LG Flatron L1750S - Stopped to work
  • rf.pereira
    • May 2017
    • 16
    • Brazil
    My old LG L1750s stopped working some time ago: it doesn't turn on anymore (even the power LED) and only emits a noise that I'll explain in a moment.
    I oppened it to try to figure out the problem, but I didn't found any bad capacitor or something "strange" visible. Even so, I started to follow the steps done in this thread, but changing the capacitors didn't solved my problem.
    But I observed something unusual: when plugged, the monitor emits a clicking noise that stops for a little time if I disconnect the mainboard from the PSU. Along with that, the output voltage of the pins in CW201 decreases a lot when the mainboard is plugged again: from ~4.9V to ~2.3V and from ~13V to ~7.5V.
    Some data:
    - C101 working normaly;
    - jumping pins 1 and 5 in U101 shows normal behavor;
    - changed 7 capacitors: C206, C202, C204, C205, C203, C105 and C103;
    - some pins in CW201 have ~4.8V and others ~13V (unplugged mainboard);
    - I couldn't identify which component is emitting the noise;
    - PSU model: AIP-0108 REV:02 (Lien Chang)
    Thoughts on where to continue?
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: LG Flatron L1750S - Stopped to work
    You didn't replace C207 (I guess, the green one)? You should try to replace it too.
    Also you should check for a short to ground on the motherboard power connector's pins.
    • rf.pereira
      • May 2017
      • 16
      • Brazil
      Thank you for your replay.
      Yes, I didn't change that one because I don't have the exact same model (470uF - 25V). But I have one that is 470uF - 16V, will it do the job?
      Sorry, but how do I check for a short on the motherboard?
      And how about the noise? It isn't normal, is it?
      Thanks.
      • piernov
        • Jan 2016
        • 4437
        • France
        No it won't do the job, you can only replace with the same or higher voltage rating. You can use a similar or higher capacity(uF) rating, not too high though. Another 25V 680uF would do the job, or even a 1000uF.
        To check for short, put your multimeter in resistance mode (200ohms scale if it's not auto-ranging) put red probe on ground and black probe on each of the pins of the power connector (on the motherboard, not power supply board) and write down the value.
        The clicking noise could be the PSU trying to turn on. It could mean there is an issue with the motherboard or backlight circuit.
        • rf.pereira
          • May 2017
          • 16
          • Brazil
          Ok, I will change C207 using a 680uF 25V.
          If I did it correctly (I attached a photo), the results were (starting to count from the closest pin to ground):
          Code:
          pin1- 1
          pin2- 1
          pin3- 1
          pin4- 1
          pin5- 00.7*
          pin6- 1
          pin7- 1
          pin8- 00.8*
          pin9- 00.8*
          pin10- 1
          pin11- 1
          * - shorted
          Thanks.
          • piernov
            • Jan 2016
            • 4437
            • France
            pin 5, 8 and 9 are probably ground points so it should be fine. To make sure of that, you can check on the power supply board side, you should be getting the same results.
            Are the voltages on the connector steady when the mainboard is plugged in?
            • rf.pereira
              • May 2017
              • 16
              • Brazil
              Without any power on the PSU, I measured in it:
              Code:
              pin1 to pin4- 1
              pin5- 00.5
              pin6- 116.7
              pin7- 115.9
              pin8- 00.5
              pin9- 00.5
              pin10- 116.7
              pin11- 116.7
              Now, with the PSU (have yet not changed the C207) and mainboard connected and turning on, I measured in the PSU:
              Code:
              pin1- 1.81 to 2.01V
              pin2- 1.72 to 1.91V
              pin3- 1.78 to 2V
              [B]pin4- 0V[/B]
              pin5- 0V
              pin6- 1.83 to 2.03V
              pin7- 1.8 to 2V
              pin8- 0V
              pin9- 0V
              pin10- 7.83V
              pin11- 7.83V
              This oscillattion isn't normal, is it? And pin 4 has no output voltage, unexpected too...
              • rf.pereira
                • May 2017
                • 16
                • Brazil
                After changed the C207, with the PSU and mainboard connected:
                Code:
                pin1- 0V
                pin2- 2.37V
                pin3- 0.02V
                pin4- 0V
                pin5- 0V
                pin6- 5.02V
                pin7- 5.02V
                pin8- 0V
                pin9- 0V
                pin10- 14.54V
                pin11- 14.55V
                The clicking noise desappeared, but pin1 to 4 still with a strange behavor... and the monitor still not turn on.
                • piernov
                  • Jan 2016
                  • 4437
                  • France
                  Ok so now you've got a nice 5V rail (pin 6/7). However the 12V doesn't look good, 14.5V instead of 12V is relatively high. I'm not sure why it would behave like that.
                  Service manual and PSU schematics attached.
                  Service manual page 29, connector J705 seems to be your power supply connector.
                  So your pin 4 (NC) is not connected, nothing to worry about.
                  Pin 2 (DIM) should be a PWM signal so I think that's OK.
                  Pin 3 (INV) should be 5V for the backlight to turn on.
                  Not sure about pin 1 (LAMP)
                  Can you measure voltage on the component right to the power connector on the mainboard? (U801 I guess)
                  PS: your pin numbering is reversed compared to the service manual.
                  • rf.pereira
                    • May 2017
                    • 16
                    • Brazil
                    Thank you for your feedback.
                    U801 (KIA 78D33F) -
                    Code:
                    5.02V (IN)
                    3.35V (OUT)
                    Could C207 capacitor (680uF instead of a 470uF) causing this 14.5V?
