Dell latitude e5440 bios
  • BremiX
    • Oct 2017
    • 64
    • Latvia
    VAW30 LA-9832P
    Rev 1.0 (A00)
    Doesn't POST, board ir taking 0.2 amps, fan spins and then board shuts off.
    Best Regards,
    Raitis
  • Mr.dialogue
    • Sep 2015
    • 17
    • pakistan
    Re: Need BIOS for Dell E5440
    Originally posted by BremiX
    VAW30 LA-9832P
    Rev 1.0 (A00)
    Best Regards,
    Raitis
    here you go.....ok tested.
    • microchipbtl
      microchipbtl commented
      Editing a comment
      Perfect bin thanks lot
  • BremiX
    • Oct 2017
    • 64
    • Latvia
    Thanks but didn't fix the issue.
    And tip about those two dumps, they are 1kb larger than chip can hold so you need to delete FFs at the end.
    • Fabbrone
      • Jun 2015
      • 158
      • italy
      Hy I am looking for this bios , on board ther is two chip U1 U2 ?
      thanks
      • ridamouh159
        • Nov 2014
        • 365
        • maroc
        Re: Dell latitude e5440 bios
        here is
        with good chance
        • Fabbrone
          • Jun 2015
          • 158
          • italy
          • Fabbrone
            • Jun 2015
            • 158
            • italy
            both sources have a slightly larger (1bit) size from the originals
            • BremiX
              • Oct 2017
              • 64
              • Latvia
              Try these:
              • Fabbrone
                • Jun 2015
                • 158
                • italy
                Perfect now it's working fine Thanks
                • EP3RROR
                  • Jun 2015
                  • 13
                  • Ελλάδα
                  hi, did you find any solution after all? i had the exact same problem. trying flashing both chips but nothing changed.
                  • mahmoodjavan
                    Banned
                    • Mar 2018
                    • 584
                    • iran
                    VAW30 LA-9832P
                    Rev 1.0 (A00)
                    Best Regards,
                    Raitis
                    test plz
                    • inv4der
                      • Mar 2015
                      • 26
                      • Poland
                      I'm looking firmware U38 MEC5057 KBC
                      • Mashra
                        • Feb 2019
                        • 1
                        • Pakistan
                        thank u so much
                        • nabilgo
                          • May 2016
                          • 309
                          • L.A
                          probleme dell e5440
                          this dell take 20 seconde to show up dell logo how i can fix that
                          • Zmyslony
                            • Feb 2019
                            • 2
                            • Polska
                            Re: probleme dell e5440
                            Try to clear Region ME
                            • nabilgo
                              • May 2016
                              • 309
                              • L.A
                              hox i can do it
                                • 22404
                                Originally posted by nabilgo
                                hox i can do it
                                If you`re willing to learn how to do it yourself All info you need is at post #2 https://www.badcaps.net/forum/showth...light=win-raid
                                Use ME Analyzer to check the ME firmware version in your bios dump,then follow the guide at win-raid, or watch youtube videos if you can`t follow the guide.
                                You can also try Intel Easy Clean ME from post #6 https://www.badcaps.net/forum/showth...light=win-raid ,you will still need the correct firmware from win-raid .
                                • nabilgo
                                  • May 2016
                                  • 309
                                  • L.A
                                  Try these:
                                  hey friend your bios work perfect the probleme is the laptop take 45 seconde to show data can u fix it pleas and thx
                                  • imranromi
                                    • Jan 2015
                                    • 1291
                                    • Pakistan
                                    Try this.
                                    • nabilgo
                                      • May 2016
                                      • 309
                                      • L.A
                                      Originally posted by imranromi
                                      Try this.
                                      now it start quick but wifi dosen't work
                                      • gizaha
                                        Dell Latitude 5580 possible bios corruption
                                        by gizaha
                                        Dell latitude 5580, motherboard cdp 80 la-e151p
                                        3 amber 3 white blinks. Dell website sais it's problem "bios recovery" and suggested solution "recovery image not found"
                                        (from here https://www.dell.com/support/manuals...e7a&lang=en-us)
                                        I try plugging charger while pressing ctrl+esc, machine turns on, nothing and after 20 seconds it gives 3 amber 3 white blinks again.
                                        Since ssd is replaced and had clean install windows, i've...
                                        02-13-2024, 07:18 AM
                                      • Sathsul
                                        Dell Latitude 5431 issues with dumping bios
                                        by Sathsul
                                        So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                        The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                        However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                        10-28-2025, 07:49 AM
                                      • jhanra
                                        by jhanra
                                        in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                        11-02-2024, 04:19 AM
                                      • YOUCEF4787
                                        Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                                        by YOUCEF4787
                                        I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                                        Initial Problem:
                                        The laptop was completely dead, no signs of life, no power LED.
                                        Action Taken:
                                        I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                                        Current Situation & The Main Issue:
                                        The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                                        09-21-2025, 12:19 PM
                                      • TripTop
                                        Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                        by TripTop
                                        Hi
                                        i have dell latitude E7270 with following symptoms:
                                        - takes long time to restart.
                                        - sometimes powers on and then off
                                        - sometimes while working it just dies,
                                        From googling online bios clean could possible resolve this?
                                        i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                        As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                        I reinstall...
                                        09-09-2024, 02:05 PM
