Fixing a multimeter based on VC9805 schematic
  • madan1
    • Nov 2016
    • 726
    • Bulgaria
    Hi there, recently I got a not that cheap chinese multimeter based on VC9805 schematic.
    Unfortunately it doesn't measure correctly.
    Here is an example:
    Range | ~33mv | ~100mv | ~503mv | ~2V | ~3V | ~10V
    200mv | 33------ | 101-------| - ---------| -------| ----- | -
    2v------| 0.030---| 0.98------ | 504----- | 1.94 | - ---- | -
    20v----| 0.01-----| 0.08 ----- | 0.48----- | 1.7-- | 3 ---| 10
    200v---| 0 --------| 0 -------- | 0.03 ----- | 0 --- | 2.8 | 9.8
    1000v-| 0---------| 0 -------- | 0 --------| 0---- | 1 --- | 8
    range ohms
    200---- | ---------| --------| ------- | ---------| 1.2
    2k------ | --------| --------| ------- | 0.981 | 0
    20k---- | 4.89---| --------| 2.15 | 0.96----| 0
    200k-- | 4.7-----| 29.5--| 1.9-- | 0.8------| 0
    2m---- | 003--- | 0.027 | 0------| 0-------- | 0
    20m-- | 0------ | 0.01-- | 0------| 0-------- | 0
    Both V and Ohm measures go through RS2 RS3 RS4 and RS5. All that resistors measure as shown on the schematic - 1k, 9k, 90k and 900k. RS6-9 are 1.75m, 2.95m, 1.75m and 2.95m or total of 9m ( while it should be 10m, but even with added 1M resistor, the measure pattern still stays the same ).
    I also have measured the resistance of the paths for all V ranges between Rin and the corresponding resistor ( for instance range 20V - Rin <-> RS5xRS4 ) and all paths have almost the same resistance ( +/- 0.2 ohm ). These are the paths which go through the range selector knob. Also, the multimeter is almost brand new and no damage is visible on the contacting surfaces.
    Rin is 1M
    Any ideas what else to check?
    p.s.
    range | 1uf | 22uf | 10- | 1 ----| 0.47 | 10
    200u--| 1.1 | 23.4 | 10.9| 1.1 --| 0.5 -| 0
    20u---| 0.94| 19.3 | 8.52| 0.93--| 0.44 | 0.01
    2u----| 0.95| ---- | ----| 0.945 | 0.448| 0.009
    200nf-| ----| ---- | --- | ----- | -----| 9.1
    20n---| ----| ---- | --- | ----- | -----| 9.15
    The current measurements seem fine ( of course need calibration ).
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    Re: Fixing a multimeter
    no idea but good luck with it . still have 3 dmm.s to look at again all same model different faults .
    i tried working backwards from what caused the faults such as measuring volts with the leads plugged into in amps sockets and a bypassed ultra fast fuse .
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8710
      Meters are usually rated ±x% + y digits...
      https://www.elektrovadi.com/VC9805-D...RE,PR-470.html
      Assuming your voltages are from a calibrated source (and if you do have a calibrated source, I want to know how because all these years I still have yet to get a source that's traceably calibrated despite having many multimeters that could benefit from calibration), feeding a 503mV signal into 20V, 0.5% down is 501mV => 0.50, and three counts error would be 0.47, so 0.48 is within specifications. A quick glance at the voltages don't look way too far off.
      The resistances you have to go through a similar calculation for error - this time it's 0.8% + 1 digit. Now I don't know what your resistors are and their calibration is, but you can do the same calculations.
      You would have to muck with the trimmers to make them closer, perhaps the VRref 1K pot for everything if it's really that off.
      • redwire
        • Dec 2010
        • 3912
        I would check the protection circuits and maybe the rotary switch because the DMM is measuring off numbers only on some functions/ranges?
        There are a bunch of diode-connected transistors for clamping overloads. These can get damaged (leaky) which makes low values read low or zero. Or they can turn on early and make higher readings stuck at a mid value.
