Lenovo ThinkPad 13 gen 2 - BIOS Request
  • raileanu
    • Sep 2015
    • 127
    • United Kingdom
    Please if someone can help me with a working BIOS dump for Lenovo ThinkPad 13 Type 20J1 Gen 2 as I search every where online and cannot find it.
    Many Thanks in advance.
    • 21692
    Re: Lenovo ThinkPad 13 gen 2 - BIOS Request
    Whats the model number, is it a Type 20GJ, 20GK
    • raileanu
      • Sep 2015
      • 127
      • United Kingdom
      Type 20J1. I believe the bios for Thinkpad S2 will also work as it has the same motherboard. But cannot find that either.
        • 21692
        Can you post your bios backup.The bios from lenovo is only a bios update,i can merge it with your bios.
        • raileanu
          • Sep 2015
          • 127
          • United Kingdom
          Thanks but I try this already and it doesn't work. My bios is completely corrupt from the beginning due to a loose contact on the programmer while I was reading it, then I write another wrong one and is all gone now.
            • 21692
            Try this bios,i merged 2 different bios together,i don`t think it will work but try it anyway. This bios is 16MB .
            • raileanu
              • Sep 2015
              • 127
              • United Kingdom
              Thanks it works. But is asking for a password when I try to go to settings after the message that rtc time needs to be set and to press F1. It doesn't give no other boot options. Is that kind of password with a human head, I think is a supervisor password. Can this be removed from the bios or is embedded on the security chip?
              • raileanu
                • Sep 2015
                • 127
                • United Kingdom
                I also get the message
                0183: Bad CRC of Security Settings in EFI Variable
                Any way I can bypass this on Hex Editor so the computer can boot?
                I cannot go to F1 Settings because is asking for Supervisor password.
                I believe these error messages are because the computer detects that is another bios installed.
                • raileanu
                  • Sep 2015
                  • 127
                  • United Kingdom
                  I manage to get rid of there error messages by restarting many times the computer with RTC battery plugged and its main battery. It boots normal now but still have that password on bios settings. If I just press ENTER it goes to bios screen but won't allow me to do any changes. I think I need a mini UEFI bios boot tool to flash on the EEPROM chip to reset these settings. Do you have any of these mini bioses please? It will be a great help. And Thank You once again for providing the working main bios.
                    • 21692
                    There must have been a password on the original bios,and i think it does indeed have a MEC1633L or similar chip,so flashing the bios and EC wouldn`t remove the password,if you had those dumps.
                    • raileanu
                      • Sep 2015
                      • 127
                      • United Kingdom
                      Does anyone yet play with the DXE Driver from allservice or anyone have this files please.
                      • raileanu
                        • Sep 2015
                        • 127
                        • United Kingdom
                        I hope someone will finally upload a DXE Driver so we can modify it to sort out these IBM's Passwords problem once for all.
                        • sayedmansoorpuya
                          • Mar 2021
                          • 33
                          • UNITED ARAB EMARATS
                          Please desble computrace
                          • sayedmansoorpuya
                            • Mar 2021
                            • 33
                            please fast
                            • Dan20701
                              • Sep 2020
                              • 204
                              • United Kingdom
                              Hello, Can anyone tell me if Lenovo Autopatcher v0.2 works
                              for this model ? I have done a few readings with two different programmers
                              the files are identical, Lenovo Autopatcher is telling the file is corrupted.
                              And is the password on the main bios or EC.
                              Lenovo ThinkPad 13 Gen 2, Type 20J1, 20J2. Thanks.
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                https://www.badcaps.net/forum/showth...702#post983702
                                https://www.badcaps.net/forum/showth...25#post1110325
                                https://www.badcaps.net/forum/showthread.php?t=88004
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                • Dan20701
                                  • Sep 2020
                                  • 204
                                  • United Kingdom
                                  Thanks Vesko356, Could someone please have a look in to
                                  my this bios to see if it can be fixed.
                                  Sure its a corrupted bios, Thanks so much.
                                  • Dan20701
                                    • Sep 2020
                                    • 204
                                    • United Kingdom
                                    Hello again, Related to my last post, Is there nothing that can be done?.
                                    I have tried to reload the ME using fit.exe its not loading the bin file, there
                                    is nothing more that I know I can do. Some help with this would be nice.
                                    Thanks.
                                    • loko
                                      • Aug 2020
                                      • 35
                                      • croatia
                                      ThinkPad 13 Type 20j1-0001SC need Bios dump.
                                      If somebody maybe have working Bios dump for this model.
                                      Laptop turns on but no picture.
                                      Here is original dump of this model but maybe is corrupted.
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12278
                                        Post is missing serial number.
                                        • lucaszmn
                                          Summary of BIOS Whitelist Removal Problem Lenovo Thinkpad T560
                                          by lucaszmn
                                          Problem:
                                          I am attempting to remove the WWAN card whitelist from my Lenovo ThinkPad T560.
                                          Initial Findings:
                                          • My current BIOS version is N1KET58W (1.45).
                                          • I have a CH341A programmer and have successfully created two full backups of my BIOS.
                                          • I have the ability to use command-line tools on a Linux machine.
                                          Troubleshooting Steps & Conclusions:
                                          • I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • 1g0r
                                          Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                          by 1g0r
                                          First, the data in brief:
                                          Manufacturer: Lenovo
                                          Model: ThinkPad L15 G3 21C3-0016GE
                                          motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                          IC Bios 1: MX77L25650F
                                          IC Bios 2​: MX25L25673G
                                          EC Chip: NPCX997KAABX
                                          So far I've been a silent reader, but now I need your help
                                          I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                          I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                          The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                          01-18-2025, 02:39 AM
                                        • MaxonDomkrat
                                          Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                                          by MaxonDomkrat
                                          Hi everyone.
                                          I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                                          07-30-2025, 01:27 PM
                                        • Glytch
                                          Bios Request for Lenovo Thinkpad T14s Gen 5
                                          by Glytch
                                          Hi All, Does anyone hoave a working bios for Lenovo ThinkPad T14s Gen 5
                                          Type: 21LS-0029UK
                                          MotherBoard: LT4E1 NM-F832
                                          Bios Chip: GD25LB512MEY1G
                                          any help is appreiated
                                          09-10-2025, 01:41 PM
