Asus X555L backlight shuts off when on battery
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. Very strange issue I've got with an Asus lappy here. I haven't heard or seen something similar before so it's very difficult to track down.
    Here goes: when I got it, the battery was bulged on the inside of it. It was pushing against the touchpad, so that's the initial issue the owner reported, as they had no idea the battery was causing the back-pressure. I took it apart, removed the blown battery and left it without one since it runs just fine on the AC adapter alone. Meanwhile, the chaps said they'd like a new battery put it after I told them it's blown, so fair enough, they pay me, I order it up and after a long wait the battery turns up.
    I install it and try powering up the thing. It does come on, but now there's no backlight...as soon as I plug the AC adapter in, the backlight instantly comes on...can't remember if the bulged battery did this. I can't recall if it had any bit of life left in it and turned on at all.
    Something's very wrong inside, so now I'm kinda stuck with a fairly expensive battery and a laptop I can't charge money for.....the schematic isn't very helpful because like most laptops, the PCB isn't marked, so I have no idea where to look first or what's causing the issue...I get 19v on pin 1 of the LVDS cable when plugged in and the backlight is on, which indeed goes away when I pull out the cord and it fluctuates 1-3v...the laptop keeps on going just fine, but the backlight doesn't switch over. The only schematic I found is this one, though I'm not sure it's for the proper board, since it's not mentioned anywhere. Just in case someone has a brainy idea or has encountered this before....again, very difficult. I can provide pictures if need be. Cheers and thanks.
    Wattevah...
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Asus X555L backlight shuts off when on battery
    I think i have a boardview for that. I'll check it a bit later and get back to you.
    A working TV? How boring!
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Thanks mate.
      Wattevah...
      • mielta
        • Apr 2015
        • 368
        Hi
        See if its help
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          Ugggh dumb question: how do you open those ? Haven't used board views before. Thanks.
          Wattevah...
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            This is what i use
            https://openboardview.org/
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              Thanks for the input so far, but it looks like this is going to be a mental exercise trying to figure out what went wrong rather than a hands-on approach trying to fix the thing, because I already closed the laptop and am underway to returning the battery which the seller luckily agreed to take back. Let's see...
              Wattevah...
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                The software won't install I'm afraid....just says has stopped working when I try running the installer...
                Wattevah...
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  This is the same software i use on windows 10 laptop its also what louis rossmann uses on his you tube videos so should work fine i will remove and re install it on this laptop and give it a try
                  Edit yes works fine using windows 10
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    I'm on win7 and I managed to find an alternative simply called boardviewer...I can open those files and located the connector for the panel and whatnot, but I must admit I'm not sure how such a boardviewer works. From what I understand, when I click on a pin, it highlights all other pins connected to it. In this case, I'm looking at the pins 38-40 of J4502, just so we're on the same page and they seem to be connected to AC BAT SYS. Upon clicking on the pins it shows me what else goes to those pins as well. Strange how it dies when you pull out the plug...
                    Wattevah...
                    • setiyo
                      • Mar 2018
                      • 36
                      • Indonesia
                      try this program bro
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        Can you please reupload the schematic ? I grabbed it at work and worked perfectly, but now it's telling me the archive is damaged...
                        Wattevah...
                        • petehall347
                          • Jan 2015
                          • 4430
                          • United Kingdom
                          could it be a software problem ? power settings gone wrong somehow
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            I doubt it, because AC_BAT_SYS 19v, present on pins 38-40 of the LVDS connector I mentioned, disappears when the AC adapter is pulled out. That seems to be the only "power" going into the display connector. It's not a control signal that cuts out - it's the supply itself that seems to die. Strange how nothing else dies...
                            Wattevah...
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              hopefully this will work
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                • Romania
                                Yes it does. Thanks
                                Wattevah...
                                • shuky
                                  • Dec 2010
                                  • 49
                                  hello
                                  i have same problem did you fix it ?
                                  have you got the board schematics ???
                                  thank you
                                    • 21439
                                    Originally posted by shuky
                                    hello
                                    thank you
                                    There is only a repair guide, and the boardview is already posted .
                                    • shuky
                                      • Dec 2010
                                      • 49
                                      thank you . but its only sample diagram
                                        • 21439
                                        There is no schematic, just the Repair Guide with test points. The boardview is already posted.
                                        • mkdj
                                          ASUS X571 no power : battery issue?
                                          by mkdj
                                          Mark and model: ASUS X571
                                          Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                          Tests already made:
                                          - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                          - I have removed...
                                          07-14-2025, 09:16 AM
                                        • HTR-Informatique
                                          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                          by HTR-Informatique
                                          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                          I also changed the screen because the PC fell and the screen was broken.
                                          I changed the battery with a new and original battery.
                                          I also had corrosion/oxidation on the...
                                          02-09-2025, 06:51 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • dhenion
                                          Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                                          by dhenion
                                          I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                                          The original board was:
                                          ASUS X510UNR REV 3.0 A
                                          The replacement board is:
                                          ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                                          It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                                          01-30-2024, 01:45 PM
                                        • rob777
                                          Asus TUF won’t run off battery
                                          by rob777
                                          I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
                                          I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
                                          Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
                                          Thanks....
                                          05-27-2025, 07:07 PM