                    I had a problem with C105 (lifted pad) but I think I managed to solve. But I'll recheck my solders.
                    • rf.pereira
                      • May 2017
                      • 16
                      • Brazil
                      Any idea?
                      Is there a way to confirm if the PSU is working properly? Maybe some website that shows the correct voltages to each pin?
                      • rf.pereira
                        • May 2017
                        • 16
                        • Brazil
                        Without the mainboard conected, measuring the pins (using the correct numbers):
                        Code:
                        pin#: voltage
                        p11: -0.03V
                        p10: 0V
                        p09: 0V
                        p08: 0V
                        p07: 0V
                        p06: 4.9V
                        p05: 4.9V
                        p04: 0V
                        p03: 0V
                        p02: 13.6V
                        p01: 13.6V
                        Could be this difference observed between this values and the ones from the post #8 the indicative of something or is just the normal behavior?
                        • piernov
                          • Jan 2016
                          • 4437
                          • France
                          It looks ok, except the 13.6V but it might be normal. I know that some PSU have 14V on the 12V rail and it's perfectly fine. Or you have another bad capacitor on the 12V rail.
                          Anyway, check voltage on pins AVDD, VDDC, VDDP, HWRESET of U201 (see page 26 of the service manual I posted above).
                          Check that you've got 3.3V on the power button and that it goes to 0V when you press it.
                          Check voltage on VCC and RST pins of U501 (p. 27).
                          Check voltage on pin 1 of the panel connector (p. 29 J704?)
                          • rf.pereira
                            • May 2017
                            • 16
                            • Brazil
                            ---- U201 ----
                            AVDD (pin28)- 3.31V
                            VDDC (pin50)- 1.75V
                            VDDP (pin47)- 3.36V
                            HWRESET (pin96)- 1.71V
                            ---- Power button ----
                            5V on the top 2 legs;
                            When pressed, goes to 0V.
                            ---- U501 ----
                            VDD (pin8)- 5.00V
                            RST (pin7)- 5.00V
                            ---- J704 -----
                            Couldn't find it.
                            The connector that goes to panel (LCD) (J702):
                            0V in all of the pins.
                            • piernov
                              • Jan 2016
                              • 4437
                              • France
                              Check voltage on pin 1 and 3 of Q502.
                              • rf.pereira
                                • May 2017
                                • 16
                                • Brazil
                                Q502 - kia7042ap
                                4.29V (first and third pins)
                                5.03V (first and second pins)
                                • piernov
                                  • Jan 2016
                                  • 4437
                                  • France
                                  0.74V between 3rd pin and ground then? Q502 could be bad. Try to remove Q502 and put a capacitor between base of Q503 (pin 1) and ground, 33uF/6.3V at least I would say, then check if the monitor turns on.
                                  If it doesn't, check voltage on RST pin again.
                                  If it does, replace Q502, the capacitor is just a temporary workaround to check if the rest of the circuit would work.
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    That high 12v is normal for a monitor when the inverter is not running. They have pretty lax tolerances. Do you get a green light when you push the power button or do you get nothing?
                                    A working TV? How boring!
                                    • piernov
                                      • Jan 2016
                                      • 4437
                                      • France
                                      @Th3_uN1Qu3 thanks for the info about the 12V, didn't know that even though I've already seen it. His µC is stuck in reset so he must not get any response at all. This is an active high reset btw, I already did that mistake too…
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        • Romania
                                        There's a reason they put 25V caps on it you know.
                                        To expand a bit on this, what happens is that the feedback in a monitor PSU is taken from the 5V rail alone, it is not even group regulated like cheap computer PSUs are, the output filter inductors for 5V and 12V are separate.
                                        So the 12V rail is not actually regulated at all. In practice this works fine because the inverter is regulated (thus a variation of the 12V rail will not affect brightness) and the load distribution is chosen so that under normal operating conditions the 12V rail will be reasonably close to that value. When the inverter is not running (no load on 12v), it will rise fairly high, 13-14 volts is not uncommon and nothing to worry about.
                                        • tony359
                                          by tony359
                                          11-28-2023, 05:18 AM
                                        • MegaZAC
                                          Onkyo TX-SR805 noise in one channel
                                          by MegaZAC
                                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                          There's some logic behind it. As soon as I select an input I get only left...
                                          04-23-2025, 10:09 PM
                                        • courtcircuit
                                          Philips HTS8000 home cinema noise problem
                                          by courtcircuit
                                          Hello
                                          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                          Removed each of tyhe boards
                                          02-08-2025, 08:22 AM
                                        • karatzdi
                                          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                          by karatzdi
                                          I know some might say... just buy another one. Sell it as parts..!
                                          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                          Spent some time downloading the Service...
                                          06-11-2024, 08:38 AM
                                        • flat-earther
                                          HP F4180 stopped working please help troubleshoot
                                          by flat-earther
                                          I was doing a large print job with my HP Deskjet F4180, and after about 50 pages the printer stopped in the middle of a page and the black ink light started flashing.
                                          So I went to refill the black ink cartridge with a syringe, but found out it still had a lot of ink.
                                          I tried to print a page again but every time it would print only a bit of the page and immediately stop with the black ink light flashing again.
                                          I tried two other black ink cartridges, and the problem still endured, so I knew this problem had to be with the printer itself.
                                          I ran HP Print and Scan...
                                          05-11-2025, 02:21 AM
