Dell laptop LA90PE0-01 charger repair
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. This may seem like a pointless thing to try and repair, but I've got a dead original DELL slim charger which I'm trying to fix and I figured it might be something others have stumbled upon, given that DELL is a fairly popular brand which others are likely to own. The model is LA90PE0-01 and the issue is simple: it doesn't output anything at all. I took it apart and after hours of fighting with that white silastic sh!t they felt the need to "paint" the whole board with, I eventually uncovered the board enough to take some measurement: I get around 325v on the main cap and 15 to 20v on pin 1 of the IC (goes up and down). This is where it gets slightly complicated and over my head: the IC is a LTA804N which controls BOTH the PFC circuit and the main switching one. I could not find too much about this thing, however I did find one source which says it's identical to TEA1751 (datasheet here). I was also lucky enough to find the schematic for the whole adapter here. Following along with the schematic and the pinout as best as I could, I do get some volts on pin 1 VCC of the IC, but nothing else elsewhere...I don't know if it's even pulsing those FETs on and off, because I don't have an oscilloscope to measure the gates The overcomplicated nature of that IC is also annoying. Resistors seem fine, except for one of the 1504 (1.5 megOhm, bottom left of schematic, which seems to be reading too low - only 800kohms). Already replaced C054, since it's in parallel with the VCC pin of the IC which sometimes causes issues, but it didn't change anything....any help would be greatly appreciated
    Wattevah...
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Re: Dell laptop LA90PE0-01 charger repair
    Also, I've just read that some other guy (from Poland I believe) was having the same issue, but when he tried probing the primary of the transformer (the one in the top right in my pictures), the power suddenly came on, so it could also be a bad joint somewhere which perhaps makes contact when he applied slight pressure with the probes.....haven't tried reflowing the thing yet....that would be one hell of a fix
    Wattevah...
    • cpt.charlie
      • Sep 2013
      • 270
      • Spain
      Do you have HV at pin 16?
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        I get 326v on pin 16
        Wattevah...
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          Also, I get 3.5v on pin 7 which is the VINSENSE pin. According to the datasheet for the TEA chip, that should be enough to start it.
          Wattevah...
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8352
            Resistors when they fail don't go 50% lower in value. They always go higher or open. So put that 1.5 M Ohm resistor back in. Could very well be that there is a bad solder joint and power isn't getting there where it is needed. Had bad solder joints on transformers before. I've also seen my share of a broken leg (broken flush on the top side of PCB) filter inductors even so they were glued. You would have to examen things.
            You said you do get some volts on pin one of the TEA1751. What exactly do you get? Look at the schematic. There is a startup cap 35V 47uF.
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              I've just fixed it The issue ? A 0 ohm "jumper" resistor had gone open circuit. It's the one next to the optocoupler in the schematic (to the right of the main IC). I was following the traces for the optocoupler according to the schematic, until I reached that 0 Ohm jumper where continuity suddenly stopped. I pulled it out, measured it and indeed it read 2 megOhms - WAY above the intended value. I replaced it with an ordinary piece of wire and tried it out - works perfectly. Sadly, I was too excited about my victory to take some measurements and post them here to hopefully help other chaps who might run into this issue, but bottom line is: replace the small cap for the VCC pin of the IC and check all resistors, starting with that 0 ohm one. Cheers
              Wattevah...
                • Jul 2011
                • 6070
                I would put in one those resettable fuses
                I will post a photo of one later
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8352
                  Yeah... I had another look at the schematic. If that 0 ohm resistor went open or high in value, it will sour your day quickly. As sam_sam_sam stated, they used that 0 ohm resistor as a fuse.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    Ok, but (so far at least), nothing's really complaining...it might fail again sooner or later though. What exactly is that "fuse" protecting and what was its cause of failure ? I see it's in series with the AUX winding, but I couldn't find any shorts - none at all...
                    Wattevah...
                      https://www.badcaps.net/forum/attach...1&d=1485884098
                      Can you show us where that '0' Ohms resistor on the is?
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        Above the top-right corner of the PFC inductor (that's the yellow square at the bottom in the picture you linked), there's a hole - you can see a "0" right above that hole, placed vertically in the picture. Sorry, I didn't feel like downloading the pic again and marking it in MS Paint
                        Wattevah...
                          OK, I see that now.
                            • Jul 2011
                            • 6070
                            This is the kind of fuse that I was taking about
                            Polyswitch Resettable Fuse 170mA 120V 2 Pin bel0017RM PTC | eBay
                            For some reason the link doesn't work
                            • delaware74b
                              • Apr 2009
                              • 628
                              Did you reflow the broken solder joint I circled on the back of the board?
                              Stupidity should be a crime, especially for drivers. I have NO patience for them.
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                • Romania
                                Yes I have. I've actually reflown MANY other joints for good measure
                                Wattevah...
                                • eckibear
                                  • Jan 2019
                                  • 1
                                  I found this blog very helpfull, thank you guys!
                                  I've encountered yet another zero-Ohm "fuse" in my power supply of this type. This 0R resistor does not appear in the schematic. It is placed between the upper winding of Transformer T050 and the anode side of diode "JSW" & R-52k3, on the very top of the schematic. It is marked up by the yellow circle below (the red circle shows the zero Ohm Resistor/"fuse" discussed above).
                                  BTW.: My supply was way more filled up with the white silicon putty, hardly any area was left open. I guess it had been very cheap on that day of manufacture.
                                  Cheers,
                                  eckibear
                                  • MPFI
                                    • Oct 2019
                                    • 3
                                    • Argentina
                                    I just registered to thank you for the solution. It helped with my DELL charger as well. Done some measurement. I concluded that the chip was good since the PFC was OK, I got 300V no problems. but measuring arund the optocouples ... got lost. I found a 0 jumper opened. Wondering if the boar design, that has two major holes to fit the low profile transformers (on coil and one transformer) just weakened the board and could crack SMD components. Could be the reason for the silastic flood (YES ... I spent a lot of time cleianing this LOL).
                                    Many thanks !!!!
                                      • 31304
                                      those resistors are used to pass over other tracks, it's possible the person who designed that forgot to take into account how much current was flowing when they chose the resistors.
                                      • MPFI
                                        • Oct 2019
                                        • 3
                                        • Argentina
                                        Could be, but in this case are related to the optocoupler cricuitry (output side) I dont tink that the current could be that high.
                                        • BTubbs200
                                          Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                          by BTubbs200
                                          Dell Latitude 5420 P137G
                                          Board: LA-K491P REV A01
                                          I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                          Board seems to have no shorts, all power rails are fine and show high resistance.
                                          When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                          01-24-2025, 08:15 PM
                                        • Johndill
                                          Dell Inspiron 7567 LA-D993P odd charger issue
                                          by Johndill
                                          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                          Here are the tested scenarios:
                                          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                          2. With the laptop off, plug in charger (LED says on) & the front charging...
                                          11-16-2022, 10:55 PM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • PowerAmpFreak
                                          Dell Latitude 7280 does not recognize charger
                                          by PowerAmpFreak
                                          I have a Dell Latitude 7280 which complains during boot-up that the charger wattage cannot be determined. Tested with two different chargers.
                                          Any common faults that could be fixed?
                                          I replaced the DC jack, the original DELL LATITUDE 7280 DC30100Z300 0DP4VC.
                                          How does the communication between the charger and the PC work?...
                                          07-28-2025, 07:18 AM
                                        • exerion5000
                                          DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
                                          by exerion5000
                                          Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
                                          below normal, as if it were operating in an extreme energy...
                                          10-15-2023, 02:12 PM
