bios yoga2 11 nm-a201
  • alirafee
    • Jun 2015
    • 94
    • iran
    hi
    i need bios lenovo yoga 2 11
    nm-a201
  • andrew25
    • Feb 2016
    • 224
    • Malawi
    Re: bios yoga2 11 nm-a201
    i need too... did you find it
    • mrodriguezjurado
      • Jan 2014
      • 4
      • Argentina
      testeada ok
      • fharlock999
        • Nov 2017
        • 62
        • Chile
        thanks!
        • gerardo
          Engineer
          • Feb 2016
          • 59
          • Argentina
          Originally posted by mrodriguezjurado
          testeada ok
          Thanks you!
          • Blackam8899
            • Sep 2020
            • 45
            • Rosario
            testeada ok
            OK
            • Blackam8899
              • Sep 2020
              • 45
              • Rosario
              Does anyone have the ec for this equipment?
              • to5it0
                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                by to5it0
                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                I have opened the laptop and identified the main BIOS chip...
                10-24-2025, 01:35 AM
              • lucaszmn
                Summary of BIOS Whitelist Removal Problem Lenovo Thinkpad T560
                by lucaszmn
                Problem:
                I am attempting to remove the WWAN card whitelist from my Lenovo ThinkPad T560.
                Initial Findings:
                • My current BIOS version is N1KET58W (1.45).
                • I have a CH341A programmer and have successfully created two full backups of my BIOS.
                • I have the ability to use command-line tools on a Linux machine.
                Troubleshooting Steps & Conclusions:
                • I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
                • I concluded that the
                08-12-2025, 03:01 PM
              • AYsys
                Lenovo Yoga X1 Gen4 - Faulty Bios or what is going on?
                by AYsys
                Hello dear forum members,
                I own two Lenovo Yoga X1 Gen 4 laptops. One of them had a touchscreen problem, and I tried to fix it by externally flashing the BIOS. Unfortunately, I didn’t save the original BIOS and accidentally flashed it with a faulty one. After that, the device stopped working completely.
                I then had the idea to make a BIOS backup from the other Yoga X1 Gen 4 (same hardware) and flash it onto the non-working device.
                Nothing was flashed here — the BIOS was only backed up.
                I created the backup using a CH341A Black programmer and NeoProgrammer....
                09-13-2025, 11:05 AM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
              • HotSaladMan
                Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
                by HotSaladMan
                *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
                Model : Lenovo ThinkBook 14S Yoga ITL
                S/N : MP28JT19
                MFG Date : 2022/02/09
                Factory ID PRC4
                MO : MPNXB26080FX
                MTM : 20WE001US
                MODULE FCC ID : PD9AX201NG
                IC : 1000M-AX201NG
                BOARD INFO
                FLV34 LA-KO51P
                REV : 1B 2020-08-24
                Bit of Info
                Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
                chip id, so i would always uncheck the id check, so it would bypass the error
                i did in fact make...
                11-07-2024, 07:46 AM