        I would check transistors QC3, QC4 which protect between the two grounds.
        TR 9103 (by CR 104) seems to be protection for the ohms (output) current source.
        QC1, QC2 for overloads on capacitance measurement.
        Tr L6 is protection for thermocouple input.
        DI 1, DI 2 protection for current shunts.
        Tf1, Tf2 protect the Freq. input
        The ICL7106 A/D is a bit hard to understand because DMM input COM is to A/D (-) IN LO, not A/D COM or V-.
        • madan1
          • Nov 2016
          • 726
          • Bulgaria
          At the moment the DMM is calibrated within +/-0.25V for the 20V range in reference to another mid-range DMM. Indeed accuracy of +/-0.05v is absolutely enough for my needs.
          For the above measurements I used a bench power supply. It is "roughly calibrated" to +/- 0.2v. I also used batteries for additional tests. The OHMmeter also needs calibration, but it will be in vain if the main problem is not fixed.
          And the main problem is that let's say in "2V" I have a steady reading of 1.5V, but in "20V" it goes down to 1.3V and in 200 it shows 0.
          In comparison, another really cheap chinase DMM ( ~$3 ) shows constant 1.5 in all ranges.
          The same thing happens and to the ohmmeter values ( again the $3 DMM shows the same value in all ranges ).
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8710
            You can test against another DMM in the same range, but a bench PSU is an awful reference unless it's a quality model that has been professionally calibrated. You can't trust a CCC PSU.
            You have to keep in mind, without a real reference, maybe your other DMM is wrong too. Cannot tell.
            Also please type out all the digits. Your numbers don't tell me enough unless all significant digits are shown (e.g. if you say 1.5V in the 20V range on a 3½ digit DMM, I have to assume anything from 1.45 volts to 1.54 volts which is ten possible numbers. Even worse in 2V range, it could be anywhere from 1.450V to 1.549V when rounded, which is 100 possible numbers. The former, 3 digit rule is violated but very close; the latter, the 3-digit rule is clearly violated.)
            • madan1
              • Nov 2016
              • 726
              • Bulgaria
              Right now the accuracy is not that important. I just want to get the same value in all ranges.
              Here are some new readings.
              AAA battery
              200mv - 1
              2v - 1.486
              20v - 1.46 ( -0.26v )
              200v - 01.2 ( -0.26v )
              1000 - 000 ( -0.2+ )
              18650 battery
              200mv - 1
              2v - 1
              20v - 4.01
              200v - 03.8 ( -0.21 )
              1000 - 001-002
              another 18650
              200mv - 1
              2v - 1.057
              20v - 1.03 ( -0.027 )
              200v - 00.8 (-0.23 )
              1000 - 000
              AA battery
              200mv - 192.2
              2v - .189 ( -3.2 )
              20v - 0.16 ( -0.029 )
              200v - 00.0 ( -0.16+ )
              1000v - 000
              Looks like the difference between 2v and 20v is biggest.
              I gonna test again with resistors.
              Edit:
              leads only:
              200 - 00.0
              2 - .000
              20 - 0.00
              200 - 00.0
              2 - .000
              20 - 0.00
              .22R - 0 in all ranges
              1.6r
              200 - 00.8
              0 in all other ranges
              330r
              200 - 1
              2 - .320
              20 - 0.30 ( -0.020 )
              200 - 00.1 ( -0.20 )
              2 - .000 (-0.1+)
              20 - 0.00
              1.2kr
              200 - 1
              2 - 1.182
              20 - 1.16 ( -0.022 )
              200 - 01.0 ( -0.16 )
              2 - .000
              20 - 0.00
              2k
              200 - 1
              2 - 1.970
              20 - 1.95 ( -0.02 )
              200 - 01.7 ( 0.25 )
              2 - .000
              20 - 0.00
              the same R reads as follows on the other cheap DMM:
              200 - 1
              2k - 1.991
              20k - 1.99
              200k - 02.0
              2m - .002
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8710
                But the numbers appear to be in spec, if the divider stack is accurate, only thing left is leakage...
