MacBook Air 820-00165 PPBUS-G3H Short to ground
  • technowiz
    • Jun 2018
    • 2
    Hi. I am in need of some assistance. I am trying to track down a short in this board and I am having limited success. Fuse F7140 is blown and I have removed U5450, R5450 as well as fuse F7700 and the short disappears past these components but I am unable to locate it. The only thing I can think of is that it has an internal short within the board. Any help would be appreciated. Thanks
  • gmorb
    • Sep 2017
    • 35
    Re: MacBook Air 820-00165 PPBUS-G3H Short to ground
    Insert voltage?
    • mawaqas
      • Aug 2016
      • 3
      • United Kingdom
      did you find out what was causing it?
      • AtoZed
        • Jun 2020
        • 1
        Hey!
        I have solved this type of issue once before on this exact board. Pin one side of F7140 was getting the 8.6v but the pin 2 side was shorted to ground. The fuse was blown as well. I didn't have the means to inject voltage so I replaced the fuse. Once I did that the pin 1 side of the fuse became shorted to ground as well. I then plugged in the magsafe and dripped alcohol all over the board to see if anything got super hot. This is when I found C7313 sizzlin'. After replacing it, I got fanspin and the board was fully functional. The short was gone. Hope this helps. There are a lot of capacitors on the G3H line that could be blown and shorting to ground.
        This is my first post. I wanted to post regarding sourcing the F7140 fuse. I have another Air with a similar issue and don't have any fuses left on donor boards.
        • Neodim
          • Jul 2020
          • 3
          • Ukraina
          Originally posted by AtoZed
          ...... dripped alcohol .....
          good solution, sometimes I also use this technique
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3628
            • slovakia
            standard technique if u dont have thermocam
