MS-16JB1 1.0 (Problem with KBC or BIOS?)
  • orientalsniper
    • Apr 2013
    • 461
    Hello all, how do I know if a laptop has problem with KBC or BIOS?
    When I turn it on, fan spins for 1-2 seconds then shuts off, have to disconnect all power to trigger power on. The stepdown IC provides 5V and 3.3V, but I'm getting 0V in BIOS pin 1,5,8. I downloaded BIOS from MSI website and flashed it and it still got the same symptoms.
    And I recently read that there's an EC ROM inside KBC and can be read with a programmer like this one.
    KBC is KB9028Q
  • IDislikemakingLogins
    • Feb 2017
    • 38
    • moon
    Re: MS-16JB1 1.0 (Problem with KBC or BIOS?)
    Id look more into why the bios isnt getting its power, If its responding to the power button the ec is at least partially working, Since the bios isnt getting power it shouldn't be a bios fault. Poke around what switches the power for the bios or the regulator that provides it.
    • orientalsniper
      • Apr 2013
      • 461
      Hello, sorry, my bad, but the laptop turns on by itself when I plug power adapter, the power button has 1.3V. When it turns off I can't turn it on with power button unless I replug power adapter.
      VREG5 and VREG3 have their own 5V and 3.3V, so I assume LDO IC is good.
      EDIT: I can't trigger power button, but there's a battery reset hole under the laptop (check image), if I press it, the motherboard reboots (led's on and fan spins up again).
        • 22021
        The power button voltage is low, check the ribbon cables and power button for corrosion,liquid damage ,and the connector on motherboard .
          • Feb 2017
          • 38
          • moon
          Id agree it looks low, so far only seen 3.3v at switches on laptops. I have had a few that if you hold the power switch for 20 seconds or more it will power off. Check that the kbc is getting the right power, the hp-pavilion-17-f103nr seams to use the same kbc, the schematic shows the power pins.
          • orientalsniper
            • Apr 2013
            • 461
            Hello to you both, KBC is getting 3.3V in all power pins 9, 22, 33, 96, 125, 111, 124, 67
            I don't see corrosion in either power button or ribbon cable.
            Owner said laptop had issues powering it on, but once it powered on, he could use it normally. And sometimes it booted up into BIOS setup screen when starting cold.
            • orientalsniper
              • Apr 2013
              • 461
              Btw, I attached a schematic that is very similar to the motherboard I'm repairing, same KBC and BIOS chip.
              EDIT: I'm getting 0V in RSMRST# Is it supposed to be high or low voltage?
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Read this:
                FIRST RESET SIGNAL ON COMPUTER CIRCUIT
                RSMRST#
                When the Power,Bios,Ec are OK, the RSMRST# will go Hi. In the other word,this pin go Low only when the systemreset.If BIOSdata is error,RSMRST# won’t go HI.
                When SIO(EC) get +V_RTC
                thecrystal will work.
                1. RTC have to be oscillating(32.768KHz).
                2. RTCRST# have to be high.
                3. RSMRST# have to be inactive (high).
                4. PWRBTN# have a trigger.
                5. LOW_BAT# have to be inactive (high).
                If this 5 present, then EC will recieve SLP_S3# / SLP_S5 from ICH/PCH, in the old ICH or some deferent circuirity SLP_S3 and SLP_S5 will generate directly from ICH,or both EC and PCH having this signal also.
                When All+V?S/+V? powers are ready, PWR_GOOD will tie to high to turn on CPU powers(+VCCP and +VCC_CORE).
                • orientalsniper
                  • Apr 2013
                  • 461
                  So my problem is with BIOS? Does anyone have a BIOS dump for MS-16JB1 1.0 (GE72VR 7RF)
                    • Feb 2017
                    • 38
                    • moon
                    looks like the msi site has the bios on it, looks to be the right size. Id make a backup first.
                    https://www.msi.com/Laptop/support/G...pache-Pro.html
                      • 22021
                      No, its this one https://www.msi.com/Laptop/support/G...-Pro#down-bios
                      • gerardo
                        Engineer
                        • Feb 2016
                        • 59
                        • Argentina
                        Thank you!
                        • lucaszmn
                          Summary of BIOS Whitelist Removal Problem Lenovo Thinkpad T560
                          by lucaszmn
                          Problem:
                          I am attempting to remove the WWAN card whitelist from my Lenovo ThinkPad T560.
                          Initial Findings:
                          • My current BIOS version is N1KET58W (1.45).
                          • I have a CH341A programmer and have successfully created two full backups of my BIOS.
                          • I have the ability to use command-line tools on a Linux machine.
                          Troubleshooting Steps & Conclusions:
                          • I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
                          • I concluded that the
                          08-12-2025, 03:01 PM
                        • AquaMan Ua
                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                          by AquaMan Ua
                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                          05-17-2025, 09:40 AM
                        • traxformania
                          TONGFANG "GM7TG7P" Bios Password Problem?
                          by traxformania
                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                          I'm trying to reset my bios without success.
                          I tried :
                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                          11-15-2023, 07:32 AM
                        • macabook
                          by macabook
                          🧩 Initial Issue
                          07-24-2025, 02:17 PM
                        • trouble55
                          NEC VersaPro PC-VRT42FBFR22B BIOS problem
                          by trouble55
                          Hi All,
                          [Mother board model]
                          V-VE212(U3E1)
                          [Serial number]
                          24000135PA
                          [BIOS chip model]
                          Macronix MX77L12850F
                          I am having some problems with the BIOS of my Versapro PC-VRT42FBFR22B.
                          I extracted the BIOS file (versapro001.bin 16MB) from PC-VRT42FBFR22B ROM (MX77L12850F) using CH341A and NeoProgrammer V2.2.0.10, but I don't know how to remove the BIOS password, so I can't open the BIOS even if I boot with F2.
                          I also downloaded the BIOS update package (933A0400.zip) for PC-VRT42FBFR22B from the official...
                          09-19-2024, 01:24 AM
