Hello all,
For a few weeks I've been trying to fix a voodoo5 5500 agp video card. The machine locks up when running a 3d application in dual chip mode. I found out that it happens when a driver feature called 'guardband clipping' is enabled. This means that it can run in dual chip mode and that probably the chips are fine. By chips I mean GPU's.
I've been working with someone over at vogons.org trying to fix the card. Per his recommendation I have replaced all the capacitors on the card. This didn't work. I have another, working voodoo5 which I can use to compare voltages etc.
Other than asking for tips on what else to try, I have a question. Both cards have a couple of different resistors on them. Why could this be? Images on the internet of the card show the same resistors as on the good card.
I measured the voltages on the cards and the bad one reads 2.8 to 3.3v (the chips use
3.3v) and the good cards show 3.0v to 3.3v. That's what the power section reads. It takes 5v and 12v from a molex connector and changes it to 3.3v. 4 ics on the board do this.
I replaced a suspect resistor on the bad card and the power section now reads 2.6v to 3.3v. After this I have no idea how to proceed.
So, could the problem be in the different resistors the bad card uses? Or replacing the resistor was something stupid? Any suggestions on how to proceed?
No idea if this forum is the right one for asking a question like this, who knows
Thanks in advance!
Justin
Thanks in advance!
Justin
