Fluorescent desk lamp repair
  • caphair
    • Nov 2011
    • 1249
    Turned it on and heard a loud pop, opened it and a small 10uf 50v electrolytic capacitors had blown up.
    Is it safe to replace with a higher value like 47uf 100v? Or does it have to be exact value of old?
  • kamel84
    • Feb 2016
    • 9
    • islam
    Re: Fluorescent desk lamp repair
    thank you
    • petehall347
      • Jan 2015
      • 4429
      • United Kingdom
      i would put a regular ballast in and starter if it doesn't already have one . less to go wrong
      • petehall347
        • Jan 2015
        • 4429
        • United Kingdom
        just for fun here is an idea to use lamps that look worn out but arent . can be used on good lamps too .
        • redwire
          • Dec 2010
          • 3912
          That capacitor is probably for limiting base-drive, so if it popped I think a transistor is shorted. Usually the lamp fails open circuit and then the PSU dies.
          These schematics are similar to your circuit but not exact - it's a two transistor resonant oscillator. The Philips/Osram one has no 10uF 50V cap.
          I don't see filament connections in that desklamp, only 2-wires leaving the PSU.
          • caphair
            • Nov 2011
            • 1249
            Thank you. So could I use a higher value capacitor or has to be exact?
            • redwire
              • Dec 2010
              • 3912
              I say you can use a larger value OK. But it will pop... larger... If the transistors are bad.
              • caphair
                • Nov 2011
                • 1249
                Tried one nothing happened, no light as well. Does that mean transistors are ok since it didn't blow?
                Curious when is the exact capacitor value replacement necessary? What circuits can't be altered by higher capacitor values than original
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  petehall347, I'm sorry, I'm tired of those magnetic ballasts that flicker at 100/120 cycles/second... The electronic ballasts, though quite a bit more fragile, are smaller, lighter, more power efficient, and usually starts lighting faster.
                  caphair, likely you will have to carefully check each of the transistors for shorts, as well as making sure the input fuseable resistor didn't fry. Unfortunately all of the electronic ballasts I've had when they do go, tend to fry transistors and then input circuitry - a big domino effect.
                  • caphair
                    • Nov 2011
                    • 1249
                    Why are fuseable resistors used and not regular fuses?
                    • cpt.charlie
                      • Sep 2013
                      • 270
                      • Spain
                      Resistors are cheaper than proper fuses.
                      • petehall347
                        • Jan 2015
                        • 4429
                        • United Kingdom
                        might not flash the same running off dc voltage . i have to try it soon so will let you know if it works out ok .
                        we are on 50hz here so its worse for me .
                          Why fusible resistor?
                          http://powerelectronics.com/passive-...t-applications
                          The flickering rate will be 100 Hz,
                          Electronic ballast uses much higher frequency.
                          • caphair
                            • Nov 2011
                            • 1249
                            Revisiting this. Changed the cap and one of the transistors previously and it worked all this time.
                            Just recently quit again, this time no caps blew up and no shorts on the transistors or diodes or any of the caps (tested in ohms settings)
                            Any suggestions? I should just replace it but curious to get it going again
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              did the tube go this time?
                              • caphair
                                • Nov 2011
                                • 1249
                                Yes but even after replacing it's not working
                                • caphair
                                  • Nov 2011
                                  • 1249
                                  How many volts should I see at the lamp terminals when first powered on? I’m measuring 126v then drops to 86v
                                  Does that mean the circuitry is working and possible bad replacement lamp?
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    OCV it should be really high and then drop down fast when the light strikes. 126V seems a bit low depending on the length of the tube.
                                    • caphair
                                      • Nov 2011
                                      • 1249
                                      What would cause it to be low? The tube is small and circular probably 12” give or take
                                        • 31139
                                        strike voltage probably comes from an inductor or cap discharging
                                        • eccerr0r
                                          desk lamp stopped working... stars?
                                          by eccerr0r
                                          How many bcn readers does it take to screw in a light bulb into my LED desk lamp?
                                          Answer: None. This is a nonreplacable-LED desklamp.
                                          So this lamp has one of those aluminum stars and an LED on it. It appears to be some sort of BGA or something with pins underneath. Anyway the PSU is 500mA 3.6V-8V meaning this probably was either meant to massively overdrive 1W LEDs or slightly over drive 3W LEDs...
                                          So it seems that typical 1W LEDs on stars are indeed 3.6V @ 300mA to get 1W which would be overdriven at 500mA, and 3W LEDs appear to be 3.6V@700mA which is a...
                                          10-01-2020, 12:45 AM
                                        • aneng
                                          What kind of desk lamp / magnifier do you use ?
                                          by aneng
                                          Hi.
                                          I need to get a bright desk lamp for working on PCBs and I'm wondering what is considered the best type to get for this kind of work ?
                                          I see there are a lot of magnifier type lamps with ring lighting, but the magnification is usually only 5x, which I don't think is going to be enough for SMD work, though it might be OK for larger components / general use.
                                          There are also the long LED strip kind.... which seem like they might be good.
                                          I think that either way, I want to go with a swing-arm type ('anglepoise' type) rather than a gooseneck...
                                          03-25-2021, 04:47 AM
                                        • vestaviascott
                                          Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                                          by vestaviascott
                                          Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                                          Here's what happens:
                                          1) Power on
                                          2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                                          3) Blue status light flashes for appx 4 minutes...
                                          07-29-2020, 06:08 AM
                                        • AJ847.63e
                                          BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                                          by AJ847.63e
                                          Hi All.
                                          Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                                          The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                                          09-18-2023, 06:42 PM
                                        • mikey5791
                                          Help on Samsung Syncmaster T220 dead ccfl lamp
                                          by mikey5791
                                          This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                                          Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                                          10-18-2020, 03:17 AM
