Trying to repair a cheap 12v power supply
  • RukyCon
    A Fake Rubycon
    • Jan 2017
    • 816
    Helloooo, i'm trying to repair this cheap 12v "5A" power supply i was given a while ago and even though i said i was not going to repair it due to how cheap and crummy it was, i was board and so i decided to pull the power supply out of my scrap pile (or what was left of it since i started taking it apart) and put new parts into it. And even after fixing most of it up it still has the same problem as it did before fixing it. The problem appears to be the circuit is pulsing on every second or two almost like it's in short circuit protection mode except there's no reason for it to be at all. The output voltage does rise up to 12v under no load so it does not appear to be shorted.
    If anyone knows what's the cause of this problem then i would like to know, thanks.
    (PS: The main reason i repairing this power supply is so i know how to fix similar issues in future repairs)
    I'm not a expert, I'm just doing my best.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8288
    Re: Trying to repair a cheap 12v power supply
    Could we see straight shot, high res pics from top and bottom of the board?
    Does the PSU work for like 30 seconds to a few minutes and then shut down? Or is it going in its knees after you put lets say a 1A load on it? Maybe the protection circuit is kicking in.
    • RukyCon
      A Fake Rubycon
      • Jan 2017
      • 816
      Even when the power supply is under no load it still does not want to work, it does this all the time.
      Here are some better photos but be warned, my soldering is not the best looking but it does work 99.89% of the time so i don't think it's part of the problem and like i said in post one 'it still has the same problem as it did before fixing it'.
      Also, any bodge jobs you see were not done by me.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Seems like the common failure mode: bad caps...which caps did you try to replace? Any one that feeds back could be at fault.
        And yes, nice bodge jobs
          Did you replace start-up/running small lytics cap on the primary side?
          https://www.badcaps.net/forum/attach...5&d=1523289989
          The pins of the common mode filter choke L1 in the primary look like bad solder works.
          • RukyCon
            A Fake Rubycon
            • Jan 2017
            • 816
            I replaced all of the capacitors with brand new ones i have on hand which were also pretested before being put in. (they're mostly test capacitors to make sure this thing worked)
            Well i don't think it's at fault in this situation because the unit does try to start up.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              When you say it rises to 12V, does it overshoot?
              I can't read the controller chip and what its behavior is when problem situations arise...
              • RukyCon
                A Fake Rubycon
                • Jan 2017
                • 816
                It does not overshoot at all, it goes up to and stays at 12v under no load at all, if you were to put a load on it then the voltage would drop below 6v.
                I'm guessing you're talking about the six-pin chip on the bottom of the board, i'n case you are, the number on it is 73F32S (a number on the lower half of it being 1340).
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Ah please double check budm's suggestion of the dodgy L1 soldering then, make sure your primary side isn't too resistive! Also carefully measure the primary and make sure the voltage isn't drooping.
                  Well that turned out to be a dead end of sorts... Ugh... I hate surface mount ICs...
                  • RukyCon
                    A Fake Rubycon
                    • Jan 2017
                    • 816
                    Tested it and both sides of the common mode choke tested at less than 1Ω each.
                      When I see board in this condition, first thing I would do is to clean up those bad soldering works first to eliminate the known bad looking condition. Someone mod the board too? I will not call the soldering on that inductor pin is acceptable.
                      The resistance between the inductor pin if checked at the pins may look OK, but if measured between the pads where the pins are solder too is another story.
                      You should also the DC V meter connected to the two legs of the main filter cap (the 400VDC cap) without the load and see what happen with the load connected.
                      Also check R46, R43 resistance.
                      • RukyCon
                        A Fake Rubycon
                        • Jan 2017
                        • 816
                        R43 tests at around 543k, I could not find R46 but looking at the board i'm guessing you meant to say R26 witch tests at 555k.
                        However, R35 (a 10Ω resistor used for the snubber) is shot (tests at around 1.2MΩ).
                        As for the soldering, i did not notice that one pin on the common mode choke was not fully soldered (yet somehow still working) but the diode package and the 680uf cap's soldering have their reasons. (the 680uf capacitors reason being a bit better than the diodes reason) But i will try to make it look better (as i was a bit short on time).
                        BTW i did not solder that SMD cap.
                        • RukyCon
                          A Fake Rubycon
                          • Jan 2017
                          • 816
                          The primary capacitor's voltage sits at 172VDC even when the output is pulsing. (This is with the diode and common mode choke re-soldered)
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            What's the voltage across C8 like, is it also going like crazy?
                            Now is the time it would be interesting to find the datasheet...
                            • RukyCon
                              A Fake Rubycon
                              • Jan 2017
                              • 816
                              The voltage on C8 slowly goes up to and stays at 10.33V.
                              • RukyCon
                                A Fake Rubycon
                                • Jan 2017
                                • 816
                                Here is a video i quickly recorded of what it's doing.
                                Warning: Flashing Lights.
                                • RukyCon
                                  A Fake Rubycon
                                  • Jan 2017
                                  • 816
                                  I may try to replace D5 and see if that fixes anything.
                                  One thing i noticed while testing C8 is as C8's voltage raised, the pulsing of the output got faster.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    I was wondering how bad the pulsing is on C8. Also the datasheet for the controller chip would tell if 10.33V was enough... Scoping it would be interesting though be careful, this is on the live side.
                                    • RukyCon
                                      A Fake Rubycon
                                      • Jan 2017
                                      • 816
                                      It took C8 about 20 or 30 seconds to rise up to 10.33v.
                                      I wonder if it's possible for a diode to test well under little load but stop working properly when it's under heavy load, the reason being the diode i was thinking about replacing tests fine on my DMM.
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        That's pretty slow...hmm. wonder if there's any leakage paths that's causing it to charge so slow. What voltage does it get to in 5 sec?
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • Andreas_de
                                          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                                          by Andreas_de
                                          Hello!
                                          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                                          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                                          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                                          04-12-2025, 10:38 AM
