Big problem with Samsung 300e4e
    Pls I need the expert to help me out of this mess , Samsung np300e4e was brought to me with no boot priority , so try to flash the bios with a programmer , the operation was successful but my system refused to come up. It only flash cap lock and power lite when adapter or battery inserted. Have reprogram it my initial backup no luck, pls help out . Initial bios version is P04RBD, I try with p08rbd problem persist
    Re: Big problem with Samsung 300e4e
    post your failed bios original p04rbd, and your p08rbd(where do you get?)
      this my backup P04RBD
        and this is the P08RBD which was downloaded from this site
          your backup file only 2mb,, no p04rbg found ...please check your bios chip type/capacity...
          should be 8mb
          this file only bios update region, no me region , no gbe region, no decsriptor..
          try this file 8mb below or use from iurd2007 ( https://www.badcaps.net/forum/showpo...77&postcount=8 )
          , just make sure to use spi programmer and 8mb chipbios...
            should be 8mb
            hav try this ( https://www.badcaps.net/forum/showpo...77&postcount=8 ) no luck
            but try d u just give and feed u back thanks
              should be 8mb
              good it work perfect my pc is alive thank so much u really help
              THANKS AGAIN
