clevo 6-71-W54C0-D03 need schematics
  • sourcebf
    • Jul 2016
    • 433
    • N/A
    Please I need schematics diagramme for Clevo 6-71-W54C0-D03
  • sourcebf
    • Jul 2016
    • 433
    • N/A
    Re: clevo 6-71-W54C0-D03 need schematics
    any help please...
    • sourcebf
      • Jul 2016
      • 433
      • N/A
      found burned component PU7 and I can't identify it
      • atsio
        • Oct 2013
        • 819
        • Greece
        Probably P2808 b0
        • sourcebf
          • Jul 2016
          • 433
          • N/A
          Originally posted by atsio
          Probably P2808 b0
          yes it is, I find a post talking about this issue and seems be frequent in Celvo Mobo.
          I do modification using two diodes pin1 connected to pin 8 with one diode
          Pin 2 to pin 8 with one diode.
          realize shunt between pin 3 and pin 6
          Laptop works very well
          • atsio
            • Oct 2013
            • 819
            • Greece
            Pin 3 is usually 19v (power button), pin 6 is 3.3v signal to EC controller. You will damage the EC controller if you didn't allready.
            • sourcebf
              • Jul 2016
              • 433
              • N/A
              befor I mesured at pin 1 and 2 find 19v, pin 3 must be always lower than 3.3 v.
              • myl
                • Aug 2018
                • 1
                • peru
                I dont speak fluent but I need to say TKY for sharing all files and know hows !!
                • fixfixit
                  • Jun 2010
                  • 14
                  • Sri Lanka
                  Here is the schematic for clevo 6-71-W54C0-D03 Notebook
                  Few other model numbers mentioned in the board: W549CZMB-0D, W549CZ, W549, PN:6-77-W547CZT0-D03-D#10
                  • purnasampath
                    • Jan 2020
                    • 1
                    • Sri lanka
                    thank you
                    • ti616
                      • May 2020
                      • 1
                      • Brasil
                      Thank you
                      • nassimhamdi
                        • Feb 2016
                        • 150
                        • algeria
                        great man thank you
                        • toufik sat
                          • Feb 2016
                          • 136
                          • los angles
                          great man thank you
                          • Nasir shiwani
                            • Oct 2015
                            • 4
                            • Sri
                            Thank you
                            • marquitos550b
                              • Nov 2011
                              • 22
                              Thank you !!!
                              • nilantha maduranga
                                • Aug 2012
                                • 17
                                • sri lanka
                                fixfixit thank you..
                                • Waseem_shaikh
                                  • Oct 2020
                                  • 7
                                  • pakistan
                                  thank you
                                  • mhamajeed
                                    • Dec 2019
                                    • 18
                                    • Sri Lanka
                                    Thanks a lot
                                    • Günter Schuch
                                      searching for Schematics & Boardview for Clevo P641HK1
                                      by Günter Schuch
                                      hallo leute ich habe ein problem mit meinem laptop der marke Schenker XMG P407 und zwar ist mir anscheinend der Grafikchip gtx 1050ti der direkt auf dem motherboard verlötet ist kaputt gegangen sie ist im Gerätemanager nicht mehr aufgelistet. deshalb hoffe ich hier unterlagen für das gerät zu finden. soweit ich herausgefunden habe wird die Platine die bei der firma Schenker verbaut wird von Clevo gefertigt und zwar mit der bezeichnung "Clevo P641HK1" ich hoffe auf eure hilfe und bedanke mich.
                                      Hello folks I have a problem with my laptop of the Schenker XMG P407 brand...
                                      05-14-2025, 06:34 AM
                                    • Garibean
                                      Clevo N240JU/N250JU Schematics
                                      by Garibean
                                      Hi
                                      I'm searching for a schematic about the CLEVO N250JU, i searched on internet and couldn'nt find it
                                      Thanks !
                                      07-03-2023, 10:09 AM
                                    • mikey5791
                                      Need help to replace burned resistor in 350w atx psu
                                      by mikey5791
                                      Hi to all forum members,
                                      Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                      The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                      Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                      Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                      12-26-2024, 04:55 AM
                                    • Bartoloni
                                      Lenovo Miix 300 schematics for a burned diode.
                                      by Bartoloni
                                      this is the diode (on detachable keyboard)
                                      burned because the customer inserted the power jack on a USB port...
                                      anyone know what diode can be this?
                                      2 pics on attachments
                                      probably thesame diode can be found on miix 310 ... or 320.. but icanàt find schematics about this "new" miix tablets....
                                      04-15-2021, 08:17 AM
                                    • Roachient
                                      Lookibng foe Schematics for clevo nkn850hk 1007G03615
                                      by Roachient
                                      I'm Looking for the schematics to Prostar Clevo nkn850hk 1007G03615. The board doe get power to it. but is not locating the installed ram. If I take out the ram and the laptop does not know the ram slots are empty, (no beeping). I have found multiple possible bad caps, I need the schematics to fix the board
                                      04-11-2020, 06:46 PM
