Is my Laptops Hard Drive on it's Way Out? (4 Year Old Samsung ST1000LM024)
  • RukyCon
    A Fake Rubycon
    • Jan 2017
    • 816
    So just a few hours ago (from when i'm posting this) my laptop (which is a Dell Inspiron 3542) randomly shut down for no reason and when i rebooted it, some of the files on the desktop had moved and some files on the taskbar were missing.
    The hard drive in this thing is a 4 year old Samsung ST1000LM024 with 30K POH and was working fine up until now (and looking around online seems to show that this model is not very good in general).
    What do you think, is it time to replace it and if so, what drive should i replace it with?
    The OS i'm using is Windows 7.
    I'm not a expert, I'm just doing my best.
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: Is my Laptops Hard Drive on it's Way Out? (4 Year Old Samsung ST1000LM024)
    Yes, swap it out ASAP. Replace it with a Western Digital of your choice.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
    • on/off
      • Oct 2016
      • 333
      • Indonesia
      For me brand S*****g for HDD is only crap, on 2009 only can use for 2 month then suddenly got totally bad sector. after that happen i never trust anymore.
      WD or Seagate, one of them the first my choose.
      Hitachi.
      Toshiba.
      both on last seem lower quality from top ones
      I format with help xp bottable or HBCD.
      -Primary (C)
      -Logical (D-Y partitions)
      -unallocated (Z)
      didn't like all partition as primary and i believe have more reliable.
      • Conste
        • Oct 2018
        • 235
        Actually I have the same model here on my desk (defective) manufactured by Seagate. So I do think that ur drive is Samsung branded but manufactured by Seagate.
        I would choose WD, never had problems with those
        • RukyCon
          A Fake Rubycon
          • Jan 2017
          • 816
          Ok, i'm looking at getting a Western Digital WD10JPVX. should this be able to replace my current drive?
          • TechGeek
            Computer Geek
            • Jan 2015
            • 2254
            Looks good to me.
            sigpic
            • RJARRRPCGP
              • Jul 2004
              • 6304
              "ST"-> Probably a Seagate with the Samsung name slapped on it! And Seagate 2.5-inch HDDs, apparently have major issues! With extreme slowness probably being common.
              Just like Maxtor earlier, where their name was slapped on Seagate HDDs, probably at or roughly 5 years before Samsung had the same kind of fate!
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • RukyCon
                A Fake Rubycon
                • Jan 2017
                • 816
                One last question, do you think the issue i had might be related to the hard drive? (PC freezing then shutting down and after rebooting, files on the desktop moved and files in the taskbar disappeared)
                • TechGeek
                  Computer Geek
                  • Jan 2015
                  • 2254
                  Yes
                  sigpic
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Are you getting an auto-reboot from Windows? (caused by an error that's also a BSOD)
                    Arc A770 16 GB
                    • RukyCon
                      A Fake Rubycon
                      • Jan 2017
                      • 816
                      No.
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        No.
                        A shutdown is usually the CPU reaching a critical temp. Thus, on a wild goose chase, LMAOO!
                        A crash is most likely the HDD, except for an Athlon II-based HP CQ 61 from 2009, of course...
                        Arc A770 16 GB
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8340
                          personally, I'd take the HDD out, put in a SSD, ditch windows and run some flavor of linux.
                          • Conste
                            • Oct 2018
                            • 235
                            Yeah, just try an SSD and see if your machine works then. 120 GByte will cost around 20-25$, even cheaper than an HDD
                            Or do you need the big space of the hard disk?
                            • RukyCon
                              A Fake Rubycon
                              • Jan 2017
                              • 816
                              I only use under 1/3 of the 1TB.
                              • ChaosLegionnaire
                                HC Overclocker
                                • Jul 2012
                                • 3266
                                • Singapore
                                just download some kind of software that can pull the smart data from the hard disk like crystal disk info or hdtune. look for any reallocated, pending or uncorrectable sectors. that most likely indicates a failing hard disk.
                                • piernov
                                  • Jan 2016
                                  • 4439
                                  • France
                                  I'm with ChaosLegionnaire here, first thing to check, if the hard drive looks healthy you may suspect something else. (doesn't mean the hard drive is 100% good but still)
                                  But yeah replacing an HDD with an SSD is always a good idea as well.
                                  • RukyCon
                                    A Fake Rubycon
                                    • Jan 2017
                                    • 816
                                    I have crystal disk info and as far as it can tell, the disk is fine.
                                    • Conste
                                      • Oct 2018
                                      • 235
                                      Download HD Tune and perform a Full scan of the drive, but not in quick mode.
                                      If there is no defective sector on the disc, the problem could be another. OR the drive electronics could habe a problem itself, but mechanically everything is good.
                                      • TechGeek
                                        Computer Geek
                                        • Jan 2015
                                        • 2254
                                        Can you post a screenshot of what PassMark DiskCheckup says about the drive?
                                        sigpic
                                        • federalhouse
                                          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                          by federalhouse
                                          Hi everyone,
                                          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                          **Background:**
                                          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                          **What I've Tried So Far:**
                                          1. I accessed
                                          08-01-2024, 07:03 PM
                                        • tmcw
                                          PC case - Hard drive rails
                                          by tmcw
                                          A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                                          So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                                          I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                                          Now, the case is a CiT Gaming Case, and...
                                          05-22-2022, 12:04 PM
                                        • madura2010
                                          DAY11AM6E0 hard disk drive and optical disk drive not detected
                                          by madura2010
                                          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                          i checked the connectivity of ribbon=good communication with hard and motherboard
                                          changed hard disk and checked=3f0 error persist
                                          sata power=+5v available
                                          Then checked data capacitors=all good
                                          Then checked data lines path connectivity to pch=all good
                                          reflashed...
                                          03-12-2023, 09:09 AM
                                        • ash91
                                          Hp pavilion 15 not detect hard drive
                                          by ash91
                                          Hello gentelmen .... this is my first post and sorry for my bad english,
                                          so my proplem is my laptop keep losing hard drive even if i but the
                                          hard disk in the cady (the box that can replace the dvd rom with hard disk)
                                          when i turn the laptop on the massage that said no boot media found pop on
                                          the hard disk is fine and to be sure i try another hard
                                          i also update my bios to the last update
                                          the 5 volt is present on the hard connector on the motherboard
                                          the dvd rom work fine when i but a windows dvd in it
                                          also when i boot from flash...
                                          06-07-2023, 01:45 PM
                                        • reformatt
                                          Intel iMacs, 3rd party SSD failures and Fusion setups
                                          by reformatt
                                          I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                                          As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                                          So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                                          12-18-2024, 10:34 PM
