Sharp LC-70C8570U
  • nelson6861
    • Jul 2016
    • 67
    Sharp LC-70C8570U
    I have a sharp tv with a blink code of 2 blinks and 5 flashes. I have no back lights when it is powered on.
    I removed the back and tested all back light. They all work.
    I took reading and it seem everything points to the main board. Any help... im also thinking i will need schematics for this tv and a reset to get rid of fault code.
    The tcon board looks like it had some thermal issues from pictures
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Sharp LC-70C8570U
    1st of all how did you test the backlights did you remove the LCD panel in physically power the backlights with a dmm?
    If you look on this forum you will see many postings about faults with sharp LCD TV's especially the 70 Inch panel. When you 1st power the TV do you get a solid light light before the 2 - 5 Flash? Do you see any indication of the back lights coming on even briefly before shutdown? Also we would watch your monitor voltage to the tcon. you should be getting 12 v to the connector
    • attainteddragon
      • Apr 2013
      • 764
      • australia
      pin 15 stby voltage is present, but pin 14 ps/on command is missing.
      so right now you are not getting your on command from the main board to turn on the ps.
      WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
      • freakaftr8
        • Oct 2012
        • 3743
        Hold down ch+ vol- power while plugging it in. Or try ch- vol+ power.
        • budwich
          • Jul 2015
          • 3097
          if your attempted "power checking" was done with the tcon disconnected as shown in your pictures, then it is unlikely that you will get "ps-on"... you need to have at least one "side" of the tcon connected to something (ie. two cables).
          • freakaftr8
            • Oct 2012
            • 3743
            I believe sharp tcon will function without the panel connected is long as a tcon is connected
            • nelson6861
              • Jul 2016
              • 67
              I have a led backup light tester for leds.
              I removed led and tested then individually.
              When i power on tv, i got nothing from panel no lights.
              I tried the fault re set combo but may be im doin it wrong.
              • nelson6861
                • Jul 2016
                • 67
                Also plugged tcon board back in...
                Measure 0v tcon connection on main board also
                • nelson6861
                  • Jul 2016
                  • 67
                  Sorry.. i miss spoke..
                  No 0v on tcon board should be 12v
                  • nelson6861
                    • Jul 2016
                    • 67
                    I am suspecting main board....
                    Any schematics or where i might find...
                    This board is expensive and hard to find...
                    Dkeymf953fm01... or would fm06 or other versions work
                    • nelson6861
                      • Jul 2016
                      • 67
                      Ok retested and used the right fault reset
                      Vol down and input..
                      Had 12v on tcon board....
                      • nelson6861
                        • Jul 2016
                        • 67
                        Green led light is flashing on main board...
                        I am goin to retest power supply point..
                        Still same fault code 2/5 no leds light up and they were tested good
                        • nelson6861
                          • Jul 2016
                          • 67
                          Ok results from power supply reading.
                          Also reading from Led connector 83 volts.
                          This is with power ON condition
                          • nelson6861
                            • Jul 2016
                            • 67
                            Ok new reading from bridge rectifier and regulators on the board... i think i am getting close
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              Okay all this is going on with the panel connected to the T con or not?
                              • nelson6861
                                • Jul 2016
                                • 67
                                Yes all connections are made on tv
                                • nelson6861
                                  • Jul 2016
                                  • 67
                                  Yes t con board is connected
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Ok try the same procedure with all 4 ribbons disconnected from tcon to panel. That you will still have the tcon connected to mainboard Then try just the left two thenr the right two
                                    • nelson6861
                                      • Jul 2016
                                      • 67
                                      Ok i will
                                      • nelson6861
                                        • Jul 2016
                                        • 67
                                        Right ribbon cable disconnected /left connected to t-con board.
                                        -no fault code flashes
                                        -no picture or backlights
                                        Left ribbon cable disconnected / right connected to tcon board
                                        - 2/5 flash fault code
                                        - no picture or backlights
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • joblo37pam
                                          Sharp LC-80LE844U Blinks 2 slow, 5 fast
                                          by joblo37pam
                                          It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
                                          The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
                                          10-26-2023, 02:17 PM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • koby058
                                          vostro comes up with back light but no picture
                                          by koby058
                                          Hi people!!
                                          The owner said it showed bad picture once in a while (attached)
                                          I see that there is back light but no picture.
                                          I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                          Also attached schematic and BDV
                                          LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                          07-13-2025, 01:03 PM
