapplied thermal compound
                              - Reassembled card
                              Observed behavior after reassembly:
                              - GPU powers on and operates normally under...
                              09-18-2025, 12:14 PM
                            • Prolog
                              RTX 3080 FE Identifying capacitor
                              by Prolog
                              Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                              I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                              I hope these photos make it clear which component I am referring to:
                              (yes, the soldering is a bit botched from removing the blown one, I know)
                              I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                              12-01-2024, 08:27 PM
                            • Agent24
                              Dick Smith Q-1760 linear power supply filter capacitor question
                              by Agent24
                              I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                              It has at least one problem.
                              The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                              I have already ordered a replacement potentiometer, so that's not an issue.
                              Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                              All are CapXon...
                              10-21-2025, 05:39 PM
                            • chth96
                              If I replace with inferior capacitor, Is it No harm to other IC components at all?
                              by chth96
                              I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                              Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                              It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                              So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                              I know that these capacitor will not last as long as nichicon capacitor...
                              12-22-2023, 04:34 AM
                            • chth96
                              How can I test non-polarized capacitor?
                              by chth96
                              I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                              I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                              And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                              I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                              06-02-2024, 07:31 PM
