looking for asus ux32vd rev 2.1 bios dump, loptop stuck on asus logo so maybe bios reprograming gonna help, plz share if someone have
Re: looking for asus ux32vd rev 2.1 bios dump
Dump from nb with faulty video, UX32VD rev 2.2Attached Filesif you find these attachements useful please consider making a small donation to the site
On this model is common a pch issue, look at its corners to see if glue is firmly in place or it's easy to removeComment
Every donation made will go towards server fees and maintenance costs.Comment
Asus UX32VD main board Rev. 2.1 original bios dumb.
Macronix 25L6445EAttached Filesif you find these attachements useful please consider making a small donation to the site
by mkdjDear all,
I have a ASUS ZenBook UX480F with the following symptoms:
I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
by DynaxSCHi,
I have a serious problem to program the Z590 chipset SRAM with a Management Engine after replacing the chipset.
The new chipset is factory new and is not containing any Management Engine. Any attempts to program it into the chipset under Windows ends with a failure (eg. Error 20: Management Engine Device not present, or something similar).
Due to the lack of the ME several ports on the board, including all M.2 ports aren't working, booting OS works only on USB. So it's now other way, as to program the chipset with a ME.
Usually on ASUS boards it worked...-
Channel: BIOS & Schematic Requests!
by AhariHi all,
I...-
- Loading...
- No more items.