                Maybe even the capacitor connected to pin35 of the 7106...
                  • 31285
                  did you check the resistors in the divider circuit?
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8710
                    Apparently the OP did check them:
                    I don't know if these were tested in or out of circuit, but it looks like if the selector was removed (which most multimeters it's guaranteed because they have to be pulled apart to access the board) then there is no interference with measurement. I recall a multimeter I fixed with inaccuracy issues in ohms mode only that was part of that resistor stack, but it was that lowest one. However it uses different resistor stacks for ohms and volts mode because there's no constant current in vacuum tube voltmeters...
                    The 1.75/2.95/1.75/2.95 resistance stack totals 9.4MΩ which is not quite right, but the error is linear with respect to the main measurement stack (900K/90K/9K/1K) so it can be balanced out by VRref tuning. The main measurement stack of 900K/90K/9K/1K is the only one that must be accurate with respect to each other. The 1K would be most suspect because it seems that the lower the reading the higher the error, but regardless, it still seems within the specs of the meter...
                    • redwire
                      • Dec 2010
                      • 3912
                      If the A/D linearity is poor, the Integrator capacitor (pin35) might just be a cheap ceramic part.
                      Some DMM's have the required big through-hole film cap, and a tiny X7R might explain the poor linearity seen here.
                      Otherwise, the divider resistors are out or the A/D is noisy/bad, or maybe the power supply rails are noisy if they cheaped out on capacitance.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8710
                        I don't know why I assumed all DMMs used a film cap there (I made sure I used a film cap for my 7116 on-breadboard experiment!), but you're right, the cheapening of multimeters probably forced people to use a ceramic disc and god forbid a ceramic SMT MLCC for that capacitor... Yow. I guess I have to start looking for that integrating capacitor and shun those DMMs that use a ceramic there.
                        Then again I don't know about the stability/leakage of newer ceramic MLCCs, as I have been surprised that the average SMT resistor seems to have better tolerance than a typical gold band (5%) through hole resistor. But perhaps it's just because there's no room to print on the tiny resistor what the tolerance should be...
                          • 31285
                          smd resistors are metal film, mostly 1%
                          this is because you can handle more current in a smaller space.
                          as for caps, you can get smd film caps.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8710
                            Oh my... film capacitors are pricey and huge...
                            I recall the int cap for a 7106 needs to be around 0.22uF, these are like at least 50 cents a piece in the 1000s quantity. A ceramic of the same capacitance is 1/10th the cost and probably 1/4th to 1/10th the size!
                            • redwire
                              • Dec 2010
                              • 3912
                              Look at pics of the vulnerable DT830B DMM which is like OP's.
                              Some use a big through-hole film cap 0.15uF and others use ceramic X7R for the integrator cap.
                              SMT filmcaps (PPS dielectric) still melt easily in reflow and I rarely see them used.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8710
                                I would imagine that leakage would be a bigger problem than capacitance reduction due to voltage. The capacitor must be low leakage and not have microphonic characteristics. I don't think the voltage across the capacitor should reach more than a few volts (3V would be my upper bound guess) so it shouldn't be a huge concern if a high-ish voltage part was selected.
                                Yes, I was wondering how the heck SMT Polyester caps would survive reflow hence assuming that they didn't exist... but they sure do and how the heck would these be safely reflowed?
                                • madan1
                                  • Nov 2016
                                  • 726
                                  • Bulgaria
                                  Sorry guys, I didn't have the time to work on this. Probably tomorrow will be able thoroughly check your replies and do some more tests.
                                  Meanwhile here are some photos to get an idea about the particular DMM.
                                  p.s. 6R3 = Rin
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8710
                                    Eiew COB, mark of cheapness
                                    At least it looks like it is probably using a film capacitor 6C6 for the int cap, though I'm not sure how the board correlates to the actual schematic, they look a bit mismatched. I don't know why there's a resistor in series however, that seems a little out of place from all the 7106 series chip circuits I've at least seen...
