need bios Clear ME one for dell 5459 da0am8mb8d0 thx
Re: dell 5459 da0am8mb8d0
this is download file ori file format alrdy thxAttached FilesComment
Here you go,try it and give feedback .Comment
SMDFlea, I have a few questions for you.
My Dell Vostro 5459 has an admin password in the BIOS.
Can I use a bios image from your DELL 5459 BIOS AND EC ME CLEAN - DAOAM8MB8DO REV D.zipf ile for my Vostro?
What will happen with the old ServiceTAG?
thx,Comment
post the backup of the bios, and service tag on the laptop case ...Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
a copy of the bios in the attachment, service tag is in the filenames
try this..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Try this file. Extracted from dell updateAttached FilesComment
Here,flash BOTH 4 and 8MB . (Tag + Win key copied from backup,put into bios from post #5) .
.Last edited by SMDFlea; 07-27-2021, 08:10 AM.Comment
[QUOTE=SMDFlea;845692]Here you go,try it and give feedback .[/QUO
Atleast this dump doesn't work for me. 2-4 times blinks which means ram issue. My old dump has sometimes display and sometimes not. please help thanks in advanceAttached FilesComment
[QUOTE=lazybigyan;1202647]try on an external monitor.. if you have video all the time, the bios is not the problem.. check the display, LVDS cable, video chipset, plugs...etc..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
by zeniusHello, I have an old Dell G3 3579 (ST: 2WQ7LP2-8FC8) with a newer 8FC8 BIOS password. I have successfully attached to the flash chip (W25Q128JVSQ) on the motherboard with a CH341A programmer and made several modifications using Intel FIT (e.g., allow software SPI write) without bricking. I was also able to boot to a modified GRUB shell where I attempted to edit many BIOS security related options like BIOS Guard/Lock, Flash Signature Override, ME FW Image Re-Flash, etc.
Unfortunately, some of these modifications like to Intel BIOS Guard failed because it is fused into the PCH. Also,...-
Channel: BIOS Requests ONLY!
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
Channel: General Computer & Tech Discussion
04-23-2025, 04:30 PM -
by capoplaysHey everyone,
I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
When I check the BIOS using the F12 menu Flash...-
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
- Loading...
- No more items.
