Need help with ASRock AB350m
  • gmorb
    • Sep 2017
    • 38
    hey guys i have this asrock mobo i am trying to fix. thing wont turn on so i need a schematic and boardview for it. i believe i found the chip responsible for the short but i have no idea if im chasing the correct thing here. Anyone here have that or any info on where I can get it?
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Need help with ASRock AB350m
    I doubt you will find a full-blown schematic - at least I never bother as it's more effort than just "getting on" with the board and testing components.
    Regarding the issue: by not turn ON, what do you mean exactly? Nothing happens when you press the power button or do the fans in the PC twitch for a second and PSU go into short-circuit protection?
    • gabrieljma1
      Request: Full BIOS dump for ASRock Z790-CX (DDR5)
      by gabrieljma1
      I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
      The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
      I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
      10-08-2025, 03:32 PM
    • DOBBELDUNK
      NEED Bios File ASROCK H61M-VS4 REV.G/A 1.01
      by DOBBELDUNK
      Mobo turn on, HSF on but no display, blank only in monitor.
      Here is bios backup of asrock h61m-vs4 rev. g/a 1.01
      11-20-2025, 10:07 AM
    • Exim
      ASRock N100M, no picture no boot, but semi-alive
      by Exim
      Hi guys,
      I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
      ASRock N100M special features:
      - CPU soldered to board, small Intel 12th gen
      - iGPU
      - four POST LEDs
      Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
      I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
      Symptoms:
      - no picture/signal on any of the display connectors,...
      04-01-2025, 02:36 PM
    • nolaryie
      BIOS .bin file for ASRock B450M Steel Legend
      by nolaryie
      Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
      I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
      Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
      If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
      Thank you!
      08-06-2025, 12:01 PM
    • khanhtq0
      Full BIOS Dump for ASRock H310M-HDV Rev 1.02 (MX25L12873F)
      by khanhtq0
      I'm looking for a full BIOS dump (.bin) for the ASRock H310M-HDV Rev 1.02 motherboard. The BIOS chip is a MX25L12873F (128Mb / 16MB).
      I’ve already tried flashing the official BIOS from ASRock (version 1.40 and 3.30), but those are Instant Flash versions and don’t include the full SPI image (e.g. Intel ME Region, Descriptor, etc.). After flashing, the board powers on only when I short PS-ON to ground, and it fails to generate Vcore and 2.5V. Other rails like 1.05V and RAM voltage are present.
      I suspect the original Intel ME and descriptor...
      08-06-2025, 02:14 AM
