Thread Tools |
#241 |
City & State: Thessaloniki, Greece
My Country: Greece
Line Voltage: 230VAC 50Hz
Dell PS-5161-1D1 160W & Dell PS-5161-7DS 160W
I took them out of a Dell Optiplex GX260 and a Dell Optiplex GX280 respectively. I am going to keep one and give the other to a friend. The second psu is full of OST caps, some of them slightly bulging. Who makes those? And which should I keep? |
#242 |
master hoarder
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
Both PSUs are made by Lite-ON. You can tell by the UL number (E132068) written on the label and the Lite-ON marking on the transformer on one of the PSUs. Also, most Lite-ON PSUs will say "AMBIENT: 50C MAX" on the label.
One of the PSUs (the one on the left?) looks like it has that brown glue that goes conductive - you might want to remove it as much as you can. I think you should keep the one on the right (the one with the OST caps). It has a slightly more powerful 12v rail. More clean, too. Just recap it. |
#243 |
My Country: Greece
The second one doesn't work unfortunately. Only 5vsb. It also needs full recap and I am a bit tight at the moment.
The other one works normally but its fan is stuck. Last edited by goodpsusearch; 10-15-2010 at 08:12 AM.. |
#244 |
Send Doge Memes
City & State: Napa, CA.
I'm a: Forum Junkie
Swap the fans. Sell the working one. Spend that money to fix the other one and hope the lubricating will fix the fan...
Sierra: Core i5-11600K, 32GB DDR4-3200, Radeon RX 7900 XT 20GB, 1TB Samsung 980 Pro (OS) + 2TB Kingston NV1 (Games), Thermaltake GF1 850W, Asus Prime AP201 Case, Dell S2721QS 4K 60Hz Monitor, Windows 11 Pro. Canyon: Core i3-10100, 8GB DDR4-2400, Arc A380 6GB, 1TB Intel 670p, CWT OEM 500W, Thermaltake Versa H17, Samsung 32" 1080P TV, Windows 11 Pro. Plex: Dell Optiplex 7020, Xeon E3-1270V3, 16GB DDR3-1600, Radeon Pro WX3200 4GB, 500GB WD Blue SATA SSD, 1.6TB Lenovo IO3 PCI-E SSD, 10TB WD Red HDD, Windows 10 Pro. |
#245 |
My Country: Greece
I tried to remove the glue from the working one... And after it was done, I plugged it in.. and then the protection relay of the house went down
I have done something stupid I suppose... |
#246 |
This PSU from a Dell Optiplex looks almost exactly like the HiPro shown by Momaka:
http://www.badcaps.net/forum/showpos...&postcount=228 It has a HiPro-like model number, HP-P2507F3R, uses the same HP1001WA-1 chip near the outputs. and may have an SCR net to it, but its UL number, E134709, says it's made by Chicony. There are slight differenes, such as only 3 optical isolators instead of 4, next to the small transformer, and the +5Vstandby supply uses a small vertical circuit board and a Tiny Switch TNY265P. The main supply is controlled by a UC3843. Matsushita/Panasonic 680uF 200V caps on the primary, everything else is Asiacon (nothing measured, but none swollen). Last edited by larrymoencurly; 10-27-2010 at 02:44 AM.. |
#247 |
Large Marge
City & State: Kalamazoo, MI
My Country: United States
Line Voltage: 0-120VAC 60Hz
Sometimes power supply companies will do something that facilitates getting a new UL number, and another manufacturer will swoop in and pick up their old one (hoping that people look at a old list they made of UL numbers and think their unit in infact someone else's). I don't know how they do this, but Topower does it alot.
#248 |
Send Doge Memes
I'm a: Forum Junkie
goodpsusearch-so you made one working one as per my idea, irght? sell it!!!!
then salvage certain parts from the other one, and toss it |
#249 | |
My Country: Greece
#250 | |
City & State: Vilnius
My Country: Lithuania, EU
I also have a Hipro psu from IBM thinkcentre desktop with Chicony UL. |
#251 |
Got in some real marvels of engineering recently. All of them are broken in some way, two due to bad caps, one due to being garbage in the first place.
![]() Up first is the delightful Macron Power MPT-251. Came out of some old FRY's prebuilt thingy. Having owned one of those wonders, I can say build quality wasn't high on the priority list for FRY's. ![]() Label shot. Nothing spectacular here. Cable count: 1 x 20 pin 1 x 4 P4 2 x floppy 4 x Molex. ![]() Inside presents a bit of a surprise. Everything looks like it could do the rating on the label. Except for one thing... ![]() That hateful little Fuhjyuu mark of death. Naturally, this POS is full of them, including the primaries. Note the larger cap, which may have been someone's previous attempt at a repair. ![]() Fan is some PowerLogic thing I don't care enough about to go looking up again. Last edited by cheese007; 12-09-2010 at 11:01 PM.. |
#252 |
Next we have yet another rather infamous name: Bestec.