                                    • madan1
                                      • Nov 2016
                                      • 726
                                      • Bulgaria
                                      I have traced the V line from the probe to the IC and it exactly matches the schematics ( the components are marked differently though ). Tomorrow will trace the Vref lines and will check the components pointed out in the above comments.
                                      • madan1
                                        • Nov 2016
                                        • 726
                                        • Bulgaria
                                        Well, I guess I killed the analog part. I shorted 6R5 and after that I'm not able to get a zero ( even after I removed the bridge wire )... not it just loops between -1 and +1 ( for V ).
                                        edit False alarm... It turned out the selector knob is causing the issue..
                                        edit 2:
                                        I shorted again 6R5 and this reduced the difference between 20V range and 200V range to ~0.14V ( battery 7.74 in 20V -> 7.6-7.7 in 200V -> 007 in 1000V ). Still to test it with other voltages and resistors, but I guess the results will be similar. Any ideas how to improve even more the accuracy between the ranges?
                                        The capacitance of 6C6 is OK.
                                        • max_smart
                                          T430 laptop doesn't power on- please help me troubleshoot w/multimeter (fixing for fun)
                                          by max_smart
                                          First off, this forum really helped me out by advising me to cut some ribbon connectors to the LCD panel in order to fix a 70" TV (lots of threads on Sharp TVs with this issue). I didn't believe that it could work, but it did.
                                          Now I've been encouraged to try to diagnose something quite a bit more complicated. That is an old T430 motherboard. I work on a college campus so I have access to pretty decent tools. I found the schematic for the motherboard on the site, and have been following traces and taking DC measurements from things. I also don't mind...
                                          06-01-2024, 03:27 PM
                                        • PanicMechanic
                                          Extech EX330 multimeter current range offset fault
                                          by PanicMechanic
                                          My multimeter has developed this fault, a few months ago. I tried to fix it, but had no success.
                                          The fault is that on the current ranges it never shows 0. Does not matter if the probes are open or shorted.
                                          As you can see from the pics, the offser is the same (just multiplied for other rages):
                                          -4.9 uA
                                          -0.49 mA
                                          -0.49 A
                                          I don't know what exactlly caused the fault.
                                          The meter had a battery leak before I noticed the fault, but I am not sure if the fault was present before that happened. I just did not noticed. The battery leaked...
                                          05-11-2021, 11:13 PM
                                        • dj8452000
                                          How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                          by dj8452000
                                          I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                          02-18-2025, 08:28 AM
                                        • yayayee
                                          ASUS GU502GV not powering on - 1285A hot
                                          by yayayee
                                          I have a laptop that isn't turning on. When I disassemble it and plug in the power connector with the pcb by itself, I can see with a thermal camera I bought that TPS51285A is the only thing getting hot.
                                          So of course, the first thing I do is google the laptop model and the IC, and it just happens that I stumble upon a video by Northridgefix attempting to repair the exact same problem, only for it to catch on fire.
                                          I thought that maybe I'd be lucky so I bought a 1285A, that came in as a 1285B. The only difference I can see between them is that the 1285B...
                                          01-08-2024, 11:04 PM
                                        • Geeker007
                                          Please review my ESP based WLED controller board for WS2815 12V LED Strips - New to electronics.
                                          by Geeker007
                                          I'm designing an ESP-based WLED controller board for WS2815 12V LED strips, with a primary focus on energy efficiency.
                                          To minimize power consumption, my goal is to completely shut down the system when the LED strip is turned off.
                                          However, the current buck converter powering the ESP module draws about 8 watts even when the LEDs are idle, making it unsuitable for low-power operation.
                                          I am using below components:
                                          • Buck Converter: TPS562201 (12V → 5V regulated)
                                          • Microcontroller: XIAO ESP32-C3 (with built-in USB-C)
                                          • LED Strip: WS2815 (12V digital LED strip)
                                          • Switching
                                          06-29-2025, 05:20 PM