![]() This particular example is the ATX-250 12-Z Rev. D, found in a new-ish HP. ![]() Please excuse the blurriness. Camera was acting up at the time. Cable count is the same as the Macron Power above. ![]() Inside, again, looks decent enough. ![]() So naturally some Jamicon capacitors had to show up and ruin the fun. You can't see it in this pic, but there's a few bloaters in there. Fan is also Jamicon, but I couldn't get the thing out of the case. All of this is well and good, but I saved the best for last... |
#253 |
![]() Yes, Powmax. They're one of the most famous PSU names, but for all the wrong reasons. They're so bad that they've become pretty much the gold standard for bargain-basement PSUs everywhere. ![]() Everything in the above picture is a lie. Cable count is the same as the rest, except for the addition of an AUX connector. ![]() What a familiar sight. Tiny heatsinks, no input filtering, questionable quality capacitors, all hallmarks of a typical leadmen unit. Speaking of capacitors, primaries are JEE, as are all of the secondaries aside from one lone Teapo. ![]() On the plus side, this fan lights up red, and its the only unit of the three that works. |
#254 |
master hoarder
My Country: U.S.A.
Save the Macron and the Bestec, gut the Powmax for parts.
In my experience, Power Logic fans are pretty good. Had a few run nearly 24/7 on full 12v for a good number of years - and they still run fine (with lots of original oil left under the seal), but the computers they are in are no longer in that kind of extensive use anymore. |
#255 |
City & State: Williamsburg, Virginia
Line Voltage: 120VAC 60Hz
The Bestec has bad bloated C36 capacitor used in 5vsb circuit. To permanently fix this problem, see this thread:
http://www.badcaps.net/forum/showthr...ghlight=bestec The Bestec ATX-250 12Z is a good power supply, just needs some tender loving care. Fix the C36 problem, remove any black or dark glue, and recap as needed. This power supply has a really nice crowbar circuit to protect it from going overvoltage on the 5vsb. It also uses a pwm chip in the 5vsb instead of the usual two transistor design. The mobo killer to watch out for is the Bestec ATX-250 12E
Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11) |
#256 |
City & State: Thailand
DELL MODEL: H525EF-00 (HIPRO) UP/N: D525E001L DP/N: 00G05V
525W PSU for T3500 WorkStation 80PLUS SILVER ActivePFC uses two SPW20N60C3 Two-Transistor Forward uses SPW15N60C3 5VSB use TNY280PN IR1166S Synchronous Recitifier for 12V (cannot see MOSFET) 5V and 3.3V uses Voltage Regulator Module from 12V Capacitors on Secondary are UCC KZE/KZH, Ltec LXY (cannot see primary cap)
| AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 | | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW | | 2xWD7500AYYS | 2xHD322GJ Raid0 | |
#257 |
Has Seasonic always been good? Because I found a 150W one from the 1980s that seems cheaply built (was UL approved), although almost all the caps are Japanese:
![]() OTOH here's an Astec-made 130W PSU from the same era that IBM used in its PCs: ![]() Both PSUs have transformers work at about 30 KHz, but the Astec's is 2-3 times the volume, and it has four 440uF high voltage capacitors, compared to two 330uF ones for the Seasonic. |
#258 |
Capaholic
City & State: Trenton, NJ
Line Voltage: 240/120V 60Hz
I'm a: Hardcore Geek
Astec SMPS are the best
I will post a few pics of a 150watt dell ATX power supply I have, it has its original NCC and Rubycon caps, nice heatsinks, and good line filtering too ![]() I also have a ATX power supply (forget the brand). Who thinks a 1000uF cap is good on a 38A +5volt rail??? :P -Ben |
#259 |
Large Marge
Astec is just heavily overbuilt. 150W doesn't require much guts. Even the cheapest leadman units do 150W ok.
#260 |
Capaholic
Here it is.
It is a Dell 150watt ATX psu, apparently made by liteon. First picture is the label, I took that right before my floro-lamp burst out in red and orange flashes that scared the crap outta me! Second one shows the overall insides- Third one shows the well-rated NCC caps- Fourth, a nice snapshot of very good RF filtering- ![]() And the last one is a shot of the transformers and controller chips- -Ben edit: I got an error while trying to upload the pictures, It said that a security token was missing? I messaged the Moderators and hopefully they will be able to help me with this problem! Last edited by ben7; 01-07-2011 at 06:23 PM.. |
